Old May 01, 2013, 09:49 PM
XXBug85 is offline
Find More Posts by XXBug85
Pro Racing
XXBug85's Avatar
United States, CT, Hartford
Joined Apr 2013
Help!
Motor
I have a 19T Stock motor, The lowest I can go is a 16T Stock motor as specified on my ESC, I get about 30 mph, How much faster will it increase with a Stock 16T motor?
XXBug85 is offline Find More Posts by XXBug85
Old May 02, 2013, 12:15 AM
SoloProFan is online now
Find More Posts by SoloProFan
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Depends entirely on the motor. Also, the turn limit on the ESC is not a hard limit. Depending on the type of brushes used, the magnets used in the motor can, and the gauge of the wire that is used to wind the armature, can totally affect the performance of the motor. Then you have the timing adjustment on the endbell, if available, and the number of winds, like single, double, triple, etc... All affect the motor's "character" like max RPM, torque and amp draw.
Turn limit is only a general indication, better look at the A that the ESC can sustain, and what it can survive peak power. Then compare to the motor's amp draw.
If you want a more specific answer, make it less general, what brand and type ESC, what brand and type 19T and 12T motor are you referring to. We can then dive into the specs, and make a better calculation/prediction on performance, with less "wild guess" involved.
SoloProFan is online now Find More Posts by SoloProFan
Old May 02, 2013, 06:24 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Going to a lower turn motor will require a gearing change, and you'll lose run time pretty drastically if you go down to a 12T-14T motor.
wparsons is offline Find More Posts by wparsons
Old May 02, 2013, 09:55 PM
XXBug85 is offline
Pro Racing
XXBug85's Avatar
Joined Apr 2013
Thanks!
Old May 03, 2013, 12:37 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
A lower turn motor will generally have more power, and more power means the battery gets drained faster. Btw, do you already use lipos? If you are still using NiMh or NiCad, moving over to 2S lipo will give about a 10 to 15% increase in top speed and better acceleration. Beware that if the ESC doesn't have lipo over-discharge detection, you will need a seperate lipo saver to monitor the battery.
Old May 03, 2013, 09:41 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Going to a lower turn motor will reduce run time, even with a proper gearing change. Going to 16T won't lose as much as going to 12T, but it'll still be noticeable.
If you want more speed, your best option is to upgrade to a brushless motor/esc and 2s lipo packs. You'll get more speed, and since lipo packs are much higher capacity (5000mah vs ~2000mah) you'll get a lot more run time too.
Old May 03, 2013, 01:46 PM
XXBug85 is offline
Pro Racing
XXBug85's Avatar
Joined Apr 2013
Thanks!
Old May 03, 2013, 02:00 PM
XXBug85 is offline
Pro Racing
XXBug85's Avatar
Joined Apr 2013
Thanks!
Old May 03, 2013, 03:29 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You should really find some general FAQ type information, A LOT of your questions would be answered by them.
Don't even bother comparing number of turns from brushed to brushless, it's not a direct conversion so it's just a waste of time. A 17.5T brushless is comparable in RPM to a 27T brushed, but a lot more efficient so you'll get less heat and more run time with the same rough speed.
2s Lipo is a different type of battery. Lipo is short for lithium polymer, and 2s means it's two cells in series (3.7v/cell, so 7.4v total). They're lighter and deliver way more power than nimh packs, but you'll need a lipo compatible charger as well.
If you're happy with the performance, just enjoy it as is. If you want to go faster it can be an expensive venture.
Old May 03, 2013, 06:07 PM
XXBug85 is offline
Pro Racing
XXBug85's Avatar
Joined Apr 2013
Thanks!
Old May 04, 2013, 01:07 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
A 12T motor will most likely be faster than a 19T, but it's hard to predict how much faster, which was your initial question.
If you are happy with the current speed (I sure would be happy with 30 mph, it's pretty fast for an offroad vehicle) you could either keep running with the current motor and batteries, or already invest in some lipos. 2000 mah is pretty low for a lipo, I would suggest to get at least a 4000 mAh one. The extra capacity will come in handy, especially once you convert the car to brushless.
Old May 05, 2013, 07:09 PM
XXBug85 is offline
Pro Racing
XXBug85's Avatar
Joined Apr 2013
Thanks!
Old May 06, 2013, 11:24 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Lower turns will always be faster, but will require more power from the battery so they'll get hotter and run time will be lower. Everything is a balance.
Old May 06, 2013, 07:31 PM
XXBug85 is offline
Pro Racing
XXBug85's Avatar
Joined Apr 2013
Thanks!
Old May 07, 2013, 12:03 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
If everything else stays the same, so the number of turns is identical, the wire gauge is identical, and the timing of the endbell in regard to the commutator stays identical this holds for brushed motors. But if you alter one or more of these things, aka compare a 21 turn advanced timing motor to a 19 turn neutral timing motor for instance, I don't know which one will be faster. In that case the situation gets blurred and you can only find out what is faster by testing. If you want to experiment with brushed motors, get one with an adjustable end bell, as you can then alter the character of the motor between slower and more economical and faster but more power consuming and running hotter.
For Sale align 430l 3550kv bl motor castle creations 45a esc scorpion 2221-6 motor motoman40 Aircraft - Electric - Helis (FS/W) 4 Sep 01, 2013 11:27 AM
Question Remove motor wires from motor fixing pipe Tom Z Mini Multirotors 3 Mar 30, 2013 08:25 AM
Sold Motors! Motors! Motors! + Quattro 20A ESC! Maseo54 Aircraft - Electric - Multirotor (FS/W) 5 Mar 20, 2013 10:58 PM
Sold 11 Cox Motors 7 Motors for Repair or Parts and 4 Motors for Parts CADILLAC200 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 27, 2013 03:38 PM
