Old Jan 06, 2007, 05:41 PM
Conservative, RC extreme
Petaluma, Calif.
Joined Nov 2005
Ultra Stick 120
I bought a Ultra stick 120 jwith a Saito 180. What a beast! It has plenty of power but its a fuel sucking pig!!! I get a whopping 7 minutes out of the tank that was installed in it. (I don't know how big it is,, can't see it) Do you experts have any other engine recomendations that will still have verticle performance with better fuel consumption? GAs?
Chris
z1nonlyone is offline Find More Posts by z1nonlyone
Old Jan 06, 2007, 08:47 PM
WCB
NC
Joined Aug 2005
No expert here but I do know 180's are thirsty. For longer flying time and cheaper fuel go with gas. As much as I fly I couldn't afford glow fuel for a 180.
WCB is offline Find More Posts by WCB
Old Jan 06, 2007, 09:02 PM
Petaluma, Calif.
Joined Nov 2005
Hey thanks wcb,,, yea I am thinking gas will be cheaper in the long run. Do they have the power that glow does? So if I get a 1.8 inch gas motor will it perform the same as my 1.8 inch glow? How do you match a gas engine to the plane? It seems that gas engines are MUCH heavier than glow. Do you know a good match for my ultra stick? I am thinking it weighs around 13 lbs.
Old Jan 06, 2007, 09:39 PM
pro R/C crash-test pilot
United States, WY, Gillette
Joined Jan 2006
i think it is the zenoah g26 that goes with the stick 120 , i think it is heavier and might cut down on speed but vertical will still be good , bit pricey but well worth it.
Rcgary20 is offline Find More Posts by Rcgary20
Old Jan 06, 2007, 10:03 PM
Petaluma, Calif.
Joined Nov 2005
HI RC,,, So I imagine by your post in that the speed might reduce,,, that the rpm is less? With a stick,,, speed is not a requirement but I guess that 3d work is. I like the ability for a plane to hang on the prop and maneuver at slow speeds with the power to pull out.
Old Jan 07, 2007, 02:09 AM
Joined Jan 2006
speed might reduce yes , only because there is less RPM's than lets say a 2 stroke 120 to 160 size but since your runnig a 4 stroke it might be about the same , in general 4 strokes have less rpm than 2 strokes , you might get away with it performing just as well , but gas engines are heavier than glow so youll want to take that into consideration , i think youll enjoy a gasser on your stick , there are a few guys at my club that has those with a gasser and they seem to like it. Gary
Old Jan 07, 2007, 08:24 AM
WCB
NC
Joined Aug 2005
I'm not sure what size gas engine will make the same power as the Saito 180. Evolution gas engines are light but expensive. I have an Evolution 45cc in a H9 27% Extra and it has gobs of power. Very good engines but they are pricey. Zenoah is a fine engine and reasonably priced but they are heavy. I've heard good things about Brillelli gas engines.
WCB
Old Jan 07, 2007, 08:32 AM
God is good
Viper Pilot's Avatar
Banjul
Joined Jan 2001
I've got an old G-23 in the Ultra Stick 120, and it is not a vertical machine. It climbs well, but not unlimited. I'm not sure if a newer G-26 would help. The next step, a G-38 would give it unlimited, but would be WAY TOO MUCH for the Ultra Stick.
Viper Pilot is offline Find More Posts by Viper Pilot
Old Jan 08, 2007, 01:58 PM
Joined Aug 2005
I had lots of fun with my Ultrastick Lite with a G-26 on it.
Low cost motor - cheap on fuel.
I strengthened firewall (pins and blocks).
Move all weight to tail (battery, tail servos)
Modified elevator (larger movable surface)
Pull-pull on rudder, dual servos for elevator.
Powered by G-26 with $20 after market pipe from http://wackerengines.com/
18x6W APC
AUW was just shy of 10.5 llbs
Vertical pull from hover was very good. I posted video way back when......
http://www.rcgroups.com/forums/showthread.php?t=535229
rcflatspin is offline Find More Posts by rcflatspin
For Sale Hanger 9 Ultra Stick 120 sea157 Aircraft - General - Radio Equipment (FS/W) 1 May 30, 2005 11:13 AM
Servo Recomendations please [Ultra Stick 120] cactus Fuel Plane Talk 7 Apr 04, 2004 09:22 PM
FS Ultra Stick 120 NIB atlav8r Aircraft - Fuel - Airplanes (FS/W) 2 Aug 24, 2003 08:31 PM
Wanted: h9 Ultra Stick 120 slvmnr Aircraft - Fuel - Airplanes (FS/W) 0 May 21, 2003 04:56 PM
NEED: Hanger 9 Ultra Stick 120!! NIB Chic Aircraft - Fuel - Airplanes (FS/W) 0 Jan 24, 2003 07:47 AM
