Old Dec 06, 2013, 09:58 PM
bicyclemonkey's Avatar
Fayetteville, AR
Joined Jan 2010
Build Log
Balsa USA Stingray 120 Build.
This is my first traditional kit build, traditional being not laser cut. It's a 20 year old kit that was given to me by a fellow club member who won it in a raffle years ago. I'm going electric and I'm thinking something that'll spin a 16" prop on 8s.
bicyclemonkey is online now Find More Posts by bicyclemonkey
Old Dec 06, 2013, 10:26 PM
Fayetteville, AR
Joined Jan 2010
Inside the box.
Old Dec 06, 2013, 10:49 PM
Fayetteville, AR
Joined Jan 2010
Wing coming together.
Old Dec 07, 2013, 08:25 AM
FICKLE FLYER
tlh101's Avatar
Corpus Christi, Texas, United States
Joined Dec 2002
I built one if these about 15 years ago. Powered it with a Fox 78. It's a really good flying and fun airplane. Ugly as hell, but fun.
tlh101 is offline Find More Posts by tlh101
Old Dec 07, 2013, 11:13 AM
Fayetteville, AR
Joined Jan 2010
It sure is an ugly plane! Its been a fun build so far!
Old Dec 07, 2013, 10:50 PM
Fayetteville, AR
Joined Jan 2010
Making progress on the right wing.
Old Dec 11, 2013, 06:38 PM
DWS
D.W. Schmidt
United States, IL, Scott AFB
Joined Sep 2004
Wow, looking at your pictures brings back a lot of memories. I look toward to the days that I have the time to build from a kit or scratch again!
D.W.
DWS is offline Find More Posts by DWS
Old Dec 15, 2013, 06:06 AM
numb_thumbs's Avatar
United States, TX, Frisco
Joined Mar 2013
That wing is GORGEOUS! I am in love with your building "board" too! Where did you get that?
At least we use one of the same squares! "Old Orange" lol
numb_thumbs is offline Find More Posts by numb_thumbs
Old Dec 15, 2013, 04:48 PM
Fayetteville, AR
Joined Jan 2010
Thanks for the comments!!!!
I have started sheeting the wings.
Some may know this already but since this is my first model I thought I'd share.
I got this tip from a veteran modeler at my club. Use a glue brush to apply a thin layer of wood glue to the spar and ribs the balsa sheet will contact. Remove and there will be a glue imprint on the sheet. Re-apply a thin layer of wood glue to both pieces and allow to dry.
Once dry, line up the sheet and apply heat with a monokote iron on max. The glue will bond almost instantly.
Old Dec 15, 2013, 09:14 PM
Fayetteville, AR
Joined Jan 2010
That's a hollow core door on saw horses. I went to a local sheet metal shop and had them cut me a piece of galvanized sheet metal for the top.
Old Dec 18, 2013, 09:27 PM
Fayetteville, AR
Joined Jan 2010
It wasn't in the manual but I added shear webbing on the spars for added strength.
Old Dec 19, 2013, 08:53 AM
Joined Mar 2013
your workmanship is admirable!
My planes fly straight and trued (for the most part) but my oh my they do not look nearly so good naked.
Old Dec 19, 2013, 09:24 AM
Fayetteville, AR
Joined Jan 2010
My planes fly straight and trued (for the most part) but my on my they do not look nearly so good naked.
Thanks for the comment! I have discovered a 2/8 inch twist in the wing though that I'm hoping will correct with aileron trimming. I think this is because the main spars were warped.
Old Jan 02, 2014, 10:04 AM
Fayetteville, AR
Joined Jan 2010
Thank you Balsa USA for making me a better modeler by having me shave down square stock for the leading edge instead of supplying me with a circular piece.
Old Jan 07, 2014, 11:52 AM
Fayetteville, AR
Joined Jan 2010
Cap strips on the ribs.
Discussion Balsa USA Stingray 120 Motor Suggestions. bicyclemonkey Glow to Electric Conversions 3 Nov 15, 2013 09:01 PM
Sold Balsa Usa Stingray 120 dpsollmann Aircraft - Fuel - Airplanes (FS/W) 0 Nov 08, 2013 08:50 PM
Wanted BALSA USA STINGRAY 40 or 120 Aerofreek1 Aircraft - Fuel - Airplanes (FS/W) 0 Jun 09, 2012 09:56 PM
Wanted Balsa USA Stingray 120 KIT transformingfoam Aircraft - Fuel - Airplanes (FS/W) 0 Jan 06, 2007 07:46 PM
Alert WTB Balsa USA Stingray 120 KIT Gene Chernosky Aircraft - Fuel - Airplanes (FS/W) 0 Sep 03, 2004 07:25 AM
