Old Nov 29, 2007, 10:30 PM
rwp
rwp
rwp's Avatar
Joined Nov 2003
Joss Stick
Anyone know the recommended CG for a Modeltech Joss Stick?
rwp is offline Find More Posts by rwp
Old Dec 01, 2007, 02:46 PM
Joined Feb 2006
33 percent of the wing cord from the leading edge will do.
glowplug47 is offline Find More Posts by glowplug47
Old Dec 01, 2007, 05:44 PM
Zor
Ontario,Canada
Joined Feb 2007
A second response to your query.
33% is good advice.
Keep in mind also that the center of pressure (lift) usually moves ahead (in the direction of travel) with increased angle of attack of the wing(s).
Season's Greetings
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Dec 02, 2007, 05:43 PM
United States
Joined Dec 2005
With a lot of planes you can start by balancing at
the main spar. That will get you close enough to fly it.
The go inverted , to test. Most perfer bal with a little
down to fly level, while inverted. Although balance
point preference may vary from pilot to pilot. To much down elevator
your nose heavy , no down you might be tail heavy. But some
like a neutral GC, level inverted flight with no elevator input
Dennis157 is offline Find More Posts by Dennis157
Old Dec 02, 2007, 11:45 PM
rwp
rwp
rwp's Avatar
Joined Nov 2003
Thanks for the replies. I generally would start with balance at the main spar but this plane has a balsa covered foam core wing so there is no main spar. It balanced close to the 33% area so I took it up this afternoon for a short flight and it seems ok but it was a little windy and getting late so I'll fine tune it later. I just installed a new OS 91 so in the process of breaking it in.
For Sale Joss Stick YS120 JR 622 - Used StrayDog Aircraft - Fuel - Airplanes (FS/W) 0 Mar 17, 2006 11:17 AM
FS: Model Tech JOSS STICK ARC w/ YS 120SF StrayDog Aircraft - Fuel - Airplanes (FS/W) 1 Oct 30, 2004 09:21 PM
