Old Jul 20, 2008, 12:22 AM
Sure it'll work
Flyextreme's Avatar
United States, CA, Torrance
Joined Nov 2005
Trex 450 SE or SE V2
I've been looking at both the Trex 450 SE &Trex 450 SE V2. Has anyone had a chance to compare the two of them?
Bottom line....is the V2 worth the extra $$$$$??
Bill
Flyextreme is offline Find More Posts by Flyextreme
Old Jul 20, 2008, 12:47 AM
JustinMoore12's Avatar
USA, VA, Woodbridge
Joined Sep 2007
You would be pretty hard pressed to find a new v1. v2 has a couple upgrades, larger spindle shaft, i think the head design is slightly tweaked as well. I would say just go ahead and get a v2 if you have the money.
Gratz on ur 600th post btw.
JustinMoore12 is offline Find More Posts by JustinMoore12
Old Jul 20, 2008, 01:02 AM
Joined Aug 2006
really? LOL I just bought a brand new 450 SE V1 today...
chriskim_95 is offline Find More Posts by chriskim_95
Old Jul 20, 2008, 01:04 AM
USA, VA, Woodbridge
Joined Sep 2007
Wow, i didnt think anybody still had stock. Oh well how much price diff. was there?
Old Jul 20, 2008, 01:16 AM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
I did some more looking since my post. It looks like the only difference is the head assem. and thre 4mm shaft mentioned above. And from what I could see the price varied from around $80 to $140 depending on where you get it. I also noticed that you will pay about $150 more + or - for the same kit if you get it from the USA instead of overseas. Makes it kinda hard to keep the money close to home. I still want to take my numbers and see if my LHS can even come close. I suppose I could get the SE for now then upgrade the head later if I still wanted to at that time. I just wonder if it makes that much difference.
That's why I was wondering if anyone had had a chance to compare the two.
And does anyone know what the "GF" in 450 SE GF is for?
Bill
Old Jul 20, 2008, 01:21 AM
USA, VA, Woodbridge
Joined Sep 2007
I think the GF is fiberglass compared to the SE 2k carbon.
Old Jul 20, 2008, 01:57 AM
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
I like the 3 mm spindle of the V1. It saves much of your head parts. If you are not into hard 3D, the V1 is more practical.
Gino CP is offline Find More Posts by Gino CP
Old Jul 20, 2008, 02:26 AM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
Uh-duh!...and I think I new that at one time...maybe I need to reboot my noggin.
Old Jul 20, 2008, 02:33 AM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
Yup! it looks like the V1 is in the ticket. I am WAY NOT hard 3D. The $$$ I save could go towards the gyro/tail servo, spare parts, a batt, or whatever. I don't think I need a Farrari when a Cadilac will do nicely.
Thanks Guys, Bill
USA, VA, Woodbridge
Joined Sep 2007
Haha, we all have brain farts
Old Jul 20, 2008, 09:01 AM
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
This is just a thought that may or may not work. One of the major upgrades of the V2 is thrust bearings in the blade grips, where the V1 had all radial bearings. The thrust bearings give you smoother collective action under the high centrigugal force of the head spinning.
The Blade 400 also has thrust bearings, but they put them on a 3mm feathering shaft. My thought is that you might be able to replace the outer bearing of the Trex V1 blade grips with a thrust bearing from the B400. The thrust bearing is .5mm thicker, I think, so you might have to get thinner head spacers, but that could be a way to get thrust bearings into your V1 head while maintaning your 3mm feathering shaft. Lot cheaper than a $40 V2 grip set, too.
I'm not 100% sure it'll work, but that's how I see it in my head
murdnunoc is offline Find More Posts by murdnunoc
Old Jul 20, 2008, 09:22 AM
West Chester, Ohio
Joined Nov 2006
I personally would just get the V1 cause the 3mm spindle is much kinder too it's surrounding parts during a lil mishap. If your really stuck on getting the thrust bearings (and I think they're worth it), then just order a set cause believe it or not, they have a I.D. of 3mm and will fit on the V1 spindle. The hardest part was removing the outter radial bearing from the metal V1 blade grips so I just went to plastic main grips on that particular heli.
missle is offline Find More Posts by missle
Old Jul 20, 2008, 10:55 AM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Sure, if you want to do it the simple way that makes sense!
Scratch the earlier stuff about the B400 bearings. Missle's right, they're the same bearing.
Missle, did you have to put thinner spacers in to accomodate the thicker thrust bearing?
Old Jul 20, 2008, 02:01 PM
West Chester, Ohio
Joined Nov 2006
Actually it was the other way around; you made need to use slightly thiCKer spacers if you want a tight head but either way it doesn't matter cause any extra thickness just pushes the dampners in a lil harder.
Old Jul 21, 2008, 09:48 AM
Pirouetting flip master
Malaysia
Joined Jul 2007
my friend who bought a 3DX450 on 3mm shaft.... when doing hard landings. the feathering shaft bent...
is it normal?
lyclyc is offline Find More Posts by lyclyc
Sold ** SOLD **RTF TRex 450 SE V2 - Jazz/Neu 4S or 3S $650 shipped RockinRyan Aircraft - Electric - Helis (FS/W) 2 Mar 15, 2008 10:52 PM
Sold New Trex 450 SE V2 PNP or RTF w/DX7 SROlmeda Aircraft - Electric - Helis (FS/W) 1 Mar 07, 2008 09:31 PM
Question Trex 450 se v2 or Trex 600 guitardude007 Mini Helis 11 Oct 29, 2007 11:26 PM
For Sale Hangar 9 61" Sopwith Camel W/ Saito 100, Sale or Trade for Trex 450 SE V2 lcyrace Aircraft - Fuel - Airplanes (FS/W) 1 Jul 25, 2007 12:18 AM
Discussion trex 450 se or 450 se v2?? marsman711 Mini Helis 6 Mar 09, 2007 12:36 PM
