Old Feb 25, 2002, 01:10 PM
Mike Betz is offline
Find More Posts by Mike Betz
South Africa
Joined Feb 2002
Unstable SoarStar.
Hi.
My SoarStar likes to porpoise. I suspect my C of G is out. When I lift my SoarStar by the wing struts, the nose drops slightly. Is this the correct way of determening the C of G or am I doing something wrong?
Thanks - Mike
Mike Betz is offline Find More Posts by Mike Betz
Old Feb 26, 2002, 09:22 AM
Matt M is offline
Find More Posts by Matt M
Aeronautical nerd
Matt M's Avatar
Seattle
Joined Nov 2001
An easy way to find the CG is to balance the model on the ends of your index fingers (same place on each side of the wing) and see how far back on the wing it ends up balancing.
Typically, a good starting point is around the quarter chord (1/4 the wing chord from the front of the wing) and moving from there.
A forward CG will not fly well. An aft CG may not fly twice.
Once you see it explained and measured, you will have it. Sometimes descriptions are hard to follow.
Hopefully this is not the case here
HTH
Matt M is offline Find More Posts by Matt M
Old Feb 26, 2002, 09:46 AM
Tim Seidenstricker is offline
Find More Posts by Tim Seidenstricker
Boise, ID 83703
Joined May 2001
CG + Trim
Check the CG according to your instructions. Yes a little down is better than tail heavy. Much better. Also, if you trim it with to much up elevator, it will tend to do the same porpoising, but should be fairly mild. Don't know what your throttle position is during all of this, but you may want to back off to the 1/3 to 1/2 position after you have some altitude for safety.
Tim Seidenstricker is offline Find More Posts by Tim Seidenstricker
Old Feb 26, 2002, 10:05 AM
Radek Z is offline
Find More Posts by Radek Z
Radek Z's Avatar
Pampigny, Switzerland
Joined Oct 2001
I had the same thing on Wingo when I started. I moved the battery all the way forward (1" forward) and began to fly that way (obviously after help from e-zoners).
Interestingly enough over some twenty flights which followed I kept pushing the battery back and eventually I kept flying with the original position. I guess as you develop the feel for the plane you can control it better even if it's quite twitchy. It obviously glides better with the CG aft.
Radek Z is offline Find More Posts by Radek Z
Old Feb 26, 2002, 10:20 AM
Brian Nixon is offline
Find More Posts by Brian Nixon
Brian Nixon's Avatar
Clifton, Va., USA
Joined Sep 2000
Bingo, Radek. I like my Wingo CG back, too, for the same reason--better glide. Ultimately, it's a matter of preference and what one is comfortable with.
Brian Nixon is offline Find More Posts by Brian Nixon
Old Feb 26, 2002, 10:26 AM
Radek Z is offline
Radek Z's Avatar
Joined Oct 2001
Yup, but it took some time to get used to. If someone on the e-zone would not tell me to move the battery forward in the begining I would be probably very frustrated. So for Mike: battery forward and forget about the durtion records for the time being.
Old Feb 26, 2002, 10:29 AM
Clifton, Va., USA
Joined Sep 2000
Three or four flights and he'll start sliding that battery further and further aft.
Old Feb 26, 2002, 10:48 AM
MikeB is offline
Find More Posts by MikeB
South Africa
Joined Jan 2000
Thanks for the advice
To everyone who has replied to my mail. I was starting to think that nobody wants to talk to me. I really appreciate the replies. I will move the battery forward and try flying my SoarStar like that.
TTFN - Mike
MikeB is offline Find More Posts by MikeB
Unstable Soarstar MikeB Foamies (Kits) 4 Mar 31, 2002 04:02 PM
