Old Nov 13, 2014, 08:49 AM
jaydav's Avatar
United States, NH, Lee
Joined Sep 2010
Originally Posted by mrtopgun99 View Post
Hi everyone, i need help with a setup, i got 2 new extra stryker F27B but, i also have lots of 2200 lipo 3s battery 30c with me, so i want buy motor, prop, esc and servos for speed but not the batteries, whats the best setup for a 3s-2200-30c
Eflite Series 6 motor --
F-27C Stryker Modified - Setup 2 (2700kv on 3s) (5 min 53 sec)
jaydav is offline Find More Posts by jaydav
Old Nov 13, 2014, 09:56 AM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Nice!
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Nov 13, 2014, 02:41 PM
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
How about dual 2200 3s, what esc and motor and prop.
Dual battery in parallel will just give you longer flight times. It won't make it any faster.
Dual battery in series will give you a 6s which will require a completely different power system than you have now. Something much lower in KV and still within the max amp draw limits of your packs. Since you'd be running a 2200 6s setup. So whatever the "C" rating is x 2.2 is your max amp rating for those packs.
I've never ran anything more than 3s in my Stryker so others will have to comment on a power system for you...
Edit, just noticed you posted the C rating. 30c 2200 batts can only handle 66 amps. In parallel, that would go up to 132 amps. In Series it's still 66 amps but twice the voltage.
cjbucher is offline Find More Posts by cjbucher
Old Nov 13, 2014, 03:08 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Always want a F-27C, but never got a chance to buy one... so I was excited when I recently got a chance to buy all the parts needed to build one for $40 total, pre-bundled from someone who was going to build one from spare parts but never got around to it.
I already had a Eflite 40 Amp slim ESC, and Himax 3000KV motor, so it did not take very long last night to put it all together.
Maidened it today and it flew great! Now I have a little wing I can throw in the car for 'wind days'.
tracknoob is online now Find More Posts by tracknoob
Old Nov 13, 2014, 03:23 PM
what ya mean i have to land?
DesMoines,Wa
Joined Feb 2008
what size prop is on that 3000?Nice looking but if running 4s or even 3s I would recommend a much higher rated esc than 40
oly_rcer is offline Find More Posts by oly_rcer
Old Nov 13, 2014, 03:57 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
It's pretty mild. Running a 4.5x4.5, and on the bench with a fully charged 3S 2200 40C, I was pushing 29A and 300-something watts, momentarily.
The Himax is noted for not being particular robust for over-wattage conditions, (max rated 275W), so I took it pretty easy during the maiden, but I figured that in the air, with prop unloaded, mostly less than full throttle, and with voltage coming down from inital full charge, that it would be pretty safe.
Sure enough, at five minutes I landed and had 55% of the battery left, motor was dead-cold, ESC warm, and battery barely over room-temp.
Old Nov 14, 2014, 07:30 PM
Just go with the flow
goflyhighrc's Avatar
Modesto, CA
Joined Nov 2006
Dx*
Would anyone know on a DX 8 howto put the elevons on a switch so they go up for launching and back down for normal flight.
gofly
goflyhighrc is online now Find More Posts by goflyhighrc
Old Nov 15, 2014, 03:31 AM
Arcteryxxx's Avatar
Joined Feb 2010
Simply set a gear->elevator mix. Activate by the gear switch.
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 11:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 08:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 09:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 09:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 01:34 PM
