Old Feb 26, 2015, 05:20 PM
Kevinfred is offline
Find More Posts by Kevinfred
United States, IN, Fort Wayne
Joined Oct 2008
Question
Need to make a nose cone for an F16
I have all the typical ideas but was curious about any sure-fire easy methods. The diameter is about 3/4 the size of a pop can (at the base) and then obviously goes to a point...
Thanks!
Kevinfred is offline Find More Posts by Kevinfred
Old Feb 26, 2015, 05:24 PM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
Cut a piece of roughly shaped foam insert a bolt ( bit of hot glue to keep it in place ) put the bolt into the end of a drill , start the drill and then use sandpaper as it rotates to define the shape.
scousethief is offline Find More Posts by scousethief
Old Feb 26, 2015, 06:23 PM
Joined Oct 2008
that's the type of idea I was looking for! Thank you much...
Wanted Byron F16 nose cone mikes68charger Aircraft - Electric - Jets (FS/W) 1 May 20, 2014 07:38 PM
Wanted Byron F16 nose cone mikes68charger Aircraft - Fuel - Airplanes (FS/W) 1 May 19, 2014 06:59 PM
Wanted Nose cone for Foam Sapac f16 beachflyer Aircraft - Electric - Jets (FS/W) 3 Dec 16, 2011 03:56 PM
Alert i need an Aris nose cone gingin Multi Task F3X 0 Mar 12, 2010 04:57 PM
Making plastic nose cone for hlg GaryO The Builders Workshop 9 Jan 26, 2005 11:59 PM
