Old May 05, 2014, 12:38 AM
Chopper1 is offline
Find More Posts by Chopper1
Chopper1's Avatar
USA, CA, Millbrae
Joined Oct 2006
problem with jetcat p60se
Please help.
We have some problem with our jetcat p60se. The propane start is fine. The priming the fuel to the engine is fine but once we stop priming the fuel. The fuel slowly go back to the tank. Once the propane starts. The turbine e seems to pull fuel away from the fuel line. The fuel is going backward to the fuel tank and not the turbine.
Anyone know what might be the problem. The p60se is brand new.
Thanks for your help in advance.
Chopper1 is offline Find More Posts by Chopper1
Old May 06, 2014, 01:58 AM
Boomerang1 is offline
Find More Posts by Boomerang1
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
I have one of these engines & have no problems whatsoever, just started straight out of the box. Check how you have everything plugged into the ECU, the servo type lead connections are a bit confusing.
My ECU is the larger V6.0 unit.
With the side of the ECU with the assembly screws visible you can see 6 pins which stick out from the case marked on the ECU label - Airspeed/Propane. The gas solenoid plugs onto the lower pins with the brown wire to the right.
On the other end of the ECU the ECU label is marked Smoker/Fuel above 6 pins. The fuel solenoid plugs onto the lower pins with the brown wire to the right.
Directly to the right of those the label is marked Thr-Ch/Aux-Ch above another 6 pins. Your throttle lead from the receiver plugs onto the upper pins, signal wire to the left, positive wire in the middle & negative wire to the right.
Hope that's a help. John.
Boomerang1 is offline Find More Posts by Boomerang1
Old May 06, 2014, 06:00 AM
Dr Honda is offline
Find More Posts by Dr Honda
Dr Honda's Avatar
Pittsburgh Allegheny, Pennsylvania, United States
Joined May 2004
Sounds like you have a large air leak in one of the hoses, fittings, pump, or valves.
I would start by taking all the fittings/hoses apart... verify they are clean, and cut straight... and then reassemble.
Dr Honda is offline Find More Posts by Dr Honda
Old May 08, 2014, 08:39 PM
lashmett75 is offline
Find More Posts by lashmett75
Its a Condition not Addiction
lashmett75's Avatar
United States, CA, Sunnyvale
Joined Jul 2008
Found the pinched kero. Line behind the fuel tank. All good now
James
lashmett75 is offline Find More Posts by lashmett75
Old May 17, 2014, 01:43 AM
Chopper1 is offline
Chopper1's Avatar
USA, CA, Millbrae
Joined Oct 2006
thank you James
Cool Jetcat P20 Turbine Glider Flight with Greg Leigh ChuckTseeker Fuel Jet Talk 1 Oct 16, 2013 01:25 AM
Sold Jetcat P-20SX new in box from jetcat. lilrod3939 Aircraft - Fuel - Jets (FS/W) 2 Sep 21, 2013 12:28 PM
Wanted Jetcat P-70, Jetcat p-120 and Rabbit-100 Wanted. gapellegrini Aircraft - Fuel - Jets (FS/W) 2 Aug 20, 2013 12:58 PM
Discussion Need help with a Jetcat J Klenske Jet Turbines 2 Jul 04, 2006 09:47 PM
JetCat GSU Problem neTWork Fuel Jet Talk 1 Aug 31, 2005 12:19 PM
