Old Jul 26, 2012, 10:56 AM
Sunfire's Avatar
Joined Jul 2007
Resources - Big Bubble Dancer-like Glider
hello friends;
recently, my friend has suggested that we build a 5m AVA or a Bubble-Dancer-like electric glider (for those of you in the know, it's actually a commercialized Bubble Dancer available on Hyperflight.)
out of craziness, I have decided to go along with the idea and see how far it takes us...
I have recently started sketching up the basic outline on sketchup and generated the profiles
you are free to have them as well = )
please ignore the pdf names.... it's actually designed for foam core, with glass.
our idea is that we would use blue foam covered with 1mm balsa skin and glassed for ding resistance.
it'll be electric, too, with a 3 piece wing.
for strength, we could add internal spars.
any opinions or suggestions from experienced builders would be welcome, I think you guys have built more gliders than I have = )
right now, I'm just thinking - lightweight fibreglass on the inside of the balsa skin, and lightweight fibreglass on the outside.
I have a space saver bag and a hand-pump as well, that might do a crude form of vacuum bagging....
think it'll work?
anyway check back, this might take some time....
oh by the way, the layout is based on the XCBD.....
edited..... wing panel 4 is now corrected
Sunfire is offline Find More Posts by Sunfire
Old Jul 26, 2012, 01:13 PM
United States, MA, Waltham
Joined Dec 2001
I haven't built many bagged wings, and those were sheeted, but I've helped bag some full scale boats, and I find myself using my vacuum pump reasonably often for this and that.
There is no "could" about the spars, especially with the wing construction you are proposing. This is a long, skinny wing. If you were willing to use a fair amount of carbon, it might make sense to go with a slightly higher aspect ratio. If I'm not mistaken, you're at something like 19:1. The XBCD has an aspect ratio of 18.5.
On a project of this magnitude, don't try to skimp on the vacuum pump. Whether it is homemade or commercial, you should have a decent amount of vacuum (20" Hg on the gauge, perhaps) and a good amount of flow.
If you don't want to skin with carbon or glass with no balsa, maybe thin aircraft ply, grain on the diagonal, would be a good alternative.
lincoln is online now Find More Posts by lincoln
Old Jul 26, 2012, 09:19 PM
Sunfire's Avatar
Joined Jul 2007
Hi Lincoln, thanks for the reply.
so you mean to say, a spar is definitely needed? I would guess so, esp for middle panel. noted....
we traced this out from the XCBD's profile.
Old Jul 26, 2012, 09:30 PM
Gungho's Avatar
Singapore
Joined Aug 2006
Im the other crazy partner in this endeavour.....I get to do the 2.4m long fuselage.
I have previously made stuff out of Medium glass/balsa/medium glass with no bagging...and it came out weighing a ton. So this time round we definatley need to bag. Carbon rovings int eh right places for reinforcement.
Sparing for the wing is a must. Since the center panel is rather flat. We could cut a channel for a balsa carbon sandwhich with joiner tubes at the end. Wing sections capped with thin ply to mount the locating pins and joiner tubes.
We could get inspiration from vladimir
http://f3j.in.ua/en/supra-el-family.html#fussupra
Gungho is offline Find More Posts by Gungho
Old Jul 26, 2012, 09:42 PM
Joined Dec 2001
Glass is heavy and flexible, though it's strong. For high aspect ratios and large spans, I think carbon will help a lot.
If you want to save money, maybe light glass and disser skins? (Disser, apparently, is a bunch of tow laid up on the diagonal at intervals.)
Lots of info on various build threads and on the plans at charlesriverrc.org. I think there's even a thread on the XCBD
Old Jul 28, 2012, 08:35 PM
Whisper Model Aircraft
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
You might follow along with Curtis.
Thats the simplest, cheapest, most successful build I've seen.
http://www.rcgroups.com/forums/showthread.php?t=1528685
Will
heliwill10 is offline Find More Posts by heliwill10
Old Jul 30, 2012, 01:01 AM
Sunfire's Avatar
Joined Jul 2007
cheapest and most successful! Wow! I am in!
Old Jul 31, 2012, 06:41 PM
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
Here you go, guys. A 4.8M Supra like glider.
http://www.rcgroups.com/forums/showt...9#post22317724
I have seen this version (and prior ones) fly.
Very cool.
Contact John if you are interested in getting all kinds of valuable info.
jaizon is offline Find More Posts by jaizon
Sold Bubble Dancer short kit and tailboom lgibjones Aircraft - Sailplanes (FS/W) 4 Jul 21, 2012 04:21 PM
For Sale Home built bubble dancer 3M UK ONLY muchalucha Aircraft - Sailplanes (FS/W) 1 Apr 15, 2012 06:05 PM
Discussion repairable glider liker the Bubble Dancer? Marko75 South Bay Soaring Society 4 Mar 02, 2012 12:51 AM
For Sale carbon eraser E, 3d slope, thermal dancer(s) Stork 2 pro E bubble dancer RTS.readytosoar Aircraft - Sailplanes (FS/W) 4 Aug 21, 2008 06:27 PM
