Old May 14, 2013, 08:36 AM
Wannabe B-26 pilot!
Matt Halton's Avatar
Southwold, Suffolk, UK.
Joined Nov 2002
SC200 SONY 600VTL,EZOSD,Wiring to FS 250mw Vtx issues, please help!
Good afternoon all.
I wonder if some kind sould out there can help me with my predicament...
I have built a Y6 with Naza M, and GPS. I also have just purchased a set of Attitude SD's, and am having issues with the wiring to the vtx (FS 250mw) EZOSD,/current sensor.
My camera is a SecurityCamera2000 Sony Super HAD CCD 600TVL, which has a 12v input, the FS Vtx is only 5v.
I have attached some photos, so hope you can see what I'm using. I have another lead included with the FS kit, with a plug, cable, and bare ends (see pic)
Can anyone please explain how I go about wiring it, the EZBUS cable plugs in ok, but the video out has just 2 wires coloured orange (video) and white (audio). The 250mw Vtx has 3 wires on the plug going out to the camera, Yellow (video in) Black (ground) Red (5v)
I can tap 12v from my PDB, but how to wire?
I have a cable from my EZ current sensor, it has a jst plug with a 3s balance socket, do I need, or can I use this? My 250 mw Vtx has a red/black wire to power from a 2s or 3s box junction too. What should I use, and can anybody produce a simple diagram for me please?
Matt (internet searches found nothing BTW)
Sorry for my confusion, just don't want the old magic smoke.
Matt Halton is offline Find More Posts by Matt Halton
Old May 14, 2013, 09:11 AM
Wannabe B-26 pilot!
Joined Nov 2002
Fatshark lead/ Immersion EZOSD lead
I just removed the EZOSD lead, which is 2 plugs into EZOSD, to one plug for vtx, power etc.
This seems to be what I need to change, solder the FS plug to this other cable, but not sure of the wiring sequence as all colours are different.
Can anyone help with this, and tell me the correct plug orientation, ie, ok in this pic, or flip the plug over..
Old May 14, 2013, 09:24 AM
United States, TX, Longview
Joined Nov 2012
Well you know which wires are which. Look. Plug each original cable into the correct plug, and it tells you on the ezosd or transmitter. then. write it down and solder the correct cables together. The colors will prob be mismatched. Just get a piece of paper and draw it out so you can label the color wires without trying to figure everything out in your head. Does that make sense? Does this answer your question?
Wrice4 is offline Find More Posts by Wrice4
Latest blog entry: Youtube channel for flights:...
Old May 14, 2013, 09:51 AM
Wannabe B-26 pilot!
Joined Nov 2002
Thanks for your reply
Yes I do understand what you're saying, but the only problem I've found is that if you directly transpose each plug in it's correct orientation when into the ezosd ports, it shows wires # 3, are directly on top of each other, at the centre of the plugs, wires coloured orange and yellow need to go into the same port...Now I'm totally befuddled by this.
They are both video wires, one in (orange) and one out (yellow) I don't think I can splice them together can I?
Sorry to be a pain, but this makes no sense, any other alternatives?
Wanted Looking for a immersionRC 250mw or 600mw Vtx jasonyyd FPV/RPV - Equipment and Vehicles (FS/W) 5 May 09, 2013 02:31 AM
Discussion Please Help with EZosd Wiring only20gp Video Piloting (FPV/RPV) 2 Mar 23, 2013 08:34 AM
Discussion Please help with EZosd Mic Wiring only20gp DIY Electronics 0 Feb 20, 2013 06:13 AM
Sold Fatshark 250mw vtx rdarby777 FPV/RPV - Equipment and Vehicles (FS/W) 4 Nov 23, 2012 09:07 PM
Sold Iftron Yellow Jacket 5.8GHz Diversity Receiver, 2 patch antennas & 250mw vtx malcr001 FPV/RPV - Equipment and Vehicles (FS/W) 4 Aug 13, 2011 06:20 AM
