Old Jun 23, 2003, 09:55 AM
FJR
Holly Springs, Georgia
Joined Jan 2003
Switchback Prop size
Switchback is almost ready!
What prop should I use? I am using the stock motor from my GWS Zero. It is the correct gear.
The search function is disabled, sorry for the possible redundant question.
FJ
FJR is offline Find More Posts by FJR
Old Jun 23, 2003, 10:19 AM
wild in the park?
wherndon's Avatar
McDonough, GA
Joined Mar 2003
10 x 8
Bil
wherndon is offline Find More Posts by wherndon
Old Jun 23, 2003, 10:25 AM
FJR
Joined Jan 2003
That's what I thought. Thanks for the info. I had a 9070 and it looked awfully small.
FJ
Old Jun 23, 2003, 03:11 PM
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
APC 10x7 slo fly. Depending on your altitude, i found i liked the D gear ratio and 10x7 prop on 8 720 nimh cells, not quite as much power as the C gear ratio, but still plenty for the switchback, plus your motor lasts longer,and your batteries dont cry after each flight
Dylan
Dylwad is offline Find More Posts by Dylwad
Old Jun 23, 2003, 03:13 PM
Stick Masher
Fort Collins, CO
Joined May 2003
So, I've seen several recommendations for APC props. I looked at one over at the LHS the other day. How do you mount one of those to the GWS prop shaft? I'm sure I'm missing something obvious. But the opening diameter of the prop is too big. Is there some sort of doo-hickey that fits in there for mounting?
Derek
derekl is offline Find More Posts by derekl
Old Jun 23, 2003, 03:30 PM
FJR
Joined Jan 2003
Dylan,
Thanks for the info. I'm in Northern Georgia and I do have the "C" gear. From what I've read I should have plenty of power, however I am concerned about frying everything. I will test the setup on the wattmeter and see how everything looks, 7 cells, 8 cells with both props. My father ran the "D" gear and his SB flew with no hints of struggle.
It seems that more power than you need is the thing these days and I have to agree that it nice to be able to throttle out of a low altitude mistake. Fast fly byís are kinda cool too.
Old Jun 23, 2003, 03:46 PM
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
10X8 GWS or 10X7SF APC. To mount the APC, get the little adapter set that GWS sells.....that's the simplest way. There are lots of other ways.
What are you planning to use as a battery?
BEC is offline Find More Posts by BEC
Old Jun 23, 2003, 04:09 PM
FJR
Joined Jan 2003
BEC,
Kan950's...It's my understanding that these are a little heavy but work well. I'm open for any suggestions.
Old Jun 23, 2003, 07:26 PM
Dylwad's Avatar
Joined Jun 2002
i found that the flight performance with 7 Hecells is better than 8 AAA nimh cells, and the weight isnt as much of an issue with 7 2/3A cells. i would run 7 Kan cells on either the C or D drive with the 10x7-10x8 prop. This setup is a pretty good comprimise between power and motor life, i burned up alot of speed 300 motors before i went brushless, and now that i have i take it easier on my brushed motors.
Dylan
Old Jun 25, 2003, 07:40 AM
FJR
Joined Jan 2003
Dylwad,
I guess I'll have to break down and purchase a brushless. I'm sure there would be a great deal of info on which brushles motor is the best for the Switchback.
Altitude and prop size--confounds comparisons fregon45 Electric Plane Talk 8 Sep 23, 2007 10:25 PM
Best prop size Masterpiece Electric Plane Talk 2 Jun 29, 2001 06:36 AM
Prop size Masterpiece Parkflyers 3 Jun 26, 2001 10:44 PM
Astro 15 direct prop size? Steve H. Electric Plane Talk 6 May 19, 2001 11:18 PM
Prop size. for 2x4 glider Dandi6065 Power Systems 0 May 11, 2001 08:30 PM
