Old Sep 05, 2014, 10:06 AM
kenb is offline
Find More Posts by kenb
United States, MI, Portage
Joined Nov 2003
Build Log
New Xplorer2 F5J ALES
Hi
I am Ken Bates LSF 604 Level V and a past NATS champ in LMR and ALES. Ihave been Soaring since around 1974. I fly a Xplorer2 in TD, and have after a year of learning, got it set up where it realy performs for me (Radio change helped a lot). For this year I realy wanted a Xplorer2 F5j but the budget and a late decision to sell some other airplanes left me flying my "stormy" .Its a good machine but a bit heavy and fast for light air.
So now I am excited to build and fly this new machine, Talking to Alex at SUSA I found that the explorer f5j had some updates and has been "Polished".Yesterday Fedex del
ivered that big box..... !!
Since I don't often get new sailplanes I am going to savor the build, not rush!
Ken
kenb is offline Find More Posts by kenb
Old Sep 05, 2014, 11:30 AM
dutchsoarer is offline
Find More Posts by dutchsoarer
Joined Oct 2006
Nice, congratulations
Can you please post the weight of the horizontal stab?
Old style is about 50 gr. Foam stab (40 gr) makes is possible to use a 80 gr. motor and keep sp around 118 mm.
Thank you in advance!
Jan
dutchsoarer is offline Find More Posts by dutchsoarer
Old Sep 05, 2014, 11:39 AM
Bro is offline
Bro
Find More Posts by Bro
Bro
Bro's Avatar
Southern California
Joined Feb 2003
Xplorer F5J
Ken,
With the new tail/fuse config, shoot for a CG around 130 for starters!
I think you will find that you have "the king" of F5J model offerings>>>>
Best,
Bob
Bro is offline Find More Posts by Bro
Site Sponsor
Latest blog entry: 2015
Old Sep 05, 2014, 11:55 AM
kenb is offline
Joined Nov 2003
Thanks Bob
Fin and Rudder 30 gm
Fuse Pushrods and firewall 170 gm
Stab 50 gm
Right tip 204 gm
Left tip 204 gm (nice!)
Center 414 gm
Joiners 20 gm
all up (forgot wing hatch covers but not cut out yet)
1092 gm 38.5 oz
Old Sep 05, 2014, 12:15 PM
kenb is offline
Joined Nov 2003
Ok quick recheck on stab weight. Shop was hot and humid yesterday
cool and dry today.
stab 48 gm
fin and rudder 28 gm
center section 416 gm
so I guess that my scale is only so-so!
Remeber that this stab has control horn already
there is no belcrank! and no pivot or drive rods
Old Sep 05, 2014, 02:21 PM
Airman74 is offline
Find More Posts by Airman74
E sailplane thermal hack
USA, CA, Chico
Joined Feb 2011
someday,,, might Havta get me one of these,, after I save up a few bucks
Airman74 is offline Find More Posts by Airman74
Old Sep 05, 2014, 03:43 PM
Tuomo is offline
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
That new tail is pain to put together and take apart but it flies ah so nice....
Stab weight is not anymore an issue since this Xplorer version likes to fly with rearward CG. 130mm sounds radical but it is not.
Tuomo is offline Find More Posts by Tuomo
kenb is offline
Joined Nov 2003
Jim
There is no tray, I would prefer to make my own as final ballance is developed
The tray design should add some "shear" stifness to the nose. (gotta love those crabbed landings)
Old Sep 06, 2014, 07:14 AM
Joined Oct 2006
@ Ken
Thanks for the information about the weight. Sounds like in comparison to the glas version they managed to save some weight again (1165 empty)
Very interesting information followed about cg further back due to the new layout of the tail ......130 instead of 118 .....
Originally Posted by kenb View Post
Jim
Isn't the tray made from ST supplied. I never used it because of poor fit and made a simple one with elevator servo flat in servo-rahmen. Receiver under the servo to create room for easy acces to ballast. Not necessary now because you can use a smaller servo.
Jan
Old Sep 06, 2014, 08:11 AM
kenb is offline
Joined Nov 2003
Well, after carying around a one piece V-tail this looks easy. Experience will tell
Old Sep 06, 2014, 08:23 AM
kenb is offline
Joined Nov 2003
Last night as I was test fitting the motor, an issue appeared . The P29 gearbox bolts
will overlap the outer "lip" of the fuselage. I could cut out sections of the flange
or....
Old Sep 06, 2014, 08:28 AM
kenb is offline
Joined Nov 2003
After two tries today the photo caption refuse to apear, so
These are views of the fuselage carbon ring reenforcing the nose and the lip.
the modified motor mount with a layer added that is the thickness of the fuselage lip, the fit and clearances of mount and spinner, and finaly the firewal test fit with gluing clam in place.
Old Sep 06, 2014, 09:25 AM
jaizon is offline
Find More Posts by jaizon
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
I went with the Powerline 1025. Not a single issue. Gets to 200m in 20 sec! I love this plane for light air. Just amazing. I'm all up just around 60 oz., but I tend to build heavy anyway. You ABSOLUTELY cannot dork this plane. Trust me on that. I have no idea where my cg is at the moment but I love the way it flies and that's good enough for me. Not sure what the "changes" are in the newer models of this plane.
jaizon is offline Find More Posts by jaizon
Old Sep 06, 2014, 09:28 AM
jaizon is offline
jaizon's Avatar
USA, NH
Joined Mar 2008
I went with the Powerline 1025. Not a single issue. Gets to 200m in 20 sec! I love this plane for light air. Just amazing. I'm all up just around 60 oz., but I tend to build heavy anyway. You ABSOLUTELY cannot dork this plane. Trust me on that. I have no idea where my cg is at the moment but I love the way it flies and that's good enough for me. An articulated stab. Now that is different.
Old Sep 06, 2014, 10:10 PM
kenb is offline
Joined Nov 2003
Not much today, Grand kids soccer, sailing (weather is about to turn in michigan)
and chores.
Epoxied in the motor mount, and verified the wiring in my TD Xplorer2
I want to be able to bolt on that wing.
I see the descriptions are not apearing even though they are saved.
The first is the Fuselage solvent cleand and masked and the clamp is ready
Second, Epoxied and clamped (Gflex)
The third, verifying the wiring on the TD wing.
Discussion ALES, F5J and F5J Lite dharban Electric Competition Soaring-F5J/ALES/e-Soaring 137 Jan 22, 2015 09:26 AM
Discussion New model Xplorer2 - F5j Mitch-air Electric Competition Soaring-F5J/ALES/e-Soaring 47 Apr 18, 2014 06:34 PM
Sold Geared Hacker ALES/F5J motor Lenny970 Aircraft - Sailplanes (FS/W) 2 Dec 09, 2013 08:38 AM
Wanted looking for f5J/ALES competitive plane wheresup Aircraft - Sailplanes (FS/W) 2 Oct 27, 2013 07:44 AM
Discussion FAI F5J , ALES and eSOARING ZOOM TOOL Painter S Electric Competition Soaring-F5J/ALES/e-Soaring 10 Oct 13, 2013 07:10 AM
