Old May 04, 2009, 09:48 PM
Wandering IT geek
ronin4740's Avatar
United States, NV, Reno
Joined Aug 2005
Help!
Turnigy 5055-580 and 8mm Prop adapter
I could use a hand keeping a collet style prop adapter on the shaft of a Turnigy 5055-580 motor. The plane it's in has a reverse mount meaning that the motor is mounted behind the firewall. Using the included adapter won't work as I have no way to mount the motor in that direction.
I used a socket wrench to cinch the adapter down and thought it was on good and tight but it still broke free at about half throttle with a 6S battery. This is about 7200 RPM if I'm doing the math right (((25.2*6)/2) * 580). I plan to use a smaller prop next time around but am still going to spin the snot out of this motor...
So, what's the best way to keep a big cinch this prop adapter down onto the motor? Loctite or...?
Thanks in advance!
ronin4740 is offline Find More Posts by ronin4740
For Sale Wanted - 8mm collet adapter for 8mm shaft prop leybold12 Aircraft - Electric - Power Systems (FS/W) 0 Oct 06, 2008 02:17 PM
Discussion HXT/Turnigy Prop Adapter & Spinner scrapster Power Systems 2 Jan 31, 2008 05:30 AM
Help! Bolt-on prop adapter for HXT 35-48 900kV (Turnigy) Straight Up Power Systems 13 Jan 08, 2008 11:26 PM
Discussion Help Need 8mm Prop Adapter for HXT 50-68b Motor thesenator Power Systems 12 Nov 09, 2006 05:11 AM
Discussion 8mm (motor shaft) prop adapter, do they make such a thing? BlazerB52 Power Systems 2 Jul 19, 2006 05:18 PM
