Old Dec 15, 2012, 02:25 PM
logair8452 is offline
Find More Posts by logair8452
Joined Jan 2009
Remember the Buzz C engine
I inherited this Buss C engine wayback when. It has seen some rough use as the top fins have been broken. It does seem to have good compression. Does anyone have any experience in running these engines. It was more tha likely ran on glow as the points are missing. It may have been sold new as a glow engine w/o the points. I remember there adds and at one time was thinking about buying one as the price was low. Logair
logair8452 is offline Find More Posts by logair8452
Old Dec 15, 2012, 09:02 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Well the Buzz Motors Company made the Buzz "C" motor in the .342 cubic Inch displacement as a gas ignition engine in 1948. In 1949 they converted it to Glow. But usually the 1949 models had a front end that wasn't machined for a ignition timer unit. Plus the glow model was setup for a 1/4x32 glow plug, and had no built in fuel tank hanging on below the intake tube and needle. Apparently, America's Hobby Center used to advertise them a lot.
My take on it, is to not run the engine as it only has two screws holding the cylinder head on, and there is some risk of the engine blowing its top off because of that. But if you do run the engine, use only FAI fuel, no nitromethane in the fuel and use 80% methanol to 20% castor oil. That would minimize the risk. You might even want to run more oil at maybe 25% oil to 75% methanol too.
Now I have forgotten what prop to use, but if I remember right, the engines tended to run at a fairly leisurely rate. Thus it may have been a 11x6 or 11x7 prop on it at the time. But I could be mistaken after all these years. I was a kid at the time and someone gave me a BUZZ C engine to use at the time. I tried it and I wasn't impressed by it. I liked the McCoy .35 engines or the more expensive Fox 35 engines even more. But it got me through a few weekends of control line flying when I didn't have another engine at the time.
earlwb is offline Find More Posts by earlwb
Old Dec 15, 2012, 09:16 PM
Joined Jan 2009
earlwb
Good info. I would only run the engine just for the experience. Most likely not. Thanks Logair
Old Dec 15, 2012, 11:16 PM
datsunguy is offline
Find More Posts by datsunguy
Joined Jun 2011
Earl
According to Anderson's the Buzz engines were made for AHC by the Judson Company. The were originally ignition engines but went to glow in 1949 and were referred to as "slag" engines. The cylinders were aluminum with no liner. Wore out very quickly.
datsunguy is offline Find More Posts by datsunguy
Old Dec 16, 2012, 07:49 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
At the time I didn't know any better. But it seemed to work OK for me, pretty weak on power though. I didn't use it all that much before I got a better engine. I had my mother sell off a lot of my stuff when I was in the USMC, so it disappeared at that time. So maybe I just got lucky.
But an aluminum cylinder works OK in the K&B Sportster series, except they use a chromed aluminum piston though. So it may be doable if the cylinder has the correct aluminum alloy. Then the utlility gas engines of today all have something similar to a aluminum bore in their cylinders too, with some kind of a silicon/iron coating that wears well too. So it might look like all aluminum but there might be coating or something on the cylinder walls.
Old Dec 17, 2012, 01:31 PM
kenh3497 is offline
Find More Posts by kenh3497
Comfortably Numb
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
"Nickasil" (sp) is one trade name. It is a nickle plating with silicon carbide in it. It has to be honed with a diamond hone. A regular stone won't touch it. I wish all the model engine MFG's would use it.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Dec 18, 2012, 03:41 AM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
It's 'Nikasil', Ken.
And yes, it is a very hard electro-deposited coating that very rarely wears through.
It is, however, sensitive to sulfur in the fuel, which made engines that used it unusable in some countries, in which gasoline contains sulfur in too great a PPM value.
Sulfur simply eats this nickel composite for breakfast...
DarZeelon is offline Find More Posts by DarZeelon
Discussion Mattel Superstar does anyone remember this early electric R/C ARF? willin Electric Plane Talk 187 Aug 25, 2015 11:21 AM
For Sale TWO New In Box Tower Hobbies 40 R/C Engines with mufflers ! Great Schnerle engines shooboy Aircraft - Fuel - Engines and Accessories (FS/W) 1 Oct 28, 2012 10:43 AM
Discussion Remember Remember on the 6th of November ENGINETORQUE Life, The Universe, and Politics 67 Oct 21, 2012 07:43 AM
Help! Remember this r/c car? Was called Hunter.I Need Parts? Lordgalla Electric Power Cars 2 Jul 16, 2007 11:33 AM
Discussion Does anyone remember the Copperhead C/L model for ignition or glow willin Control Line 4 Feb 19, 2006 05:00 PM
