Old Oct 25, 2014, 08:24 AM
Joined Dec 2010
mCPx Not Levelling / Very Sensitive During Flight
Hey guys, I come to you in time of need! My mCPx (v2, not BL) is driving me bananas. I am able to take off and the heli seems very stable when in the air, however as soon as I touch the right stick it veers wildly off and ultimately crashes.
There is a combination of two problems here - the heli seems to keep on tilting after moving the right stick rather than levelling out, and also the right stick is INCREDIBLY sensitive! My wee heli just rolls over in flight no matter what I do.
This all started after a rather nasty crash (probably over 100 flights in) and I've replaced so many parts now to no avail, as well as re-binded around 20 times. Any suggestions would be very much appreciated!
si_edgey is offline Find More Posts by si_edgey
Old Oct 26, 2014, 12:19 AM
StuckNaTree's Avatar
United States, VA, Richmond
Joined Jul 2014
Just a thought but 100 flights in you should clean those servos. That could be your problem just some dirty servos. Do you get much jitter normally? I know fbl will have some jitter, but if it shakes for no reason when stationary it's dirty. Check connections, of not try switching the servo and see if problem persists. It'll at least narrow down the problem. Also depending on which version board you have, even small vibrations can make the gyro act crazy, v1 more so I believe. But it astonishing how just a bit of vibration will make the heli head in random settings trying to correct the random inputs it is receiving.
StuckNaTree is offline Find More Posts by StuckNaTree
Old Oct 26, 2014, 04:30 AM
Joined Dec 2010
Thanks for the reply - I have tried cleaning the servos (which were pretty dirty) but it made no difference. She's actually flying very stable just when spinning up and just after take off, it's more that the servos seem to be incredibly sensitive to input from the right stick
I'm stumped, any other suggestions would be great - I'm going to contact HH to see if they have any ideas as well.
Help! Crius AIO Pro based TriCopter losing ESC power during flight hamsterrorist Multirotor Electronics 1 Oct 25, 2014 02:15 AM
Discussion Afro 30Amp ESC's very sensitive/jumpy Rcbamm Multirotor Power Systems 3 Oct 08, 2014 01:46 AM
Discussion Motor malfunction during flight matej1410 Multirotor Electronics 4 Oct 02, 2014 03:39 PM
For Sale McPx bl very few flights with extras hunhunter Aircraft - Electric - Helis (FS/W) 2 Oct 20, 2013 12:06 PM
Discussion Can the Aerobird Challenger be made faster during level flight? Mambo Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2008 01:02 PM
