This thread is privately moderated by The Don, who may elect to delete unwanted replies.
Old Jun 27, 2014, 11:46 PM
that's gonna leave a scar
KCinNC's Avatar
United States, NC, Mooresville
Joined Aug 2007
Originally Posted by The Don View Post
Wicked 6000 wemotec fan on 3S was just over 100 mph running a 3S 1800 in the Screamer. I did a build thread on it.
good deal, that will work for me
KCinNC is offline Find More Posts by KCinNC
Old Aug 03, 2014, 04:41 PM
david.webb46's Avatar
Joined Mar 2013
Blitz RCWORKS F-14
Don,
I just started a twin 60 mm f-14 from BlitzRC and I really would like use one of your setups, any recommendations?
david.webb46 is offline Find More Posts by david.webb46
Old Aug 03, 2014, 08:37 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Here are the various 60mm setups
http://www.rcgroups.com/forums/showp...03&postcount=5
I did mine with the 4400 motors and twin 60 amp ESC (setup #4), and a 4S 4000 mah. Plenty of power, I thought if I ever did it again I would probably go the 4000 KV and twin 40amp to save some weight (setup #3).
The Don is online now Find More Posts by The Don
Old Aug 04, 2014, 12:06 PM
Premium2000
Largo, Florida
Joined Jun 2007
Big problem
I recently bought one of your wicked 2700 edf / Changesun 64mm 12b 4S setups and put it in a Dynam F16, including a thrust tube with a 57 mm exit.
All I can say is Wow! This thing sounds great, will go vertical on takeoff and has nice speed. Nanotech 4S-1800 45/90C lipo's end up barely warm.
So what's the problem? Well I've gotten so much attention at the Club that others want this setup and your out of stock on the combo.
Also, I just got a Free wing 64mm stinger 4S that I would like to quiet it down without losing performance. If this combo is no longer available what would you recommend? Speed is not primary concern. I'd like l low noise, balanced thrust and speed.
Your recommendation for this 4S, 12B Changesun setup was spot on.
Thanks!
Larry
Premium2000 is online now Find More Posts by Premium2000
Old Aug 04, 2014, 04:53 PM
Joined Mar 2013
Don,
Thank you for the direction, does either come in a combo that is balanced plug and play if you will?
thx again
Old Aug 04, 2014, 05:11 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Originally Posted by david.webb46 View Post
Don,
thx again
You just add the "mount and balance" to the shopping cart.
Old Aug 04, 2014, 05:15 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I received too many complaints on this setup that it used too many watts and not enough thrust or speed so I have no plan on restocking.
Also, I just got a Free wing 64mm stinger 4S that I would like to quiet it down without losing performance. If this combo is no longer available what would you recommend? Speed is not primary concern. I'd like l low noise, balanced thrust and speed. Your recommendation for this 4S, 12B Changesun setup was spot on.
Thanks!
Larry
The only option I will have in the future is a new Wemotec 9 blade fan for use in 64mm EDF applications. But that is still some time away.
Old Aug 08, 2014, 09:59 PM
KCinNC's Avatar
Joined Aug 2007
my favorite edf right now.....this thing is awesome !!!! I am using a 2200. << it just works !
thanks for the setup
Old Aug 08, 2014, 10:17 PM
nom
nom's Avatar
United States, ID, Boise
Joined Mar 2011
Try your setup on 4S!!!
nom is online now Find More Posts by nom
Old Aug 14, 2014, 07:30 PM
Joined Mar 2013
Don,
Thanks for the suggestion with the power plant for my f-14, can you tell me what is the difference in the 5000kv Inrunner motor that BH recommended and the 4400 EDF setup that you recommended? Also had some trouble trying to order the twin edf setup ready to install. not sure why??
Thanks again for your expertise!
Sold Dons Wicked EDF 4800KV brushless and 55mm EDF UNIT hi2nr Aircraft - Electric - Jets (FS/W) 4 Mar 01, 2012 06:51 PM
Sold Dons Wicked EDF 4800KV 55mm EDF unit hi2nr Aircraft - Electric - Power Systems (FS/W) 0 Mar 01, 2012 06:28 PM
Mini-HowTo Mounting the Wicked EDF motor into the HET 6404 64mm EDF Fan unit The Don Don's RC 0 Jan 28, 2012 11:20 AM
Discussion dons wicked edf plus 4400 60mm edf applications tommythecat Don's RC 6 Nov 20, 2011 01:13 PM
Question Hobbykings edf 35mm Mig-15 *Wicked Setup* deuce66 Don's RC 4 Oct 27, 2011 07:56 AM
