Old Feb 15, 2014, 10:08 PM
bickie is offline
Find More Posts by bickie
Australia, VIC, Melbourne
Joined Oct 2013
Careful!
Warning: Certain ESCs can destroy Sunnysky 2204 2300kv (and similar) motors
NOTE: See update at the bottom of this post for summary/insights from ongoing discussion.
Hey all,
I've just had an interesting issue with one of my sunnysky 2204 2300kv motors behaving really weirdly, then getting incredibly hot to the point where sparks/smoke came out (fun stuff).
They'd just been installed in my mini-quad - I'd done a few small hover tests/etc, then waited until the next morning to try in earnest.
The first time I fired it up, one of the motors didn't start spinning when arming the quad - after giving it a little bit of throttle, it stuttered backwards/forwards and started to smell very bad.
I quickly stopped it and had a look - there was no obvious issues with it (shorts, wiring, etc).
I noticed when running this motor it stutters when running (all other motors are fine on the same ESCs - HK F10A + SimonK)
Results pictured:
Note the burnt pole in the stator - it really looks fatter/like it's touching the others. All the other poles in the stator seem fine.
All the other motors behave normally. I've also tried this motor on an entirely different ESC and it behaves the same way.
Anyone else experienced this/have theories as to what could cause it? Faulty ESC? Manufacturing defect in the motor?
Cheers!
UPDATE #1: Further evidence points to ESCs & firmware versions (see later posts & below).
UPDATE #2:
Wow, this thread has really become a rich source of knowledge - quick summary of key points (to save everyone reading the whole thing):
  • Most ESCs cannot handle the high KV and will destroy these (and similar high-kv pancake) motors due to timing issues
  • Even on correct ESCs, most firmware versions will destroy these motors
  • The only reliably proven SimonK firmware version is the 2013-05-05 (attached to this post)
  • Alternately, recent versions of BLHeli (11+) have been proven to work when configured correctly (see below)
  • ESCs that have been known to work with the attached SimonK firmware include: Hobbyking 12A Blue Series, AfroESC 12A (programming tool)
  • Some people have experienced intermittent desync issues with AfroESCs on SimonK, which can be solved by adding a 100uF 16v capacitor across the input side of the ESC.
  • BLHeli
    • For suitable Silab based ESCs, you can use BLHeli to achieve reliable performance on these motors
    • Suitable BLHeli compatible ESCs include: Turnigy Plush 12A, BLHeli Sunrise 20A (+ programming tool for Silab ESCS)
    • BLHeli is now also available for Atmel based (ie: SimonK compatible) ESCs and is reported to be a great alternative
    • BLHeli must be configured as Motor timing: Medium-high, Demag compensation: off
    • Rotorgeeks are selling preconfigured 12A BLHeli ESCs that have been pre-flashed/setup suitably for these (and similar) motors.
  • SS x2204 on 4S
    • 4S is very problematic on 2300kv motors due to the very high RPM/timings. However, as of July 2014, the newly released KISS ESCs are known to work with this combination. They come in 12A and 18A versions.
    • It has also been reported that the newest BLHeli versions (12+) works on high quality ESCs on 4S, including the Rotorgeeks 12A.
Happy flying!
bickie is offline Find More Posts by bickie
Old Feb 15, 2014, 10:34 PM
panyator is online now
Find More Posts by panyator
panyator's Avatar
Singapore
Joined Jul 2013
Got the same problem, an esc failed on me during a static test. It's like opening a flood gate, all the current will pour into the stator without control and will burn the winding... so your motor is dead, unless you are willing to rewind it. And throw away the esc, it may seem like it is working but you wouldnt want the risk to burn another motor.
panyator is online now Find More Posts by panyator
Old Feb 15, 2014, 10:41 PM
Gadget-Geek is offline
Find More Posts by Gadget-Geek
Build,Fly,Crash,Repeat
Michigan
Joined Nov 2007
I believe this is caused at the factory when they press the stator to the base. I have noticed that some of my SunnySky motors bought elsewhere have smashed windings. When the windings get smashed, The lamination is damaged and could cause the winding to short themselves out. I haven't had any issues with my SunnySky motors but I also didn't use the ones I noticed had smashed windings.
GG
Gadget-Geek is offline Find More Posts by Gadget-Geek
Old Feb 16, 2014, 02:22 AM
bickie is offline
Joined Oct 2013
Ok, this just got more interesting.
I had a spare motor, so thought I'd just move on and replace it.
New motor in - multiple static tests (without props), all working beautifully.
Added some props for a test hover and on the first attempt, the front right motor did the same thing (oscillating back and forward). I stopped it quickly enough and tested it - sure enough it felt quite warm.
The key is - this was a different motor on a different ESC exhibiting the exact symptoms.
Current operating theory is that certain ESCs with certain firmwares (I'm pretty sure I'm running Simon K BS.hex - 2013-09-20) can fry these motors.
