Old Feb 01, 2006, 01:28 PM
Guilherme_VM is offline
Find More Posts by Guilherme_VM
São Paulo - Brazil
Joined Feb 2006
Futaba Skysport 4 schematic / modification
Does anyone has futaba's skysport 4 schematic.
I've one of these radios, but for 40Mhz band. I'd like to convert it to 72Mhz band.
I'll very glad if does anyone could help.
Guilherme
Guilherme_VM is offline Find More Posts by Guilherme_VM
Old Feb 02, 2006, 12:15 AM
imeins is offline
Find More Posts by imeins
imeins's Avatar
Australia
Joined Nov 2002
In about 30 seconds time you should receive the first "oh my golly gosh [sorry flanders almost let it slip there] the FCC are going to take you out and whip you till you die" response. This is obligatory here for anyone (from any country) who even suggests they might open the case of anything electronic.
If you do find a source for circuit diagrams for Futaba gear then I'd be very interested in one for an old gold series 6 ch too.
Cheers, Ingmar
imeins is offline Find More Posts by imeins
Old Feb 02, 2006, 04:09 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
You haven't put where you live in your profile, but from the words you chose I would guess you aren't from the US? If so then FCC regulations won't apply, but of course you should follow the rules in your country.
To change from 40 to 72MHz you need to reduce the capacitance and inductance of the tuned circuits. Unfortunately circuit diagrams don't usually include coil winding details, so you may have to experiment a bit (start by removing about 40% of the turns on each coil).
The best diagram I have is for a Skysport 7, but the Skysport 4 RF circuit should be very similar if not identical. Components that may need changing are C3, L1, C5, L2, C7, C10, L3, L6, C16, C17, L4, C19, L5 and C21.
For tuning you should have at least a frequency counter and rf power meter, or better yet a spectrum analyser. If you don't understand how to use these instruments and what adjustments are needed then I suggest you do not attempt the conversion!
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Feb 02, 2006, 06:49 AM
São Paulo - Brazil
Joined Feb 2006
Thankk you very much Bruce.
It'll very usefull.
Don't worry. The regulations here (I live in Brazil, I'll update my profile) are very similar to that from FCC, but I'm an Eletronic Enginneer and licenced HAM.
I've a frequency counter, RF power meter and other equipments, Unfortunately not a spectrum analyser yet.
I feel more confortable having the schematic, rather than try and error technique.
Have you the receiver' schematic?
Thanks again.
Guilherme.
Old Feb 03, 2006, 12:13 AM
flatfour is offline
Find More Posts by flatfour
Right Honorable Member
flatfour's Avatar
Chicago Midway, Illinois, United States
Joined Jul 2003
These guys sell Futaba 4CH buddy boxes for $30. I realize getting it across the equator might be a bit of an issue...........
http://www.brucknerhobbies.com/Aircraft%20Radios.htm
flatfour is offline Find More Posts by flatfour
Old Jul 16, 2007, 07:04 PM
antonio carlos is offline
Find More Posts by antonio carlos
antonio carlos's Avatar
Brazil
Joined Dec 2005
Originally Posted by Bruce Abbott
The best diagram I have is for a Skysport 7, but the Skysport 4 RF circuit should be very similar if not identical. Components that may need changing...
Bruce, I need the diagram/circuit from Futaba T4YF. Do you have it?
antonio carlos is offline Find More Posts by antonio carlos
Old Feb 07, 2012, 03:43 AM
nige838 is offline
Find More Posts by nige838
United States, TX
Joined Oct 2009
It'll very usefull.
Thanks again.
Guilherme.
Did you ever get a power rating (mw) for the futaba's skysport 4 ?
Thanks...
nige838 is offline Find More Posts by nige838
Need crystal for Futaba Skysport 4 channel transmitter, where to buy?? mike93 Parkflyers 26 Feb 15, 2009 06:50 PM
Help: Futaba Skysport 4, servo reverse switch won't switch back!?!? mike93 Parkflyers 0 Dec 17, 2002 04:40 PM
FS: Futaba Skysport 4 Channel system, $65 chlee Aircraft - Electric - Airplanes (FS/W) 1 Sep 25, 2002 07:23 AM
WTB: Futaba SkySport 4 hans-petter Aircraft - Electric - Airplanes (FS/W) 0 Apr 20, 2002 12:52 PM
Futaba Skysport 4 Tx , is it 6 ch ready? Bleriot Power Systems 12 Sep 21, 2001 02:51 PM
