Old Sep 04, 2013, 03:30 PM
payne9999 is offline
Find More Posts by payne9999
Balsa&Tissue
payne9999's Avatar
United States, OR, Beaverton
Joined Jan 2011
Build Log
DC-3 C-47 Project
I have always wanted to build a DC-3. I have considered the Top Flite kit but I am almost convinced I should just scratch build the thing. So, for a prototype I am building a small Guillows conversion to get familiar with the airframe and test out some ideas.
The end goal is to build a 80-100" version and have solid ideas about equipment installation, CG and were best to build a battery hatch etc. Setting the goal at 82" would be nice because then I could use the retracts designed for that kit.
So for now here is my start on the tiny C-47 version:
I have cut lightening holes in all the formers and ribs and scalloped the main crutch pieces. I am trying to save weight where I can.
payne9999 is offline Find More Posts by payne9999
Old Sep 04, 2013, 07:26 PM
bhoov128 is online now
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Very cool... in for progress updates
Ben
bhoov128 is online now Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Sep 04, 2013, 07:31 PM
glewis is offline
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
I'm in!
This one is on my bucket list since mosquito control used them to spray around here in the early 70's. They used 2 aircraft that flew in formation spraying at treetop level. It was so cool to be jolted out of bed right a dawn by the sound of 4 radials thundering overhead.
Glenn
glewis is offline Find More Posts by glewis
Old Sep 04, 2013, 07:37 PM
RMCCOR7737 is offline
Find More Posts by RMCCOR7737
Heads up...
RMCCOR7737's Avatar
United States, VA, Stafford
Joined Jun 2009
Watching also. love the Guillows conversions...
RMCCOR7737 is offline Find More Posts by RMCCOR7737
Old Sep 04, 2013, 08:54 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
I am jazzed about this one. A micro DC-3 is interesting to me for some reason. However, the end goal is to size this up to at least 80".
I have the ESC's, receiver, motors, servos all set aside and tested so it is just a matter of fabricated the air-frame and plugging through the process. Right now my big concern is weight (of course) and I would like to place the target at 350 grams. I am not going to sheet this one. The stringers are quite close together on the fuse and I think it will look really nice without sheeting and I want the best flight performance I can get.
Right now the electronics and power system are as follows:
2X Park 250 motors from HK
2X 10 amp ESC's from Headsup
5X 3 gram servos from Headsup
Orange 6 channel receiver without the case
Coverite Solite covering
Props: TBD
Gear: probably fixed but I would like to consider some sort of micro retracts
Controls: Ailerons, Elevator, Rudder, Throttle, Split flaps
I have not decided whether to do a C-47 or DC-3. The decals Guillows provides for Eastern Airlines are really nice. There is a nice Gonney Bird down at the Evergreen Flight Museum that might make a good full size reference.
Dave
Old Sep 04, 2013, 11:22 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Finished framing up the wing:
Prop selection is proving difficult since I would like a 3 blade. Most of the 3 blade props like GWS are to shallow pitch for this plane. I need a 4x4 3 blade to be scale and maybe a 5X4X3 or 5X5X3. So far I am not finding a prop that would look scale but it may just require a 2 blade prop for flying.
Dave
Old Sep 04, 2013, 11:32 PM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
Props: TBD
Dave
I need to get out to the Evergreen museum again... However, the fly-in in Hood River is this weekend!
The Gooney is coming together fast! Somewhere, I have (or maybe Pa has it) an old plan for a C/L DC-3, can't remember the span, though it was bigger then 3'. It shows an Ohlsson and Rice paint scheme (!) and the fuse is a big chunk of carved balsa. Good outline, however.
James
Deuce is offline Find More Posts by Deuce
Old Sep 05, 2013, 12:09 AM
Laramie is offline
Find More Posts by Laramie
San Bernardino California U.S.A.
Joined Dec 2009
This is just a dry run ...
... for a larger project, right?
If thats the case, use a 2 blade prop.
If its important to do the 3 blade thing, Ive had success using rubber powered props, 3 props cut into 6 blades, than thread and epoxied to a hub over a plan at 120 degrees, get the idea? Its not too hard to do.
