Old Mar 29, 2012, 09:51 PM
United States, FL, Bradenton
Joined Jan 2012
Turnigy Accucel 6 charger questions???
I want to get a 12v power supply and then order 2 or 3 Turnigy Accucel 6 Balance Chargers for charging 1300 and 2200 3 cell packs and I want to know if anybody knows exactly what I need extra to order from HobbyKing like balancing boards or plugs or harnesses etc since it takes a few weeks to get here from China I want to get it right the first time. It says it comes with harnesses but what's that mean? My batteries will all be converted to Dean's style T-plugs and it looks like I may need this which they are out of):
http://www.hobbyking.com/hobbyking/s...onnector_.html
or this:?
http://www.hobbyking.com/hobbyking/s...g_harness.html
and this for charging in the car in a pinch:?
http://www.hobbyking.com/hobbyking/s..._Chargers.html
overmyhead is online now Find More Posts by overmyhead
Old Mar 30, 2012, 05:58 AM
Canada, ON, Stouffville
Joined Nov 2011
I am not sure where you are getting the batteries....But if you plan to get a few batteries at the same spot...It is easier and safer to convert the charge connectors.
I went with the XT60, but many like the Dean, just if you are buying from HK...almost everything comes with XT60's already attached.
I bought 2 ten packs of connector, some servo extensions, and the XT60 paraboard, which they do have in stock, Silicon wire in Black and Red, Heat shrink in Red and Black, and I built all my charge connectors.
I even picked up a 4 battery box and put a connector on it to charge my many AA NiMh batteries around the home... This way the wife see's the practical side of the hobby
It took me 3 orders to HK before I got everything I needed for connecting...And took most of the offseason. But if you make your decision right away on connector style....You should be good to get everything at once.
as a note, the Servo extension are cut and a connector is added to charge receiver, and Transmitter batteries...
Hope this helps
sts41
sts41 is offline Find More Posts by sts41
Sold Turnigy accucel 6 charger w/power supply. CorgiCowPockets - xxDExx Aircraft - Electric - Batteries & Chargers (FS/W) 3 Feb 28, 2012 09:48 AM
Wanted WTB Turnigy Accucell 6 or 8 Charger DaaBears Aircraft - Electric - Batteries & Chargers (FS/W) 3 Feb 08, 2012 12:08 PM
Help! Turnigy Accucel 6 charger-to-powersupply cords (I need 2) Afraidtoregister Batteries and Chargers 7 Jan 14, 2012 06:06 AM
Sold Turnigy Accucel-6 charger with power supply kyle7119 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 05, 2012 08:55 AM
Discussion Accucel 6 charger question Zork Batteries and Chargers 3 Dec 09, 2011 10:47 AM
