Old Apr 27, 2013, 06:01 PM
Dale Young is offline
Find More Posts by Dale Young
Joined Dec 2004
motor (kv) question
Sorry for the dumb question, ....but here goes.
I have acquired a used motor from a friend. He doesnt remember what kv the motor was. He just remembers that he bought it from Grayson hobbies (I have tried for months and cannot contact) .
I DO know that the motor is a 35-30-08
How can I determine the kv? Thanks in advance!!!
Dale Young is offline Find More Posts by Dale Young
Old Apr 27, 2013, 07:47 PM
whitecrest is offline
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Borrow a tach and mark the motor bell with tape or a sharpie to allow a reading to be taken. Measure the unloaded (no prop) RPM at full throttle. Kv is then measured RPM/Esc input voltage. For example, 10000 RPM / 10 volts = 1000Kv. This will be close enough for government work.
whitecrest is offline Find More Posts by whitecrest
Old Apr 27, 2013, 08:07 PM
kavic5150 is offline
Find More Posts by kavic5150
Unregistered Nightflyer
kavic5150's Avatar
Joined Jul 2009
Can you post a pic? Maybe someone has seen it or one of us can find a match using google images.
kavic5150 is offline Find More Posts by kavic5150
Old Apr 27, 2013, 08:55 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I can't place any Grayson motor of that size, but if it is about 75g 3530-8T, then it is probably about 1250-1300Kv...(an HXT 3530-10 I tested was ~1085Kv)... but wait a Turnigy 3530-14T came out at 1450Kv... so maybe yours is closer to 2000Kv???
Aha.. An 80g EMP 3530-08... which is an HXT motor anyway.... is said to be 1700Kv.
http://mayor-hobbies.net/RC/pages/info/emp_35-30.html
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Apr 27, 2013, 08:56 PM
Joined Dec 2004
Thanks for the replies guys!! At the moment, I'm on a business trip and I'm not close to it. But I'll try posting a pic when I am. Thats a good idea!!
Old Apr 27, 2013, 08:58 PM
Joined Dec 2004
Whitecrest, That sounds like a great idea, but will running it unloaded, hurt it?
Old Apr 27, 2013, 09:59 PM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
No. To be extra safe, use 2S or 3S to limit the maximum RPM and only run for a few seconds; long enough to measure the RPM. It will draw very little current running unloaded.
Old Apr 27, 2013, 10:39 PM
Joined Dec 2004
Thanks!!
Old Apr 27, 2013, 10:48 PM
Joined Dec 2004
Dr. Kiwi. That particular motor seems to be alot smaller( or at least alot shorter) than the one I got. It is golden ended, with a silver can. It also had a sticker that said Grayson hobbies 35-30-08 on the can.
Old Apr 28, 2013, 01:28 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
What is the diameter/length/weight of your motor?.. maybe you have one with a 35mm x 30mm stator (not 28x14 stator and 35x30 external dimensions that I was thinking of).
Old Apr 28, 2013, 05:25 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
A 35 x 30 stator would produce a motor about 7mm more in O.D. or about a 42mm O.D. on the magnet housing. The overall length is harder to predict but from the back of the baseplate to the top of the dome (not to the top of a raised boss where the shaft emerges) would be 10-12mm or so more than the 30mm stator height. So it might have been called something like a 42xx. or something like that.
Getting a weight on the motor and a raw Kv would resolve all the mysteries as far as using it, then it just a case of trying some props that need an input power of about triple the weight.
If you can't get a weight or an RPM your toy chest really need some help!
But you can put a prop on it and see if it gets hot and blows hard. If it gets hot try a smaller prop, if it does not, try a larger one. When the base plate gets warm to the touch you are in the ball park for using it.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Apr 28, 2013, 07:00 PM
Joined Dec 2004
I'll be back home tuesday, and will get specs then. Thanks guys!!!
Found High KV motor for push prop jet mrbobbio Aircraft - Electric - Power Systems (FS/W) 3 Apr 01, 2013 09:16 AM
Sold 4X Tiger Motors MT-2208-18 1100 KV AlienQuads Aircraft - Electric - Multirotor (FS/W) 3 Mar 30, 2013 03:41 PM
Discussion Question about the Brushless 2226/2300 KV Easysky motor question (dolphin/cessna) twincobra Micro Ready-to-Fly 0 Feb 11, 2013 12:49 AM
Question KV power question ironace Electric Plane Talk 12 Feb 06, 2013 09:49 PM
Discussion Low kv motors vrs high kv motors in windy conditions crcr Multirotor Talk 6 Jan 10, 2013 01:34 PM
