Old Apr 01, 2002, 09:02 PM
theKAT is offline
Find More Posts by theKAT
theKAT's Avatar
Bloomington, IL (Hell's Cornfield)
Joined Dec 2001
M100 alternatives rehash
Could someone fill me in on possible alternatives for an m100? Something in a similar power/weight ratio.
I remember reading there are some similar motors available from a place called Goldmine Electronics. For some reason, I'm unable to do a search here tonight.
-How do the Goldmine motors compare?
-Can you fit them directly into the m-100 gearbox?
-How do you go about successfully getting the pinion gear off the old and on the new motor?
- Other alternatives?
I ordered a couple m100 replacement motors over a week ago last thursday (web order) from Jet-Set and they just today informed me that it would be another 3-4 weeks to get the motors in (without the gears and prop). I'll remember to phone in the order next time. For such a popular item, they sure don't make very many. I guess I'll have to either keep swapping my one motor between models or pony up the extra $17.50 per unit. Seemed like a good plan at the time....
TigerShark? Sent two e-mails and never heard a thing back from BMW, I don't even know if his motor is what I am looking for.
The IPSD isn't available yet from any source I can find.
theKAT is offline Find More Posts by theKAT
Old Apr 01, 2002, 09:18 PM
Arizona Chuck is offline
Find More Posts by Arizona Chuck
Old Desert Rat
Arizona Chuck's Avatar
Rimrock AZ. USA
Joined Mar 2000
Check out the GWS C100 from AeroMicro
http://www.aeromicro.com/
I use both, I favor the M100 but the C100 is real close and half the cost.
Arizona Chuck is offline Find More Posts by Arizona Chuck
Old Apr 01, 2002, 10:41 PM
Bleriot is offline
Find More Posts by Bleriot
Bleriot's Avatar
Joined May 2000
Hi Kat Well sorry but I decided the TS is too goofy to sell as an assembled unit and I was unable to keep up with all the questions, requests for 1/2 price and all the other stuff as well. I was losing money with every sale anyway so I stopped. Stupid idea anyway.....However, I am pleased to tell you that the TS motor will adapt into the M-100 gb by using either a pair of 2mm screws or better yet.....an o-ring. I'll sell the motors only for $5. You'll need to send me the old motor so I can swap pinions over if you're interested. There was ALWAYS a problem with spare M-100 motors, with jetset retaining exclusive availability, or lack thereof. Best Regards
Bleriot is offline Find More Posts by Bleriot
Old Apr 02, 2002, 08:30 AM
theKAT is offline
theKAT's Avatar
Joined Dec 2001
Chuck,
What gear/prop/battery setup are you using? What models are you flying them on?
Thought about 280 motors, but they seem kind of heavy compared to the Johnson. I even have a spare one of those laying in my shop.
Thanks all for the info.
Good, Fast, Cheap (pick any two)....
Old Apr 02, 2002, 08:17 PM
theKAT is offline
theKAT's Avatar
Joined Dec 2001
Ah, Bleriot lives...
This may seem like a silly question at this point, but what exactly is you motor like. I've been trying to get at some general info with my e-mails to you. Where does it fall power and weight wise with what's commonly available? What props and batteries are recommended? Thanks.
Karl
Old Apr 03, 2002, 06:17 AM
Old Desert Rat
Rimrock AZ. USA
Joined Mar 2000
theKAT
I have the "1" "2" and "A". Mostly use the recommended prop, depending on what plane I'm using them on. I fly everything with the 8/300 NiMH bateries from Radical RC and try to keep the amps around 3 to 3 1/2.
Old Apr 03, 2002, 08:34 AM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
I think what you're looking for is the Johnson 4046 from Electronic Goldmine. I think they are the same size as the motor in the M100, but tend to like one cell fewer. Another alternative setup is the MG-1 or EMPS-1 based on this motor, a little cruder than the M100, but pretty close in power. You can also check on the tests of the Orion Elite, or if you can stand a bit more weight, a Speed 300 has more guts.
Sam
Megowcoupe is offline Find More Posts by Megowcoupe
Old Apr 03, 2002, 09:47 AM
Bleriot is offline
Bleriot's Avatar
Joined May 2000
Hi Kat 180 long can motor size. will fit m100 gb with o-ring adaptor 7-8 cells nimh 7 nicad 300 mah. about 4A 2 ratios.4:1 6:1, ballraced and gws shaft, bearing tube is attached to motor via groovy ..er grooved US Southern Basswood carrier with adhesives. Bearing tubes locally available and cheap. Same with motor. I have also some of the 4046 megocoupe mentioned, I can beat the price but they are amp hungry. of which I can send you a couple free if you order a TS. Hey....honey..I shrunk the MiniPleaser Best Regards
