Old Jan 30, 2016, 07:53 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
At the same weight, two motor of different Kv rating use larger or smaller props to adjust the load to the RPM. Any prop increases the load on the motor as it turns faster and reducing the pitch and/or diameter is the only way to reduce the load when that happens.
You mention "maximum pitch speed" as if it were a motor characteristic. Pitch speed is a propeller characteristic and the limit on it would be the prop's RPM limit. And that is usually expressed as something like this:
maximum RPM - APC Thin/Folding Electric = 145,000 RPM / Diameter (inches)
And it relates to the propeller's failure and not the motor. Interestingly enough, APC props are seldom ever used at their max RPM simply because the blades get stalled and inefficient before they get to that high an RPM. Typically, most people don't use them at more than about 2/3rd's of their rated max, you can see that in the testing data at flybrushless.com.
My feeling is that your option 2 is going to call for a smaller prop and that will mean it has less thrust. And that will make it less adept at lifting and hovering and probably slow it down in forward flight. But I defer to your testing the theory.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jan 30, 2016, 11:34 PM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Something.
2slipo around 2.5 w/g
3slipo around 3w/g
4slipo closed to 4w/g
high Kv 1700-2200 4-5 w/g
more high Kv 5-8 w/g
in EDF 8-10 w/g
Something in EDF 10-14 w/g
All cases is necessary test.
manuel v is offline Find More Posts by manuel v
Old Jan 31, 2016, 09:07 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Check out the attached spreadsheet compiled by Dave North for different winds of the Turnigy 2730 Blue Wonder motor. The motor tests are listed in order of increasing motor kV. As the kV changes so does the prop selection to match. In general, as kV increases, maximum power increases, pitch speed (not listed) will increase and efficiency decreases.
Interesting to note that static thrust does not drop off at higher kV/smaller props, but costs more power; less efficient.
leadfeather is offline Find More Posts by leadfeather
Old Jan 31, 2016, 09:33 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Dave North (user timocharis) and Truglodite are just a couple of the real patrons of the rewinding art. Master Man Knitters par excellence for sure!
Dave North / timocharis blog page - http://www.rcgroups.com/forums/member.php?u=31575
Truglodite blog page - http://www.rcgroups.com/forums/member.php?u=142090
Those two blog pages are a gold mine of rewinding info and a history of the art on this forum. If you don't have the M$ Excel spreadsheet software or don't want to buy it, download and install the free OpenOffice.org suite and it will open the *.xls files without any problems at all.
For maximum usability sharing and to spit in M$'s greedy face, keep the *.xls files in the Excel format when you save or use them and then they can be posted here for sharing.
Jack
Old Jan 31, 2016, 02:06 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Not necessarily reduces efficiency.
The motor work is represented by two things, thrust and propeller speed.
Please read this article, the two sections.
use google translator included.
http://aeromodelismoelectrico.blogsp...000-watts.html
Old Feb 03, 2016, 02:35 AM
martin555 is offline
Find More Posts by martin555
http://www.nemesikle.hu
martin555's Avatar
Hungary, Baranya, Pcs
Joined Jul 2011
friends, sorry to interrupt and to ask some basic questions.
after reading and reading this thread I still do not see clearly what is the big deal about this motors, this is also because I come from gas RC planes have little knowledge about electric stuff at all. but in long winter times and the new multicopter thing I started to build tri- and quadcopters.
my question would be simply that I have 4-5 piece of DT750 , the new version, long, threaded shaft, (I already cut it short..) and the straight magnets, stock copper wire winding.
I want this motors for a simple basic 450 quadrocopter. (I also put it in rotorbits tricopter, liked the response, hated the ball bearing replacement.. tricopter yaw tail motor is being shaked by the servo, DT 750 did not like it)
so, but, I built 450 quadrocopter (so that no motor must be shaken by a servo) and liked the DT750 with cheap plastic 10x4.5 or carbon-mixed nylon props WERY MUCH. on 3S 2200mah lipo, hover was 12-14 minutes, power (torque) was always there. I used them with turnigy plush 25A UNFLASHED esc so the esc was for airplane, no simonK or blheli. the response was slow but okay to basic aerial filming with xiaomi yi camera on a basic 9g servo pan tilt stand.
now I have 4x 20A afro ESC and also 4x30A afros, I flashed them all with BLHELI.
I have great hope in these cheap motors, because I built S500 frame multistar elite 2216-920kv motors and used 4S 5400 multistar and have poor performance and "also" 10, max 11 minutes of hower without gimbal without camera.
so question 1 : generally. where is the truth here? how can a 2216 -920 "underperform" a shaky, vibrating, falling-apart, bendy shaft, poor wound Dt750?
-whats the big deal about re-winding the DT750? what would it bring to me? (power efficiency I am looking for)
question 2: I mentioned my afro 20 and 30A esc with blheli.
-what blheli settings do you recommend for DT750, for most efficient smooth flying around , no aggressive sport flying?
-can I use the 4S 5400 multistar with the DT750? (I promise no aggressive full thr! lipo is also low -C it can not deliver very good...)
what prop would be suggested for the DT750? I have a lot of 10x4,5 cheap plastic "leaf-style", also 11x5 thin electric props.
my current settings BLHELI:
https://onedrive.live.com/redir?resi...nt=photo%2cpng
any good info would be greatly appreciated.
martin555 is offline Find More Posts by martin555
lrk-torquemax diy brushless outrunner kit Ron van Sommeren Power Systems 2 Dec 22, 2011 08:45 AM
For Sale hexTronik 24gram Brushless Outrunner 1700kv tallflyer Aircraft - Electric - Power Systems (FS/W) 3 Jul 10, 2007 10:49 PM
English lrk-torquemax diy brushless outrunner site & mailing list Ron van Sommeren Electric Plane Talk 0 Sep 29, 2001 06:57 PM
E-fly-in&diy brushless outrunner meeting, Sept. 2nd, Winssen/Nijmegen,the Netherlands Ron van Sommeren Electric Flight Events 1 Aug 02, 2001 06:37 AM
diy brushless outrunner/LRK meet & E-fly-in, Sept. 2nd, Nijmegen, the Netherlands Ron van Sommeren Power Systems 0 Aug 02, 2001 06:32 AM
