Old Oct 17, 2014, 03:42 AM
United Kingdom, England, Oakenshaw
Joined Jan 2010
I accidentally left the mobius plugged in and charging overnight - I came to it this morning and it was still warm. Does it not have an auto-shutdown charge thing where it stops charging? i.e. when the green light goes out - does it mean it's stopped charge going to the battery?
I know LiPo's are a bit iffy if you overcharge
AndyKay is offline Find More Posts by AndyKay
Old Oct 17, 2014, 04:23 AM
f2001m's Avatar
Joined Feb 2012
mine i leave it plugged overnight. in next morning remove it from the charger once green led turn off.
f2001m is offline Find More Posts by f2001m
Old Oct 17, 2014, 05:51 AM
Joined Nov 2010
Maybe you left the camera on?
When you connect the camera to external power it will turn on. If you only want to charge the battery then you should turn it off. No harm will be done if you leave it charging overnight, but it's best to make sure it's turned off.
Isoprop is offline Find More Posts by Isoprop
Old Oct 17, 2014, 08:00 AM
Joined Jan 2010
Nope was definitely left on the Green LED charge mode.
Old Oct 17, 2014, 08:05 AM
Random Flier
Oxford (UK) and Mtn View CA (USA)
Joined Nov 2002
Mobius in FPV racing
BBC report on French drone racing - spot the Mobius!
http://www.bbc.co.uk/news/technology-29546019
isvana is offline Find More Posts by isvana
Old Oct 18, 2014, 12:09 PM
Spain, Valencian Community, Alicante
Joined Dec 2008
Originally Posted by sureshot__ View Post
First open it and check inside for any problems.
It could be a stuck switch.
If the main board is bad, Banggood.com sells replacement boards.
thanks for your reply.
into cam all appears ok.
looks as if firmware are crazy
I push one button and the led color not correspond with the correct action.
alberthamon is offline Find More Posts by alberthamon
Old Oct 19, 2014, 05:10 PM
7AC
7AC's Avatar
Central Indiana
Joined Oct 2006
Help, I can't increase or decrease the numbers for the colors in the "advanced" section of the GUI by clicking on the little up or down arrows.
7AC is offline Find More Posts by 7AC
Old Oct 19, 2014, 05:47 PM
< 1100W in Seattle
LowWatts's Avatar
Joined Mar 2006
Have you tried selecting custom first?
LowWatts is offline Find More Posts by LowWatts
Discussion FPV'ing successfully using tricopter/tcopters - tell us how you did it? shauntot FPV Talk 7 Apr 24, 2013 02:55 PM
Discussion Question about using computer monitors for FPV Koo FPV Talk 2 Feb 13, 2013 01:13 AM
Discussion OT, for those still on the fence about GoPro cams for your FPV needs. bgnome Dock Talk 9 Sep 19, 2012 12:59 PM
Discussion FPV cam your daughter would approve: Barbie Cam Steph280 FPV Talk 14 Aug 12, 2010 10:09 PM
Discussion Building Clear Canopy's for your FPV cams... IamLegend FPV Talk 2 Nov 16, 2007 02:50 PM
