Old Apr 01, 2015, 08:59 AM
jensstern is offline
Find More Posts by jensstern
Joined Nov 2010
Build Log
B36 peacemaker "the big stick of the 50s" from zero to lift-off
Hello guys. This is actually not a build-log in real-time because the plane is already nearly finished yet but I thought it's still worth sharing some experience.
I went into a B36 peacemaker. yes! Why would somebody do such a build? My background is as follows: I built and flew several twin engine electrics then I finished my 4-engine C130 which flew superb right away. So I thought how could I repeat my experiences in a similar model? The B36 has a simple fuselage - let's do it.
The model bases on cores of white expanded styrofoam sheeted with 1mm-balsa.
I had a set of old plans from the 60s seemingly 100 times copied already but nevermind .
jensstern is offline Find More Posts by jensstern
Old Apr 01, 2015, 09:02 AM
Joined Nov 2010
Nose and tail built up in oldshool style with planking balsa over formers. Sounds easy but just took time...
Old Apr 01, 2015, 09:05 AM
Joined Nov 2010
For transportation reasons I decided to go with a fixed ruder and removeable elevators. Each side received one servo. Connection with MPX connector and MPX snap-lock.
Pictures shows cutting rudder core and finished rudder.
-Jens
Old Apr 01, 2015, 09:09 AM
Joined Nov 2010
Cutting the wings brought a huge progress and some new motivation. As for the spar I was very limited with space. I decided to build an I-beam for maximum strength at low weight.
Old Apr 01, 2015, 09:12 AM
Joined Nov 2010
Nacelle time. These babies took siginifcant time to complete with planking over formers... Cooling air inlets were made from solid balsa.
Old Apr 01, 2015, 09:14 AM
Joined Nov 2010
And this is were I made my first huge mistake that drove me crazy nearly a year later....Oouch. Can anyone guess from the pics already? To be continued..
Old Apr 01, 2015, 09:34 AM
Sopwith Mike is online now
Find More Posts by Sopwith Mike
Slip the surly bonds...
Sopwith Mike's Avatar
Christchurch,England
Joined Aug 2004
You didn't build in the wiring? I nearly said "you put the motors on back to front"
Sopwith Mike is online now Find More Posts by Sopwith Mike
Old Apr 01, 2015, 10:21 AM
jhspring is online now
Find More Posts by jhspring
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
Nope, I can see the connectors in the wing end panel. Gear looks great too. In fact the whole model is very neatly done.
The mains are proud of the wing, but the real one had bulged doors for the same reason, so that can't be it. Hmmm.
Jeff
jhspring is online now Find More Posts by jhspring
Old Apr 01, 2015, 12:36 PM
Joined Nov 2010
Haha, good guesses but more subtile. All wiring is included as well as 4x flap servo.
The plans I had didn't show CG (how mad is this...) and second I never built a plane with such a swept back wing. I was not aware of the fact the CG sits far rear on such wings. I installed my main gear with so much enthusiasm that the plane could not stand on gear after completion.
Much later I used two computer programs to calculate the CG. An american tool and a german tool. Both agreed on the same CG (awesome) but after balancing everything correctly the nose gear was in air .
This set me back for weeks...The whole maingear plywood frame had to be dremeled out. The wheel base had to be filled with foam partially, balsa and glass and everthing had to be installed back again as far back as ever possible.
Lesson learned for life.
Old Apr 01, 2015, 12:43 PM
Joined Nov 2010
The nose gear story. Well, this had to be thought over carefully as well. Space was limited as usual and it retracts forward.
How to set up a design of servo control if you don't have much room in your nose? I didn't like pull-pull-wires at all. These are not reliable and will get caught anywhere.
Ok - these were my ideas: The steering servo sits rearwards and is connected to 2x carbon tubes using ball links. The nose gear leg has a little alloy bracket where 2x carbon fiber wires connect. The length of the tubes is set up correctly when they hit the nose gear leg when gear is down. The wires slide within the tubes. Doing so I have a nice push-push connection. When leg is down the servo can turn free (carbon fiber tubes move free over carbon fiber wires).
Works flawless and reliable.
Old Apr 01, 2015, 12:47 PM
Joined Aug 2004
I like that - very neat.
Joined Nov 2010
The wing saddle needs not much explaination. Just stay smart and cut nicely. You don't need any heavy sanding steps here.
Old Apr 01, 2015, 12:56 PM
Joined Nov 2010
Sadly I was to lazy to take more pictures in those days. I am still a youngster and time matters. We make a huge step here and take it out for a close look and a full system test. Test of the pneumatic gears. Testing and adjusting all six flaps. I believe 2 years had passed by. Flying pictures and info on the power system to follow shortly.
Not to forget my second and third big mistake I made.
-Jens
Old Apr 02, 2015, 09:30 AM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
No wonder there's a balsa shortage!
Nice work.
Re cg/ gear placement....Generally, on a trike gear, draw a line 15-20 rearward from cg at wing, and where it contacts the ground is where you place your rear gear.
mrittinger is offline Find More Posts by mrittinger
Old Apr 02, 2015, 11:08 AM
stacker is offline
Find More Posts by stacker
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Looks super!!
--Stacker
stacker is offline Find More Posts by stacker
Build Log Peacemaker- "Britplan" Build Off - 1st January 2013 to 30th June 2013 JohnAV8R Vintage & Old-Timer Designs 74 Nov 24, 2015 06:58 AM
Discussion CP Heli: General "lift off" stick position? Vodarac Electric Heli Talk 12 Feb 12, 2015 03:32 PM
Discussion Blade MCPX -- how to get lift-off with with middle left stick. lawlist Beginner Training Area (Heli-Electric) 33 Nov 14, 2011 06:10 PM
Help! SYMA S018 veers off course from lift off Animator Electric Heli Talk 0 Jan 07, 2011 02:59 AM
Help! problem with lift off from lama v3 *UPDATE* dedafmonteur Coaxial Helicopters 11 Feb 12, 2008 05:06 AM
