Old Jun 13, 2014, 11:58 AM
Hey guys...watch this
buildcrashrepair's Avatar
United States, KS
Joined Jul 2013
Help!
How to add scale panel lines?
Not sure where to post this but i guess ill do it here.
I am new (more like extremely new) to the rc airplane detailing world. I am wondering how i would glass an airplane and then add scale panel lines?
I was thinking that I could just pencil the lines in after i put the paint on and then put a clear coat on top but not sure that the way to do it
Any help would be great as i am a total noob to this
Rob
buildcrashrepair is offline Find More Posts by buildcrashrepair
Old Jun 13, 2014, 12:33 PM
Canada
Joined Nov 2000
One can apply 1/64th tape then apply primer coats. Subsequently removing the tape prior to final colour coats results in nice lines. Not for those concerned with weight build up though. Pencil is a good alternate as it's a decently thin and faint line. Not over the top prominent.
Be sparing in application of panel lines IMO Less is more :-)
Many really overdo it... and as small factoid; Luftwaffe planes featured taped and puttied seams.
Bare is offline Find More Posts by Bare
Old Jun 13, 2014, 03:11 PM
ARFs make me BARF
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
There's makeup, then there's Hollywood makeup.
Most models have panel that are much too large. Full scale MIGHT have 1/16" gap..so on a model, most of the time pencil lines are fine. All too often models get Hollywood makeup, with panels that would have 2" gaps in full scale.
Less is indeed more. I good bit of shading w airbrush is more convincing..
mrittinger is online now Find More Posts by mrittinger
Old Jun 13, 2014, 03:58 PM
Branjo
Joined Sep 2013
I use an extra fine point sharpie and a 6" straight edge sometimes and I like that just fine. Granted, it may not be a perfect scale finish but it ads some detail fairly easy and thats it. Although, like has been mentioned, less is always more with these small planes.
bshultz327 is offline Find More Posts by bshultz327
Old Jun 13, 2014, 04:16 PM
Power Upward
GeorgeG97322's Avatar
United States, OR, Albany
Joined Jun 2007
My father used the Micron Archival Ink Pens for his Mustang. They worked quite well, but ya don't dare slip when using them, hard to clean up mistakes
George
GeorgeG97322 is offline Find More Posts by GeorgeG97322
Old Jun 13, 2014, 04:29 PM
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
Remember that panel lines at the scales we are building planes are almost invisible. I sometimes use a light grey pencil with a coat of krylon matt or dope. Most folks way over do the panels. My advice is forget it.
Pat Daily is online now Find More Posts by Pat Daily
Old Jun 13, 2014, 04:33 PM
United States, KS
Joined Jul 2013
Thanks for the feedback.
I think that i am just going to use the pencil method (since its the easiest) and see how it turns out
Old Jun 13, 2014, 08:00 PM
ARFs make me BARF
mrittinger's Avatar
Joined Dec 2000
This is what I did on the MAN Zero...
http://www.rcgroups.com/forums/showt...ht=a6m3&page=7
Old Jun 13, 2014, 09:14 PM
Pat Daily's Avatar
Joined Mar 2001
I am not sure what plane you are modeling but I recommend a grey versus black and keep it light, not overdone. In these photos you can hardly see the panel lines. Only a few show up. The photo of the SNJ in the air was taken be a camera at the wing tip and most panels are invisible at that short distance.
Old Jun 14, 2014, 02:22 AM
All under control, Grommit!
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
As Mark and Pat both said, the simple addition of a thin pencil line to the surface is a very good and quick means of adding panel lines, which should be quite understated for the smallish models that are so popular. I once saw a semi-scale Harrier that would have been quite a nice model, but had been completely spoiled by the addition of heavy black overdone panel lines, added with a felt-tip pen
leccyflyer is offline Find More Posts by leccyflyer
Old Jun 15, 2014, 09:52 AM
Don't look at me like that....
62pilot's Avatar
United States, AR, McDougal
Joined Aug 2005
Yup, lite and thin. I use pencil for weathering or for shadows from exhaust or other small protrusions . Can be very effective for smaller scale planes.
All panel lines, exhaust, and other bits including the shadows on the simulated fabric covered control surfaces are done in pencil.
62pilot is offline Find More Posts by 62pilot
Old Jun 16, 2014, 11:42 AM
Pat Daily's Avatar
Joined Mar 2001
nice work on the dive bomber! Is it a kit of from plans?
Old Jun 17, 2014, 09:09 AM
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
The panel lines are clearly visable on this Stuka and Focke Wulf.
I hadn't read that panel lines were taped and puttied on Luftwaffe aircraft.
TomCrump is offline Find More Posts by TomCrump
Old Jun 17, 2014, 11:50 AM
United States, KS
Joined Jul 2013
Thanks for all the info...going to give it a shot pretty soon!
Rob
Old Jun 18, 2014, 06:55 PM
62pilot's Avatar
Joined Aug 2005
It's stand off in the next county scale. Built only from crappy 3 views . I want to change the canopy , as it appears to tall. And need to redo the battery hatch on the bottom. But Thanks. The wing was from an old Midwest profile P-40, and the cowl is a bowl stolen from the wifes cupboard .
Discussion scaling 3 view to use as template for panel lines rudypantaleon Scale Fuel Planes 4 Apr 26, 2011 09:25 PM
Discussion scale panel lines newcomer Scale Kit/Scratch Built 12 Mar 04, 2010 10:18 PM
Why so deep panel lines in the scale planes? Lynxman GWS (Grand Wing Servo) 0 Jul 14, 2004 12:01 PM
Question How to do panel lines? gouch Slope 12 Jan 12, 2004 04:16 AM
Panel lines for Plug HOW??? ChrisFeole Electric Ducted Fan Jet Talk 10 Aug 03, 2003 09:32 AM
