Old Jun 04, 2014, 05:57 PM
Old_Pilot's Avatar
United States, TN, Memphis
Joined Dec 2012
Build Log
Wilmot Frog IV Interceptor
I've been scratching around for a candidate for BBCC5, and every time I think I've found one, I discover that there's 8 build logs of 4 configurations, and 2 sequels of the bird.......HARRUMPF!, HARRUMPF!
So, I started looking down through the list of airplanes in the Flight Global Archives tome compiled by Lord Librarian Terrell and found this little girl. It's apparent she was a 1930's rubber powered kit of a fantasy fighter aircraft, but there doesn't seem to be any drawings other than the 3-view and a picture of a squadron of them.........to that end I've developed a set for a 60" version (approximately 1/8 of the "proposed" scale).
I really like her, but...(there's always a "but"), I think she looks better as a parasol with spoked wheels than as a shoulder wing with smooth rims........sooooo, I developed a set of drawings for both variants. If the BBCC 5 executive committee allows it, I'm going to build the parasol version ......see attached
Note: I revised the drawings.....Tail feathers are now built-up...she was a bit butt heavy with those platters of balsa for the stab and fin.
I'm going to revise the drawings again to reflect smaller ailerons and a relocated undercarriage, and probably a little thinner fuse.....its wider than 4".....
Revised Drawings 6/16/2014 to reflect changes from above
Old_Pilot is offline Find More Posts by Old_Pilot
Old Jun 09, 2014, 06:38 AM
Old_Pilot's Avatar
Joined Dec 2012
Wilmot Frog Mk-IV Interceptor
Predicted Flight Characteristics based on:
3 degrees AOI
43 oz AUW (though all the birds I've built so far of this size have come in at between 32 - 36 oz range)
Clark-Y - 11.7% at 28% chord/3.4% camber at 42% chord
25.66 FPS will generate 43 oz of lift
Old Jun 09, 2014, 03:06 PM
Old_Pilot's Avatar
Joined Dec 2012
24" WS Foam Glider Version
Got my foam cutter out this morning......plus a couple of Dollar Tree Foam plates.
I'll mount the wings tomorrow probably
Old Jun 10, 2014, 05:17 AM
Old_Pilot's Avatar
Joined Dec 2012
Test Glider
Miniature version of the Mk-IV. Test flight this morning when it quits raining. Indicated CG shown......we'll see
May get the cutting wire back out and mount the wing in its shoulder position...add some light weight (cardboard) wheels and undercarriage
Old Jun 10, 2014, 07:22 AM
Old_Pilot's Avatar
Joined Dec 2012
Test flights of glider
I finally flew something I built !
Old Jul 18, 2014, 05:12 PM
Old_Pilot's Avatar
Joined Dec 2012
On pause right now
The Wilmot will be my candidate for BBCC5........which won't start until September....so this build log is on pause until then
Old Jul 22, 2014, 07:14 PM
lukes221's Avatar
Canada, ON, Lindsay
Joined Nov 2013
nice! i like the parasol idea.
lukes221 is offline Find More Posts by lukes221
Old Jul 23, 2014, 06:02 AM
NSWFFS
Richmond NSW Oz
Joined Apr 2005
Very cool idea, there is in fact, a double size (stick and tissue/rubber powered) plan of the original ARF Frog Interceptor / Frog fighter.
The original came in a box that doubled as a winding stooge and storage, Inside the box there was a small bottle of winding lube for the rubber and the handle to wind it. The wings were plugged into the fuse after winding and off it went. I would guess the wingspan at 10". I bought him another for his 70th birthday but asked him not to fly it given what they cost.
My father had one as a boy however he foolishly flew it from a headland in Sydney Harbour and you can guess the rest of that story. I bought him another for his 70th birthday but asked him not to fly it given what they cost.
Somewhere I have the 2X plans, I think it was in Aeromodeller around 15 to 18 years ago. It was definitely an English model mag.
There is also the RCM plan for electric RC at around 46"
Cheers,
Rob
McGiver is offline Find More Posts by McGiver
Old Jul 23, 2014, 06:05 AM
Old_Pilot's Avatar
Joined Dec 2012
Luke,
Thank you so much.....also working on resurrecting the Fane AOP.......
http://www.rcgroups.com/forums/showt...9#post28823311
Any ideas or suggestions are certainly welcome
Old Jul 23, 2014, 06:15 AM
Old_Pilot's Avatar
Joined Dec 2012
McGiver,
THANK YOU SO MUCH for the color picture.....that will help immensely with the color scheme........have to look at RCM for the plans......
Thanks again
O_P
Old Jul 23, 2014, 10:19 AM
lukes221's Avatar
Canada, ON, Lindsay
Joined Nov 2013
Originally Posted by Old_Pilot View Post
Luke,
I was following that build for the most part yes. It also looks very unique. i planes that arent around much. Its refreshing to go to a field or event and see different planes for a change
So from this and the Fane build your method from what i see is you build a foam version just to test and then build the balsa version?
Old Jul 29, 2014, 09:59 AM
Old_Pilot's Avatar
Joined Dec 2012
For an airplane to qualify for a BBCC, it has to be "converted" from one form of control to another....and since the Fane has never been kitted as a model in any flight configuration, I had to build something to "convert" to RC.....also, I didn't know anything about either plane's CG, AOI, Thrust angles, decalage, and the like, I built the gliders just to get some idea of what those numbers and positions might be.
I'll probably build both for BBCC 5, just not concurrently......and that won't start until September...still tweaking the drawings right now
Old Aug 03, 2014, 03:29 AM
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
My older brother had one in the '60s and I was insanely jealous of him. If flew but not as well as we expected.
Grantham Kid is online now Find More Posts by Grantham Kid
Old Aug 03, 2014, 12:13 PM
United States, NJ, Browns Mills
Joined May 2005
IIRC, Chris Golds did a large one for E-power. It was published in QEFI about a year or two ago.
CD
Captain Dunsel is offline Find More Posts by Captain Dunsel
Sold Skylark ATT Antenna Tracker IV and Trace OSD IV For $275 satttheman FPV Equipment (FS/W) 1 Jan 22, 2014 12:23 PM
Sold Skylark AAT IV and Trace IV sparkyincali FPV Equipment (FS/W) 4 Jan 16, 2014 04:39 PM
Discussion Interceptor 052 tail rotor mod. Baddmove Coaxial Helicopters 1 Nov 01, 2013 01:36 AM
Off Site NIB Comet Interceptor Free Flight Antique Classic Model Airplane Kit badbill Aircraft - Fuel - Airplanes (FS/W) 1 Sep 29, 2013 12:40 PM
Discussion FROG Interceptor Mk IV marksherlock Electric Plane Talk 11 Jan 22, 2009 05:36 AM
