Old May 24, 2015, 09:25 PM
TheDonski is offline
Find More Posts by TheDonski
Oakridge, Oregon
Joined Jul 2004
Question
Twitching Motor
I have a QAV250 with 2208's and 18amp Kiss Escs. I crashed last week by throwing a prop. When I tried to statup the motors I only get 3 that power up and one that twitches. I checked all of the solder joints on the twitching KISS ESC and motor wires, but nothing looked broken. Is there a way to determine if the KISS ESC or the Lumineer Motor is not bad without desoldering the ESC and motor and checking with another?
TheDonski is offline Find More Posts by TheDonski
Old May 24, 2015, 10:18 PM
Mad Vampy is offline
Find More Posts by Mad Vampy
Joined May 2015
Unless you know the amperage draw and how to read the output of a brushless ESC not really. Only by trying swapping out the motor and if the motor (known good one) does it again then most likely it's the ESC. Have you tried switching the ESC to a different motor out port on the controller to see if it stops?
Mad Vampy is offline Find More Posts by Mad Vampy
Old May 24, 2015, 10:22 PM
Oakridge, Oregon
Joined Jul 2004
That is a great idea to switch the ESC to another port to see if it still responds. Thanks!
Old May 25, 2015, 08:30 AM
waltr is offline
Find More Posts by waltr
Team WarpSquad
United States, PA, Doylestown
Joined Jan 2014
You need to try a different motor then a different ESC.
I Highly recommend using a Current Limiter so you do not burn up a motor (has happened to me).
http://www.rcgroups.com/forums/showthread.php?t=2327875
waltr is offline Find More Posts by waltr
Old May 25, 2015, 11:24 PM
Oakridge, Oregon
Joined Jul 2004
I looked in more detail at my esc and motor and on my Kiss ESCs the power indicator light (blue) is on when powered up (Good sign). The motor however is not turning as freely as all of the other working motors, so that would be my guess. I will try soldering up a good motor to see if the esc might be the issue or switch escs to see if that does it. I will also switch a lead to see too.
Thanks again!
Help! Twitchy quad, only one motor twitches, tryed PID adjustment and multiwii LPF settings Power Max Scratchbuilt Multirotors 16 Mar 25, 2015 05:18 PM
Discussion Sunnysky Motors Twitching/Sputtering synergy03 Multirotor Electronics 2 Jan 21, 2015 09:17 PM
Discussion Motors simultaneously twitching when APM armed and motors spinning Pyr8 Multirotor Electronics 0 Aug 06, 2014 03:20 PM
Discussion twitching motor- HELP eculuke Scratchbuilt Multirotors 7 Mar 31, 2014 11:11 AM
Discussion Help - Twitching motor from ESC eculuke Multirotor Electronics 2 Mar 31, 2014 08:57 AM
