Old Jan 17, 2005, 03:49 PM
RACENUT44 is offline
Find More Posts by RACENUT44
Joined Dec 2004
Batteries Over Heating
New To Rc Boats
I Have A Oval Master 26, Hacker Esc,nemesis 10l Motor
It Runs Good , Motor Not Over Heated, Esc Running Cooling
But Thr Batteries Are Over Heating, Like Burnig
There Are Older Batteries My Son Had,power Max 2400mah
P.s. I Did Run Them Until The Boat Was Running Slow
Help !
Thanks Dennis
RACENUT44 is offline Find More Posts by RACENUT44
Old Jan 17, 2005, 04:51 PM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
Dennis, dont worry, I ran a 12v optimized najade, and a dolphin R34 from CML on tamya plugged 7.2v ni-cad packs, and they got HOT, as the motor in the 700/12 motor in the najade, and the 540 motor in the dolphin are sucking somewhere around 40 to 50 amps on start up, with 30 amps on run,
as long as you dont totally flatten the batteries every time, you should be ok. replace the batteries as they may be nearing the end of their service life, but you will find that the next set of replacement batteries will probably get almost as hot.
The fact that they are getting hot is normal when under high current loads, Nicads heat up when fast charging as well, so dont fret about it, also let me guess, ur run time is somewhere between 5 and 10 mins?
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Jan 17, 2005, 05:12 PM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Dennis,
How long have the "old" 2400mAh batteries been out of use?
They need a couple of charging/discharging cycles to get up to full capacity.
As Ghost already mentioned, don't run the boat untill the batteries go flat, you'll kill the cells, I always (well amost always) bring my boats in, as soon as the speed starts to drop (the new GP3300 NiMH's are expensive, but are the best available!)
If you go for new cells, and you go for NiMH, make sure your charger can handle them safely.
One thing to take in account is, that you have to run NiMH cells hot from the charger, charging them the night before will kill them in no time.
Nicads, like the Sanyo RC2400 (the best Nicads IMO) can be run cold without taking damage.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Jan 17, 2005, 07:53 PM
Joined Dec 2004
Thanks Guys
May Be I Run The Batteries Too Long , I Will Stop Earler
I Had A Good Charger Astro 110 D, Discharges And Charges Both Kind Of Batteries
Thanks Again Dennis
If Someone Wants To Reply , Please Do
Old Jan 19, 2005, 12:24 PM
Ghost 2501's Avatar
stoke on trent
also racenut, once your batteries next go flat, slow charge them over a 24 hour period
Old Jan 20, 2005, 11:14 AM
JIM CALDWELL A is offline
Find More Posts by JIM CALDWELL A
Cleveland Cuyahoga, Ohio, United States
Joined Dec 2000
What prop? are you running more than 4 min's?
How many cells?
2400's are probably 3 years old, get GP3300's as soon as you can.
You won't belive the difference!!
JIM CALDWELL A is offline Find More Posts by JIM CALDWELL A
Old Jan 20, 2005, 12:15 PM
martin richards is online now
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
Unless cost is no object or you're competing regularly, I'd look at some of the more budget-priced NiMH cells such as the bigger 3000 mAh Kan or similar. It really depends on how many amps you're going to be pulling and whether you need to squeeze the max voltage out of them. Anyway, with the new GP3600 being introduced, there may be bargains to be had of the "old" 3300.
martin richards is online now Find More Posts by martin richards
Old Jan 20, 2005, 07:16 PM
Joined Dec 2000
These boats are 12 cells running for 4 min's.
I belive the lead boat is your hull, it is running 8L motor with 440 prop, and GP3300's for comparisom.
http://www.rcgroups.com/gallery/show...cat=524&page=2
Happy boating!
Old Jan 20, 2005, 08:12 PM
Joined Dec 2004
Im Running 12-cell X-440 Prop
I Want A Smaller Propfor For Little More Run Time X-438
Next Race This Pond Bashing
mega 15/16/3 esc over heating rspiegel Electric Heli Talk 15 Mar 08, 2003 09:44 PM
batt over heating in my bug ESB Electric Ducted Fan Jet Talk 5 May 30, 2002 08:39 PM
aveox 1406/4y Over heating aryeh Electric Plane Talk 1 Sep 18, 2001 01:27 AM
over heating twinstar! stuart warne Foamies (Kits) 0 Jun 09, 2001 02:50 PM
