Old Oct 18, 2013, 08:45 PM
Joined Sep 2013
Newbie. Do water cooled motors act as a pump?
Do water cooled electric motors act as a pump to move water through them or is the water forced through the tubes by the boats movement?
We just got an aquacraft Revolt 30 and it seems it is not moving water through the motor. We are not sure whether we had a clog or the motor is not pumping the water properly. It over heated within the first two minutes of running.
waltern is offline Find More Posts by waltern
Old Oct 19, 2013, 01:36 AM
cyberhoops's Avatar
Seattle
Joined Feb 2006
No pumping... just water pressure from the pickup tube.
cyberhoops is offline Find More Posts by cyberhoops
Old Oct 19, 2013, 02:53 AM
Australia, VIC, Blackburn North
Joined Feb 2011
Easiest way to check water flow is by pushing water through the system by either a syringe or a mouthful and blow it through or just blow through the outlet. It should be pretty easy to blow through.
Check all the lines to ensure they aren't creased, if no creases, there may be some debris caught in the system somewhere.
mozzyrocks is offline Find More Posts by mozzyrocks
Old Oct 19, 2013, 09:08 PM
Steps? What steps?
zozer's Avatar
United States, TX, Humble
Joined Jan 2010
What do you mean by "overheated"? Did you measure the temperature of the motor or ESC? What prop were you using? Exactly what packs? Mostly full throttle or mostly part throttle?
It is pretty easy for water in the lines to drain out when the boat is lifted from the water. A rudder pickup will drain almost all the water if the bow is held up for a few seconds. If you can blow through the lines, there is probably plenty of water moving through them when the boat is moving.
zozer is offline Find More Posts by zozer
Old Oct 20, 2013, 04:28 PM
Joined Sep 2013
thank you all for your help. We blew out the lines. They had been blocked by moss and the engine went into limp mode. All is well now.
Sold Bundle of Brushless motor,water jacket & 120 Amp water cooled esc. LVMikey Boats (FS/W) 0 Sep 11, 2013 11:19 AM
Sold 550 Size Brushed Motor (water cooled) and ESC bwoollia Boats (FS/W) 1 Feb 26, 2013 11:59 AM
Discussion on/off water pump motor AC with remote control 315mhz Jame David DIY Electronics 3 Feb 19, 2013 12:25 AM
Discussion An inrunner building project, from BMW engine-cooling water pump motor modisc Electric Motor Design and Construction 30 Aug 22, 2012 09:08 PM
Discussion Looking for water pump for motor cooling RCBoater Dock Talk 8 Sep 11, 2009 06:59 PM