Old Feb 16, 2014, 06:49 PM
Redemptioner is offline
Find More Posts by Redemptioner
Professional UAV Services
Redemptioner's Avatar
Australia
Joined Dec 2009
Your issue is the Firmware you are using not the motors, this is a common problem with pancake motors and SimonK (hundreds of users had the problems), use the 5-15-2013 firmware and you will be fine with the sunnyskys and Tigers. Anything with high pole counts you don't want to use simonK with at all, you need to go to a ESC specifically made for multirotors motors with high pole counts in mind such as the hobbywing platinum pro series (up to 40 poles).
In short DO NOT use SimonK with pancake motors with a pole count above 12 poles.
Redemptioner is offline Find More Posts by Redemptioner
Old Feb 17, 2014, 06:16 AM
bimdas is offline
Find More Posts by bimdas
quadiger
Australia, WA, Perth
Joined Jun 2013
Had the same thing happen to one of my sunnysky motors after my mini crashed onto the road and the esc burst into flames. When I touched the motor it was burning hot. It was definitely the esc's fault.
bimdas is offline Find More Posts by bimdas
Old Feb 17, 2014, 11:03 PM
bickie is offline
Joined Oct 2013
Hey Redemptioner, that's really helpful, thanks.
You've ended up on the Blue Series 12A with the May-2013 SimonK, yeah?
I've seen on some of the OpenPilot threads that people are having more success with these (and other high kv/pole count pancakes) on the SiLabs based ESCs (ie: Plush) and Blheli. Any experience/thoughts?
Old Feb 17, 2014, 11:14 PM
VIDEOMAN3 is offline
Find More Posts by VIDEOMAN3
VIDEOMAN3
VIDEOMAN3's Avatar
New York
Joined Jan 2009
Same thing happen to me. My HK 10amp with simonk burned one of my new s2204 motor. I just saw the smoke coming from the motor ans the esc. So be advice HK 10amp and certain simonk firmware with this motor could be a disaster. I lost two escs burned into flame.
VIDEOMAN3 is offline Find More Posts by VIDEOMAN3
Old Feb 17, 2014, 11:42 PM
Waterbound is online now
Find More Posts by Waterbound
United States, MD, Annapolis
Joined Jun 2013
So far that's all I have run with my Sunnys HK Blue 12a SK 5-15-13 for 2.5 months maybe..no problems yet, knock on wood. I also don't use bullets and run 3s 1300 on a metal head h.
Waterbound is online now Find More Posts by Waterbound
Latest blog entry: Hubsan H107D Custom FPV Setup
Old Feb 18, 2014, 12:34 AM
bimdas is offline
quadiger
Joined Jun 2013
I've always used 5-15-13 as well. Next mini I'm going to use the one before that as I've heard it runs even better for the sunnyskys.
Its 33c outside and just took my mini for a fly. One of the escs feels alot hotter than the others and its not even the one supplying bec to the fc. Hopefully that doesn't mean a failure is impending.
Old Feb 18, 2014, 01:18 AM
Australia
Joined Dec 2009
Usually an indicator of the the CG being out.
Old Feb 18, 2014, 01:26 AM
bimdas is offline
quadiger
Joined Jun 2013
I was lifting a 200g battery on the rd230 so it was back heavy but wouldn't that cause both of the back escs to run hot?
Old Feb 26, 2014, 05:07 AM
Soma is offline
Find More Posts by Soma
Australia, QLD, Brisbane
Joined Sep 2012
Another vote for firmware being the cause of the issue.
Stick with SimonK 2013-05-15.
I recently tested even this firmware on 4S with the X2204 2300KV and the loss of sync caused huge currents to be sent to the motor.
Soma is offline Find More Posts by Soma
Old Feb 26, 2014, 06:03 AM
jasonmbiggs is offline
Find More Posts by jasonmbiggs
Jason
jasonmbiggs's Avatar
United States, TN, Bell Buckle
Joined Aug 2002
I ordered the Luminier ESCs for my Sunny Skys. Do I dare even try it?
jasonmbiggs is offline Find More Posts by jasonmbiggs
Old Feb 26, 2014, 06:05 AM
geggog is offline
Find More Posts by geggog
Joined Sep 2013
I'd be interested to hear how they go ... but I'm dubious as they're tiny, and these little motors can pull some serious amps (as Soma has proven).
geggog is offline Find More Posts by geggog
Off Site SunnySky X2204 2300kv *New in Stock* witespy Aircraft - Electric - Multirotor (FS/W) 65 Sep 15, 2014 04:17 AM
Sold 3S Flyduino Nanoquad - Sunnysky X2240-2300KV Motors AlienQuads Aircraft - Electric - Multirotor (FS/W) 5 Jan 02, 2014 08:59 PM
Found Looking for sunnysky 2300kv motors xhover Aircraft - Electric - Multirotor (FS/W) 5 Dec 30, 2013 10:43 AM
Sold SunnySky X2204 2300kv *new in box* p0st4L Aircraft - Electric - Multirotor (FS/W) 22 Dec 28, 2013 07:51 PM
Sold SunnySky X2204 2300kv *new in box* p0st4L Aircraft - Electric - Multirotor (FS/W) 24 Dec 12, 2013 08:52 PM
