Old Dec 31, 2014, 08:23 PM
jeffsch is online now
Find More Posts by jeffsch
Jer. 29:11
jeffsch's Avatar
United States, WA, Snohomish
Joined Oct 2009
Build Log
Rockwell XFV-12a
I came across the Rockwell XFV-12a and was inspired to build a jetset44 style model.
Wingspan: 26.5 inches
Length: 36 inches
Wing area: 82.6 square inches
Canard area: 32.1 square inches
Preview of plans is attached below. (This is output from Sketchup.)
Construction is pretty straightforward:
* The fuselage is a box construction, with a few formers, and with doublers along the seams for later rounding.
* The forward fuse tapers to the centerline and turns into a former that runs to the rear and holds the stick mount for the pusher motor.
* The plans show a flat wing but following mopar_man, I laid the 5mm spar on top of the 6mm wing and bent a 3mm skin over top in a faux airfoil.
* There's one servo for the canard -- probably set up as an elevator. There are separate servos for the wing's control surfaces -- probably will be set up as ailerons. All control surfaces are actuated with torque rods.
* The nose cone and canopy are carved from pink foam.
* A short section of 1mm carbon rod is inserted in the tip of the nose cone and in the tips of the winglets.
* The bottom is reinforced with Silkspan from brodak.com . (I'm trying this instead of brown masking paper in the hopes it will be easier to cover in paint later.)
* The bottom half of the winglets are attached with magnets in the hopes that they'll be attached during flight but pop off on landing.
I marked the CoG per http://adamone.rchomepage.com/cg_canard.htm
The model is (almost) ready for a first flight, largely pending good weather.
As this is my first canard model, do let me know if you have any advice for the first flight and/or if you have any questions about the build.
jeffsch is online now Find More Posts by jeffsch
Old Jan 01, 2015, 01:57 AM
ksqm is online now
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Jeffsch,
Nice build. For your maiden, I would definitely have dual rates set up. Also, you might want to consider skids/land gear to protect the canard. It may take away from the looks, but it'll help ward off damage. Consider this your prototype/test mule. lol Search RC for thr "Star Cobra". Only other plane I know that uses the canard for it's elevator. Good Luck. Very nice Plane.
Ksqm
ksqm is online now Find More Posts by ksqm
Old Jan 01, 2015, 09:31 AM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
whoa..thats neat!!!
corsair nut is online now Find More Posts by corsair nut
Old Jan 22, 2015, 11:25 PM
jcrosk is offline
Find More Posts by jcrosk
United States, IA, Hudson
Joined Feb 2009
I've not seen that one before. That would make a cool EDF as well. I can't wait to see it fly.
jcrosk is offline Find More Posts by jcrosk
Old Jan 22, 2015, 11:37 PM
jcrosk is offline
Joined Feb 2009
More info - http://forum.worldofwarplanes.eu/ind...ckwell-xfv-12/
Old Jan 23, 2015, 09:27 AM
Jer. 29:11
jeffsch's Avatar
Joined Oct 2009
It is an odd one isn't it. Thanks for the link.
I've been waiting for better weather before its first flight. (And I'm still mulling over the suggestion by ksqm re: skids or other to protect the canard.)
Old Jan 23, 2015, 03:50 PM
foamdave is offline
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
jeffsch:
Uber cool! Hope that flies well for you...
Dave-
foamdave is offline Find More Posts by foamdave
Old Jan 23, 2015, 04:48 PM
ksqm is online now
Joined Mar 2009
Been waiting on this one!!!
Ksqm
Old Jan 23, 2015, 06:02 PM
BlazerB52 is offline
Find More Posts by BlazerB52
BlazerB52's Avatar
Fenton,MO USA
Joined Aug 2005
FYI The forward fuselage and cockpit was a A-4 skyhawk and the nose gear retracted forward. Lots of off the shelf parts was used to control costs. Only time it was in the air was suspended from a gantry for tests. Hope it flies good.
Will be watching how this project goes.
BlazerB52 is offline Find More Posts by BlazerB52
Old Jan 31, 2015, 03:08 PM
foamdave is offline
skumgummi dave
Gresham, OR.
Joined Mar 2004
jeffsch:
Any more progress on this one? Curious folks want to know.....
Dave-
Old Feb 01, 2015, 12:04 AM
Jer. 29:11
jeffsch's Avatar
Joined Oct 2009
I haven't had a chance to maiden it yet. Stay tuned...
Old Mar 11, 2015, 07:44 PM
foamdave is offline
skumgummi dave
Gresham, OR.
Joined Mar 2004
jeffsch:
Anything new on this beauty?
Dave-
Old Mar 11, 2015, 11:26 PM
Jer. 29:11
jeffsch's Avatar
Joined Oct 2009
Thanks for asking! Took it to our club meeting and got lots of good advice -- some the same as here.
It's waiting for its first flights now. The weather would be a convenient excuse, but we've been having unseasonably good weather.
Old Mar 12, 2015, 12:02 AM
foamdave is offline
skumgummi dave
Gresham, OR.
Joined Mar 2004
Actually that is good news. Some fellows start an unusual scratch built and re-kit it on the first flight and you never hear another word. I'm glad that's not the case here.
Best to you;
Dave-
Old Mar 21, 2015, 11:48 PM
Jer. 29:11
jeffsch's Avatar
Joined Oct 2009
A little reinforcement of the business end of the jet. The battery hatch I built is too far forward to balance -- the area and location of the canard more than offset the rear-mount motor. The picture shows where a 1750 mah battery needs to go,
Discussion North American Rockwell OV-10 Bronco TedD60 Scale Drawings and Three Views 2 Feb 27, 2016 11:54 AM
Wanted Plans, Rockwell Commander 112/114 Dave Buck Aircraft - Fuel - Engines and Accessories (FS/W) 1 Dec 06, 2014 08:50 PM
Sold Bridi Rockwell Aero Commander Shrike Fuse, Center Section & Wings $115,00 SHIPPED!! stevster Aircraft - Fuel - Airplanes (FS/W) 2 Oct 13, 2014 10:34 AM
Sold Vintage Rockwell Electronic Calculator Model 8R Mikey 68 Non R/C Items (FS/W) 2 Mar 09, 2014 08:48 PM
Convair XFY-1 or Lockheed XFV-1 vtol Electric Plane Talk 2 May 02, 2004 10:59 PM
