Old Oct 10, 2012, 03:01 PM
3flyguy3 is offline
Find More Posts by 3flyguy3
3flyguy3's Avatar
United States, IL, Waukegan
Joined Apr 2012
Question
What do the numbers mean?
Say 2204 1480kv or 2203 1750kv. What is the first number? The second?
3flyguy3 is offline Find More Posts by 3flyguy3
Old Oct 10, 2012, 03:03 PM
Ken Myers is online now
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
This part of the article Electric Power Basics should help with this:
http://www.theampeer.org/e-basics/e-basics.htm#MOTORS
The whole article starts here:
Ken Myers is online now Find More Posts by Ken Myers
Old Oct 10, 2012, 07:21 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
The first motor has a stator of 22mm diameter, 4mm stator depth and a Kv (RPM per Volt) of 1480Kv... maybe weighs ~23g.
The second motor is slightly smaller (maybe ~18g): 22mm stator diameter, but only 3mm stator depth... 1750Kv, so, at the same voltage, it will have to spin a smaller prop than the lower Kv 1480Kv motor.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 10, 2012, 08:20 PM
3flyguy3 is offline
3flyguy3's Avatar
Joined Apr 2012
Why does it have to spin a smaller prop?
Old Oct 11, 2012, 03:18 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
The prop size, and how fast you try to spin it, determines the power output: The motor's kv number tells you how many rpm it'll try tp spin at for every volt you put in, so for the same voltage the higher kv number will spin the prop faster and, thus, consume and produce more power. If the motors are rated for the same maximum power, a prop that's right for the lower kv motor might overload the higher kv motor and cause it to burn out.
abenn is offline Find More Posts by abenn
Old Oct 11, 2012, 07:53 AM
3flyguy3 is offline
3flyguy3's Avatar
Joined Apr 2012
Thanks. Makes sense.
Question sport, pylon, f3a.. what are all the catagories and what do they mean? flybybob Beginner Training Area (Fuel) 3 Jun 30, 2012 10:10 PM
Mega motors - what do the numbers mean??? DaleM Power Systems 2 Aug 12, 2003 07:32 AM
EzCalc - what DO all those numbers mean ? Ginger Adam Power Systems 3 Jan 10, 2003 12:32 PM
What do the Brushless motor numbers mean? pohlmeyr Power Systems 12 Dec 08, 2002 11:29 PM
prop numbers, what do they mean? cathode Beginner Training Area (Aircraft-Electric) 3 Jun 05, 2002 02:09 PM
