Old Jul 23, 2015, 07:42 AM
Jin597 is offline
Find More Posts by Jin597
Joined Jul 2015
PL6 - LiFePO4 - Discharge/Charge rates
Hi Everyone,
I'm new to charging, so please forgive if this has been addressed somewhere else (I did try searching).
I have PL6 as well as a 4S - 34aH - 13.2V LiFePO4 battery.
each cell has nominal 3.3V.
I am trying to do a full cycle (discharge/charge), and having issues with the PL6.
I have read on other threads that the best selection for this type of battery is preset #10 - High Power.
When I use this setting, even though I have set the Charge/Discharge rates at 15A, I am only getting 3.65A on discharge/charge.
My pack can definitely handle the amps (max continuous discharge of 170A and max charge current of 50A).
I'm hoping someone here can shed some light as to why I can only charge/discharge at 3.65 A when I have set to 15A for each....
Jin597 is offline Find More Posts by Jin597
Old Jul 23, 2015, 02:52 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
Sounds like you are hitting the internal discharge limit of 50 watts. 50 watts / 3.65 amps is 13.7v. You can use the regenerative discharge into a lead acid battery to increase the discharge capabilities.
Gregor99 is offline Find More Posts by Gregor99
Old Jul 23, 2015, 05:05 PM
Jin597 is offline
Joined Jul 2015
Is there any way around that without buying an SLA?
I was trying to avoid buying an SLA. My DC supply provides up to 30A so I was under impression it would be enough.
Cycling a 34Ah battery at 3.65A will take some time
Old Jul 23, 2015, 05:45 PM
Gregor99 is offline
Seattle
Joined Sep 2007
I think missed that the charge rate was also slow. For that issue, check the supply settings, current limit and low supply settings. Low supply setting should be 50%-70% of the supply voltage.
Old Jul 23, 2015, 05:58 PM
Jin597 is offline
Joined Jul 2015
Thanks Gregor. will check that tonight. I know for the first cycle, I want to be conservative and set the supply 15A, even though capable of more. Will give that a go. Thanks!
Old Jun 28, 2016, 09:49 AM
wickkerr82 is offline
Find More Posts by wickkerr82
Singapore
Joined Apr 2006
Hi guys,
Sorry to hijack the thread.
I have a cellpro powerlab 6 and a lifepo4 2100mah transmitter pack. However, my cellpro powerlab 6 only offers to amperes in a123 which are 2300mah and 1100mah. I am confused on which to use to charge my transmitter pack.
wickkerr82 is offline Find More Posts by wickkerr82
Old Jul 02, 2016, 07:51 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Use the A123 , 2300mah preset. It only needs to be close, and doesn't have to match.
Old Jul 15, 2016, 10:38 PM
Singapore
Joined Apr 2006
Thank you Gregor 99, will try that Sir.
Discussion charge/discharge rate im new Electric Power Cars 10 Jul 07, 2015 06:50 PM
Discussion LiFePo4 Charge after fully discharged Jack McC Batteries and Chargers 10 Oct 05, 2014 04:09 PM
Discussion How do Manufacturers find out 'C rate' for charge and discharge? lnpurnell Batteries and Chargers 6 Jun 10, 2014 07:51 AM
Discussion PL6 charging/discharging help!!! 3flyguy3 Batteries and Chargers 26 Aug 01, 2013 08:15 PM
Help! Need help understanding Discharge rate/ Charge rates, C ratings fltekdiver Batteries and Chargers 10 Oct 02, 2010 09:29 AM