Anyway, Ill be following this thread, as it looks like fun, for sure. .....
Laramie.
Laramie is offline Find More Posts by Laramie
Old Sep 05, 2013, 12:28 AM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Laramie.
Yes, I am wanting to do a small park flyer size and then move on to the 80-100" one. The 80" or larger will not be a problem as far as finding props but in the smaller sizes (5" or under) it is difficult.
Dave
Old Sep 05, 2013, 12:38 AM
meltor is online now
Find More Posts by meltor
AKA Jagdpanther9
meltor's Avatar
Joined Jun 2012
cool! this one is on my list as well. i'm in.
meltor is online now Find More Posts by meltor
Old Sep 05, 2013, 01:35 AM
GROUNDeffected is offline
Find More Posts by GROUNDeffected
GROUNDeffected's Avatar
Joined Jan 2013
I'm interested too looks like a good challenge. Are you going to use counter rotating props or both same direction?and what degree of down and right thrust if any?surely must be some?
GROUNDeffected is offline Find More Posts by GROUNDeffected
Old Sep 05, 2013, 01:42 AM
Spitfire1954 is offline
Find More Posts by Spitfire1954
Spitfire1954's Avatar
United Kingdom, England, East Riding of Yorkshire
Joined Jan 2011
Hi Dave – I have this one on the board right now (I must start a build log) and it is proving to be a challenging conversion – I shall be following with interest, looks great so far.
Charles
Spitfire1954 is offline Find More Posts by Spitfire1954
Old Sep 05, 2013, 07:18 AM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Contra-rotating is what I usually do on multi-motor projects although it really doesn't matter much. On planes where the engines are not on the centerline the P factor effect is not noticeable to me. I have flown small and large twins and 4 motor planes both ways and saw no so-called torque effect on takeoff roll. The only thing I could see was the plane turned one direction slightly better than the other but it was a very subtle effect.
So far on all my multi-motor projects I have used zero right and zero down. If I need some down I will add it after maiden unless someone out there who has built this model has advice. The contra rotating question is often answered by prop availability. If there aren't nicely matched sets of props by a given maker then the plane cannot be setup that way. I am currently flying a 75" B-17F and all 4 motors are turning the "normal" direction. I had it setup contra-rotating as well early on.
Dave
Old Sep 05, 2013, 07:52 AM
Bill Smudge is offline
Find More Posts by Bill Smudge
Bill Smudge's Avatar
United States, KY, Bowling Green
Joined Jul 2011
Hey Dave,
The bones are looking great, retracts will be nice if you can pull that off.
Looking forward to the rest of the build.
Bill
Bill Smudge is offline Find More Posts by Bill Smudge
Old Sep 05, 2013, 08:07 AM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Originally Posted by Bill Smudge View Post
Hey Dave,
Bill
There is one other guy out there that was working on a small DC-3 (not Guillows) and he had a design for tiny retracts. However, he did not explain the mechanism design. I may search for his build log and see if he will share the design.
One thing I hate about micro builds is finding a way to access the components and the battery mount. I am going to frame up the entire plane, temporarily mount all the components and check CG. Then I will figure out what part of the plane will have the main access hatch. I have been thinking through this and the only way to know is to frame it all and check the CG.
Dave
FAQ Time for a Twin - Blu DC-3 / C-47 project Gene Bond Foamies (Scratchbuilt) 982 Jun 30, 2015 04:23 PM
For Sale HUGE ZD Fly DC-3 / C-47 pnp 74" Wingspan 1st $175 LPU wingspan100 Aircraft - Electric - Airplanes (FS/W) 2 Jun 14, 2013 03:40 PM
Sold New Topflite DC-3/C-47 kit with new retracts Mike Fortune Aircraft - Fuel - Airplanes (FS/W) 0 Mar 18, 2013 05:19 PM
Found DC-3 or C-47 kit nailbenderdude Aircraft - Fuel - Airplanes (FS/W) 1 Feb 24, 2013 06:38 AM
Sold Royal C-47 / DC-3 ARC Kit davepar Aircraft - Fuel - Airplanes (FS/W) 2 Feb 09, 2013 04:28 PM
