Old Feb 04, 2016, 05:22 PM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
Forgive me Pontiff if it is a sin.
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Feb 04, 2016, 05:32 PM
the pope is offline
Find More Posts by the pope
Australia, SA, Adelaide
Joined Sep 2007
Its OK my son , everything in this life is a sin . That's why we get such a good turn out on Sundaysj ! . cheers
the pope is offline Find More Posts by the pope
Old Feb 04, 2016, 08:49 PM
iadamz is online now
Find More Posts by iadamz
Joined Jan 2009
Lol. Yes. Make sure to bring money.
iadamz is online now Find More Posts by iadamz
Old Feb 04, 2016, 09:32 PM
lucas45 is offline
Find More Posts by lucas45
Canada, BC
Joined Sep 2007
Yes we all looking up into the sky asking ourselves which angle is mine!
lucas45 is offline Find More Posts by lucas45
Old Feb 04, 2016, 09:52 PM
the pope is offline
Joined Sep 2007
No need for money . bank transfer , paypal will do just fine . Money is so yesterday . Cheers
Old Feb 04, 2016, 10:02 PM
Joined Jul 2011
Being the Pope means no need for a wallet.
Old Feb 04, 2016, 10:18 PM
the pope is offline
Joined Sep 2007
Wanna bet ! The pope's a taker not a giver ! Cheers
Old Feb 06, 2016, 04:47 PM
cirrus_uk is online now
Find More Posts by cirrus_uk
cirrus_uk's Avatar
United Kingdom, London
Joined Mar 2012
Hi - would appreciate some advice here.
Had Aurora A9 with 2 Optima 6 lite RX for several years and have worked flawlessly with my electric models (3 cell lipo connected via SPC).
Just given transmitter and receiver to my relative who flys only IC. He has a 2 meter glider which has 3 channels. Uses 3 micro servos (2 X HS81 and 1 X HS82MG). He uses a 4 cell AAA NiMH pack (no room for anything larger).
We didnt use SPC port but connected his battery to the RX battery channel, bound the transmitter to the optima 6 lite in normal mode. Red light on TX and red light on RX module. All good and RX voltage reported as 5.8V. Spent some time setting the servo throws and subtrims. After around 15 mins of playing the transmitter module started beeping and the module showed both the RED light and BLUE light on all the time. RX module still showed a red light. Still had control. Turning off the power to RX module stopped the beeping but the RED and BLUE lights were still on the Spectra module.
After doing some research it looks like this is the Spectra module reporting low voltage. The module is supposed to auto detect a 4 cell pack is use for RX module and set limit to 4.5 V yet the module alarm was going off at 5.5v (we did not have an alarm set for the transmitter).
I used the HPP-22 progammer and set a custom voltage for the SPECTRA module to be 4.5V.
Everything now seems OK and no more module beeps and RED + BLUE lights.
I've obviously never had this issue using 11v LIPO packs with my electric set up. But moving to IC and the smaller 4 cell AAA receiver pack it was getting autodetected as 5 cell and a 5.5v cut off rather than 4 cell and 4.5v cut off.
So am I right in my assessment? Have I done the correct thing in manually setting the module cut off to 4.5V? Is this too low or OK? Is it correct that the module will show RED and BLUE led's and a beeping sound when low voltage detected and lights stay on even after disconnecting power to receiver? Is the beeping and light change indeed due to low voltage?
thanks
cirrus_uk is online now Find More Posts by cirrus_uk
Old Feb 08, 2016, 10:41 AM
Xpress.. is online now
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
You were seeing the module warning you about low voltage, re-programming it with the HPP-22 should have solved it. It is supposed to automatically detect rx pack voltage but it's possible it maybe mis-set it to the 6.0v/5 cell pack voltage. If you manually set the voltage warning with the HPP-22 it will not auto detect.
Xpress.. is online now Find More Posts by Xpress..
Old Feb 08, 2016, 11:01 AM
Bigster is online now
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
Originally Posted by Xpress.. View Post
The Spectra 2.4 modules are identical between the A9 and Optic 6 so they will interchange. It's not so scary back there, the switches are simple to work with. All you need to do is remove the switch nut, pop the switch out (it may have a bit of glue on it to help keep it in place), transfer the brass shim to the new switch, solder the leads in place, and re-assemble. Takes all of ~5-10 minutes to do.
Thanks again for the encouragement and offering the switch - it was a simple fix!
Bigster is online now Find More Posts by Bigster
Old Feb 08, 2016, 05:45 PM
cirrus_uk's Avatar
Joined Mar 2012
thanks - yes looks like I've sorted it. Fingers crossed for his maiden with it.
Old Feb 22, 2016, 12:26 PM
YellowJacketsRC is online now
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Hitec Service
http://www.rcgroups.com/forums/showp...ostcount=37010
YellowJacketsRC is online now Find More Posts by YellowJacketsRC
Old Feb 26, 2016, 08:25 PM
FredyC is offline
Find More Posts by FredyC
Not an addict to RC..... Naaaa
FredyC's Avatar
Mexico, S.L.P., San Luis
Joined Feb 2016
Awesome.
Just found this thread of A9'ers. Had my Aurora 9 for over 5 years. Bought it just as I was leaving the hobby. But I'm back and are just now startin to use it since January! I'm glad to hear all the issues are gone.
Just learned that the SPC port is a great thing! Havent yet used it, but will next week!
Awesome!
FredyC is offline Find More Posts by FredyC
Old Feb 26, 2016, 09:14 PM
CyberPilot is offline
Find More Posts by CyberPilot
I'm a feather on the wind
CyberPilot's Avatar
Orange County CA
Joined Apr 2003
FreddyC,
Funny, I thought I was reading a post I never wrote! I also bought my Aurora 9 when they 1st came out but never used it. I got busy with work while finishing my degree and raising my kids. I'm done with school and I'm ready to jump back into RC. Thanks for sharing, I don't feel so bad being out of it so long myself now.
Dave
CyberPilot is offline Find More Posts by CyberPilot
Old Feb 27, 2016, 07:26 PM
They Call him Dead!
Joined Jul 2003
It's a great radio. For the money it can't be beat imo. of course there are those that want all kinds of NEW features that my complain about it. Personally, I don't need a color screen or 6,000 model memory..... This radio is extremely easy to use and has NEVER failed me. What else do I need?
For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition freedomflyer Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 07, 2006 04:15 AM
WANT! Hitec Flash 5 Transmitter! jocappy Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2002 10:04 AM
Wanted >= 4 channel Hitec (or compatable) Transmitter OverHeadCam Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2002 10:56 AM
FS Hitec Prism 7X Transmitter mt_100 Aircraft - Electric - Airplanes (FS/W) 2 May 20, 2002 07:30 AM
WTB: Hitec Flash 5 Transmitter stevevanwagner Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2002 10:29 PM
