Old Sep 07, 2010, 01:02 AM
Italy,Russia,Kazakhstan...
Joined Aug 2007
How to build you Avionik-B model.
At first:
this is not official manual.
I'm not autorised to make it from team Avionik.
This is my point of view to the inadequate relation to the model from part of Pilots.
Fellows, you obtained very qualitative model. Specifically, on such models they become the champions of World. Respect the quality of model and the labor of producer. And this will return to you by high score in the field.
Golikov is offline Find More Posts by Golikov
Old Sep 07, 2010, 01:08 AM
Joined Aug 2007
The Wing
First,
Never use the flat connector's from the wing in flight. This connectors is for test only, and this is not adopt for constant use in race condition.
For less than two years which I flight the Avionik B models, I have to see how the team use only self made from something like this, connectors ("connector" "connector1") fotos.
Old Sep 07, 2010, 01:09 AM
Joined Aug 2007
Jast cut 2x3 piece from, and sand it clear.
Old Sep 07, 2010, 01:15 AM
Joined Aug 2007
Prepare 2-3 cm of 4mm heatshrink tube and 10-15 cm 1.2 mm heatshrink.
Solder the wing connectors first, with great care, accurate, cut the wires one by one from flat connectors, make pass first trow the 4mm tube and solder each one to his position on the wing connector.
Old Sep 07, 2010, 01:17 AM
Joined Aug 2007
After, when all 6 (8 really) wires will be soldered, heat up gently the shrinks.
Old Sep 07, 2010, 01:18 AM
Joined Aug 2007
Prepare the fuse part,
Old Sep 07, 2010, 01:20 AM
Joined Aug 2007
Please notice, I have cut one lip from "male" side and glued this lip on "female", to make some like a "key". And never wrong with.
Old Sep 07, 2010, 01:22 AM
Joined Aug 2007
Prepare the reiciver-radio, on board battery. Connect all as it must to be, to the wing.
Swith it on. The servo horn goes UP.
Old Sep 07, 2010, 01:24 AM
Joined Aug 2007
Please, make the horns for Flap and Aileron from 2mm circuit board. Try to find some with really tiny fiber.
Old Sep 07, 2010, 01:28 AM
Joined Aug 2007
Notice the "a!" this is good position for neutral of flap servohorn. Make this equal for other one.
Pay attention for height of Flap horn and hole position!!!
Old Sep 07, 2010, 01:31 AM
Joined Aug 2007
Look's like the same but is not. The Aileron!!!
Pay attention for servo horn (a!), bit higher hole (6mm) and 5mm up front hole position.
Old Sep 07, 2010, 01:33 AM
Joined Aug 2007
The link!!! not less than 1.5 mm good steel wire. 2mm is better.
Old Sep 07, 2010, 01:36 AM
Joined Aug 2007
Fuselage, jast see the foto.
Old Sep 07, 2010, 01:39 AM
Joined Aug 2007
Tail part is easy. Prepare the elevator link, but do not glue one side end. Till the elevator do not stay in place with his horn.
Old Sep 07, 2010, 01:44 AM
Joined Aug 2007
Make the elevator bed on the rudder top. Sand it to do perfect "T", and not less than 4-5 mm down travel for elevator.
Discussion Avionik 2006 F5F/B Highfly! High Performance 8 Aug 16, 2010 01:29 PM
How long do you fly a your model before you get bored and build/buy a new one? totalboss Electric Plane Talk 51 Jun 10, 2010 12:53 AM
Discussion How do you tell the diff. b/w Failure to bind(Rx can't Connect) and Loss of bind? Fly2High Radios 19 May 19, 2010 06:24 AM
Sold Avionik B-06 F5B model Lenny970 Aircraft - Sailplanes (FS/W) 0 Apr 16, 2010 12:50 PM
Poll How do you obtain your Model Airplanes? PLEASE HELP!! Mode One JR Indoor Electric Festival 6 Nov 06, 2009 10:54 AM
