Old Jun 15, 2010, 12:47 AM
CrashingDutchman is offline
Find More Posts by CrashingDutchman
CrashingDutchman's Avatar
The Netherlands, Utrecht, Amersfoort
HobbyKing 450 4-Blade/5-Blade Rotor Head
Pre order your 450 4-blade or 5-blade rotor head now. Stock arrival around 22th of june (in about a week):
4-blade (US$ 25.95) : http://www.hobbyking.com/hobbycity/store/uh_viewItem.asp?idProduct=12611
5-blade (US$ 27.95): http://www.hobbyking.com/hobbycity/store/uh_viewItem.asp?idProduct=12612
4-blade
5 blade
CrashingDutchman is offline Find More Posts by CrashingDutchman
Old Jun 15, 2010, 03:33 PM
mayday1 is offline
Find More Posts by mayday1
rancho san antonio, CA
Joined Sep 2005
4-blade
5 blade
I wonder how difficult it'll be to find 5 blades of equal weigh and cg. May be
with lower headspeed balancing of the blades isn't as critical.
mayday1 is offline Find More Posts by mayday1
Old Jun 15, 2010, 09:01 PM
kevinb120 is offline
Find More Posts by kevinb120
kevinb120's Avatar
United States, VA, Woodbridge
Joined May 2009
The prices are just STUPID cheap, I ordered both... They will be out of stock after the first batch forever. I've put my 500D-fused 450 on hold temporarily as I need to go back to re-evaluating pinion or motor/kv choices as it's a pig (on two blades), after 60 flights she's just a bruiser on batteries; and I have tons of other stuff on my bench. I also didn't want to to commit to making it so much more expensive going multi-blade in lieu of going larger, but now I'll go back with a proper head and do it right if I'm going to non stop fiddle anyway. Thank goodness these weren't done in BLUE!
She definitely could make do with a new 'hat' with a little more lift...
kevinb120 is offline Find More Posts by kevinb120
Old Jun 15, 2010, 09:11 PM
kevinb120's Avatar
Joined May 2009
You can find a ton of info on multi blade heads in the scale heli forum in the nitro heli forums here (scale electric is covered there), to see what you are getting into These are cheap enough to just throw in a drawer just in case you feel the bug to get into it.
http://www.rcgroups.com/scale-helicopters-43/
Old Jun 15, 2010, 09:12 PM
mosca.br is offline
Find More Posts by mosca.br
Trying to fly on the cheap!
Norway, Rogaland, Stavanger
Joined Aug 2008
That will look great with a 5 blade head!
That 5 bladed head is begging for a md500!
mosca.br is offline Find More Posts by mosca.br
Old Jun 15, 2010, 09:17 PM
kevinb120's Avatar
Joined May 2009
Considering these heads just came out, and the 3-axis gyros are showing up in quantity/quality with the prices dropping like a rock, stuff you never dreamed of getting into(like helis for me in the first place ) are becoming accessible. Everything else is going up in price, but this hobby gets cheaper every day. The problem is, with the price of each individual R/C item constantly going down, the count of those items tends to multiply just as quickly
Old Jun 15, 2010, 09:44 PM
Maksym is offline
Find More Posts by Maksym
Maksym's Avatar
Baie-Comeau, Québec, Canada
Joined Mar 2010
Do you have feathering shaft on those 4+ heads? how does it work if so? I'd assume the whole head would have to be changed when you crash?
Maksym is offline Find More Posts by Maksym
Old Jun 15, 2010, 10:14 PM
TomM is offline
Find More Posts by TomM
Rust: The poor man's Loctite.
TomM's Avatar
State College PA
Joined Jul 2002
Originally Posted by kevinb120 View Post
........ These are cheap enough to just throw in a drawer just in case you feel the bug to get into it.
You hooked me with that one. Just ordered the 5 blade. I just got a Jet Ranger fuse, now I'll have to put that on the shelf and get a H500.
TomM is offline Find More Posts by TomM
Old Jun 15, 2010, 10:17 PM
kevinb120's Avatar
Joined May 2009
Well, the H500 makes the 450 size heli look a LOT larger due to the small size of the full-scale bird. The fuse's are a bit heavy, but more blades=much more lift. Definitely can use it, even though multi-blades starts an entire new chapter of learning to setup a heli. It also becomes a bit tail heavy, but I fly 2600 3S packs(not shown-i just stuck a battery in there so she sits upright) and all is well balance wise. If you look carefully another 450 is 'hiding' behind the 500... I was getting ready to start playing around with lower pinions/higher kv motor or going to 4S to make it overcome the weight and unload the electronics, but multi-heads make so much lift I may just have to play around with pinions and new tail rotor gearing/sizes.
