Old Nov 29, 2015, 02:55 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Originally Posted by OlliW View Post
bill glover was so kind to work himself through the above data recording procedure, and transfered the files to me, yielding the motor plots below
I can't yet tell too much as regards conclusions since there are still quite too few comparison experiments
one thing however strike me, namely that the yaw motor seems to be surprisingly smooth ...
bill: what had been your battery voltage, and the Vmax values for the three axes?
Supply was around 11.5V (partially discharged 3S 8000 mAh) and vmax values were:
pitch - 50
roll - 70
yaw - 200
I still need to do a little more tuning.
The pitch and roll 2206s are Turnigy from Hobby King:
http://www.hobbyking.com/hobbyking/s...strSearch=2206
The 2804 on yaw is the one from the GoodLuckBuy GoPro 3D gimbal. I think this now comes with these motors on all axes but my early one had 2208s on pitch and roll instead.
Bill Glover is offline Find More Posts by Bill Glover
Old Nov 30, 2015, 06:25 AM
DJI27 is offline
Find More Posts by DJI27
Open the bay doors... HAL
DJI27's Avatar
United States, OH, Mentor
Joined Jun 2013
just in case it might be of interest:
I've started collecting info on available motors suitable for Mobius gimbals, http://www.olliw.eu/2015/mini-micro-gimbal-motors/
Helpful list.... thank you
I've more or less selected either the AX 2206 140KV or the Walkera WK-WS-22-001 for my gimbal.
Is there any particular rationale behind choosing different motors for each axis or can all 3 axes have the same motor?
DJI27 is offline Find More Posts by DJI27
Old Nov 30, 2015, 10:43 AM
Joined Nov 2000
You generally need more power on the yaw axis, so the pitch & roll motors can be smaller (saving some weight).
Old Nov 30, 2015, 10:44 AM
robca is offline
Find More Posts by robca
United States, WA, Kirkland
Joined Sep 2013
Saving weight would be one. The motors closer to the Mobius need the least torque (since the amount of weight to stabilize is small), the yaw motor is the one that needs to be the strongest. Also, the lighter the motors closer to the Mobius, the smaller you need the yaw motor to be.
2206 motors are really big for a Mobius, something much smaller would suffice
If you use 2206 motors that weight 40g, probably weight is not your main concern. But a 2206 as a yaw motor having to stabilize more than 120g might be pushed hard (4 2206 motors plus the Mobius, plus the mechanical components). That same 2206 with much lighter motors might work. Needless to say, heavier motors mean heavier arms, to avoid flex and vibrations... so weight increases rather fast when you start using 2206 motors.
Which is not to say it won't work, there are plenty of 2D GoPro gimbals using 2206, so roll and pitch will be ok. Yaw might be the one to keep an eye on
robca is offline Find More Posts by robca
Old Dec 01, 2015, 10:17 AM
DJI27 is offline
DJI27's Avatar
Joined Jun 2013
Yeah ... one of my goals is to keep gimbal weight as low as possible while still providing enough strength & rigidity.
What you've said is kind of redirecting my thinking though....
Old Dec 01, 2015, 10:32 AM
DJI27 is offline
DJI27's Avatar
Joined Jun 2013
Since weight is a top consideration for me, it looks like I need to learn a lot more about motors.... I'm beginning to see how everything abot the Mobius complicates what should be a rather straight forward gimbal design.
Old Dec 10, 2015, 10:20 PM
snoopy3440 is offline
Find More Posts by snoopy3440
Keep Flying
Swedesboro NJ
Joined May 2008
Deleted Wrong Thread sorry
snoopy3440 is offline Find More Posts by snoopy3440
Old Dec 29, 2015, 10:54 AM
SilbernerSurfer is offline
Find More Posts by SilbernerSurfer
I dont like crashes!
Germany, BY, M
Joined Jul 2013
Looks good, 113€, 200g weight of Mobius included, 3 axis, rail for easy remove.
http://www.hobbyking.com/hobbyking/s...ed_Gimbal.html
SilbernerSurfer is offline Find More Posts by SilbernerSurfer
Old Dec 29, 2015, 05:56 PM
RCWASP is offline
Find More Posts by RCWASP
Learning to fly.......FAST!!
RCWASP's Avatar
Australia, VIC, Bentleigh East
Joined Mar 2013
Originally Posted by SilbernerSurfer View Post
Looks good, 113, 200g Mobius included, 3 axis, rail for easy remove.
Looks interesting.
RCWASP is offline Find More Posts by RCWASP
Old Dec 30, 2015, 01:42 AM
oxygen is offline
Find More Posts by oxygen
Flight cadet
The Netherlands, OV, Enschede
Joined Jul 2012
Camera not included is depicted on the first image
oxygen is offline Find More Posts by oxygen
Old Dec 30, 2015, 05:53 AM
Joined Nov 2000
Hard to be sure but it looks like it uses the suspension spheres in tension rather than compression, which isn't ideal.
Old Dec 30, 2015, 09:22 AM
Germany, BY, M
Joined Jul 2013
I mean, 200g, weight of Mobius included!
Old Jan 04, 2016, 07:38 AM
Germany, BY, M
Joined Jul 2013
Looks good, 113, 200g weight of Mobius included, 3 axis, rail for easy remove.
Forgotten to mention, different motors. Maybe this is one reason for the light weight.
Copy/Paste from HK:
X,Y axis: 18 series motors
Z axis: 22 series motor
Old Mar 05, 2016, 02:22 PM
Eagle1980 is offline
Find More Posts by Eagle1980
Joined Feb 2014
Hi Guys,
Frank told me I should show my Gimbal here in this topic, so I will do.
Maybe you have saw meanwhile our project site? ... www.open-diy-projects.com
If not, some words, we founded a Open Source Project site for sharing and support projects for round about copters and Cameragimbals. It is 100% noncommercial, no banner promotion no profit, just hobby and fun.
last Year we finished the EagleEi Mobius 3 axis Gimbal, few month later it grows up to a 360 3axis, few month later the Xiaomi Gimbal was born and now we finished the RunCam2 Gimbal too.
Here the Mobius Gimbal testing with Live out:
EagleEi 360° Mobius Gimbal, incl. AV-Out (0 min 34 sec)
and here the new RunCam2 in Hand testing:
RunCam2 Gimbal, EagleEi Open-DIY-projects (0 min 32 sec)
If you like this projects, so please feel free and and visit us, maybe you can create some of our projects too:
http://open-diy-projects.com
Eagle1980 is offline Find More Posts by Eagle1980
Old Mar 09, 2016, 02:51 AM
DucknDive is offline
Find More Posts by DucknDive
Spotty Herbert
United Kingdom
Joined Oct 2012
Love those gimbals eagleei!
DucknDive is offline Find More Posts by DucknDive
Discussion Mobius Action Cam $71 shipped tomcor Hot Online Deals 26 May 12, 2014 04:32 AM
Help! HOBBYKING 5.8GHZ 200mW to MOBIUS ACTION CAM CONNECTION dhonwyn Aerial Photography 3 Feb 02, 2014 09:10 PM
Discussion Mobius Action Cam wmw Aerial Photography 4 Dec 19, 2013 02:54 PM
Discussion Mobius Action Cam - live preview on external device Firebird_PL Aerial Photography 10 Dec 05, 2013 01:52 PM