Old Jun 15, 2010, 10:19 PM
kevinb120's Avatar
Joined May 2009
They have feathering shafts. I assume they are locked(bolted?) into the head for each blade rather then supported by the other blade. The funny thing is how simple the heads are without all the hardware to support a flybar between the head/swash. Make 5 links exactly the same size, attach to head, adjust tracking and go as far as head setup. The nightmare with a flybar is to make it and the head work in unison properly. It's just a matter of making the heli tail able to compensate for so much more rotational force, the additional lift and proper headspeeds, and of course getting the gyro to work.
Old Jun 15, 2010, 10:25 PM
TomM is offline
TomM's Avatar
State College PA
Joined Jul 2002
Well, like you said, it'll probably sit in a drawer till winter....too many fish to fry right now. I do have my eye on this fuse...
http://www.hobbypartz.com/67p-450-md530-402-army.html
I bought the 206 from the same company/same price and IMO it's good quality.
Old Jun 15, 2010, 10:33 PM
kevinb120's Avatar
Joined May 2009
I would avoid that one like the plague, get one with a magnetic nose (a clone of the T-rex OEM type). HK has them, and RC aerodyne has a whole bunch.
http://www.scaleflying.com/450_Size_...show=90&page=1
Old Jun 15, 2010, 10:35 PM
kevinb120's Avatar
Joined May 2009
The HK head looks to be a clone of this setup:
http://www.scaleflying.com/product_p/tf5b4.htm
They also offer scale blades, weighted and non weighted, and not expensive at all
Old Jun 15, 2010, 11:54 PM
Jeremymtc is offline
Find More Posts by Jeremymtc
Pilot in Training
Monrovia, CA USA
Joined Nov 2005
Ditto that! I ordered both the 4 and 5-blade variants too (for that price, how can you not?). I've already got an RCA 5-blade head, but I'm still trying to work out the available pitch range using its follower... As best as I can tell, the RCA unit is intended for CCW operation - it seems there's not enough travel available for more than 4-5 degrees positive pitch when running CW/RH. These HK heads should be interesting to compare. The HK swash follower looks like it has much greater freedom of motion.
BTW, nice fuselage there, Kevin =)
Jeremymtc is offline Find More Posts by Jeremymtc
Old Jun 16, 2010, 12:31 AM
kevinb120's Avatar
Joined May 2009
Heh, nice battery, and love the tail rotor flip.
I had a few copterX's laying around, I had to strip off the anodizing... Use a 500 size head button for now, it looks great on the H500.
Only problems with that kit, the paint flakes right off the white nylon gear legs(sharpies to the rescue), and the vertical fin can vibrate enough it can get the gyro to try to correct it constantly. They should of done wood instead of plexiglass for the tail fins. I glued two pieces of carbon rod to the leading/trailing edges of the vertical fin to stiffen it up. Flies like its on rails ever since. I didn't even bother trying to get the rear mounting screws in, just did the front and used a tiewrap around the frame in the middle(I see a bit of the same there). I love how it likes to putt around nose high coming out of FFF and slow sweeping turns, just like the real deal. Just slowly flying it away, then giving it a 90 degree turn dipping the nose and hitting the gas looks just too darn good...
Question RC Aerodyne 5-blade rotor head. Minibichus Scale Helicopters 51 Mar 15, 2011 07:39 AM
For Sale NIP 5 blade rotor head Trex450 cheeseboy Aircraft - Electric - Helis (FS/W) 1 May 28, 2010 09:24 PM
Sold New 500 size 4 Blade PNP Scale Rotor Head Yardbee Aircraft - Electric - Helis (FS/W) 1 Mar 25, 2010 04:51 PM
Sold 4 blade tail rotor head (500 size) $90 shipped pttse Aircraft - Fuel - Helis (FS/W) 0 Mar 10, 2010 01:27 AM
Sold Lightning 4 Blade 450 size scale rotor head. jafo216 Aircraft - Electric - Helis (FS/W) 4 May 28, 2009 10:10 PM
