Old Jul 17, 2012, 07:08 PM
D.English is offline
Find More Posts by D.English
Hemet California
Joined Jul 2009
My second mold making project.
I had to show this on my favorite composite site, I learned so much here so I can have all this fun! Thanks to all of you that helped as this stuff is addicting.
The model is a F5D pylon wing designed by PaulS and Biber that I am trying to stuff with state of the art power set up. Will start test flying in about 6 weeks. I will post some finished pics then.
DE
D.English is offline Find More Posts by D.English
Old Jul 17, 2012, 07:15 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Sweet!
wyowindworks is offline Find More Posts by wyowindworks
Old Jul 18, 2012, 11:37 AM
sarmoby is offline
Find More Posts by sarmoby
Composites guy
North OC, Ca.
Joined Jun 2005
Nice back-up structure.
Store those carefully so you don't get any washout/washin.
Looks like a nice, slow airplane............ yeah.
Look up aeroelastic tailoring and think about your ply angles as you have a swept wing.
I recall I was not smart enough to get the ply orientations under control but think about what you want the tips to do when you pull 30 g around the pylon( wash in or out).
Cool
sarmoby is offline Find More Posts by sarmoby
Old Jul 18, 2012, 03:07 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Scott, the wing you see is a mule, the finished will be all carbon. Go Dave!!
I have a Hangar queen hanging in my office...
Troy is offline Find More Posts by Troy
Latest blog entry: Flying Ghost
Old Jul 18, 2012, 04:19 PM
sarmoby is offline
Composites guy
North OC, Ca.
Joined Jun 2005
So, I assume it is a bit quick?
I assumed the wing was going to have carbon skins. The question is what do you want the wing to do when you are bending it? keep the angle of attack the same as the un-belt wing, not bend or something else?
The X-29 used this concept of aeroelastic tailoring by making a non-symmetic lay-up that induced a non-orthogonal [B] matrix in the laminate analysis. In the real world this will make the part curl when it is bent which limited the angle of attack(alpha) at the tips under high g loadings.
Since you KNOW you will be bending the wing alot, what do you want it to do in that mode?
If you just want it to be stiff and reduce deflection, ( I am assuming you are only pulling high positive G's), then the upper skin compression stiffness is important.( may consider a intersection of the main spar and drag spar- also consider what type of fiber on the compression side of the main spar- I may have a part(which crashed) which could be "donated" for a trial if you are interested that has some autoclave cured Hybor in it.
To keep the swept wing from torsional oscillations the angle of the fabric will be important.
You may or may not see this depending on the wing stiffness and sweep.
Sorry for the off-topic tangent. You boys and your silly toy planes.....
Scott
Old Jul 18, 2012, 04:31 PM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
Dave,I know why did You start this thread for .
You need this thread as inspiration for You to finally finish damn wing
....use to do same things myself
Awesome looking "hangar queen" Troy.
Yuri,wingless.....
Dbox is offline Find More Posts by Dbox
Old Jul 18, 2012, 05:08 PM
DownUnderPilot is offline
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Very cool project. There would be a market for such a plane, I'm sure it would sell well. Not many commercially available pylon wings! Yuri?
DownUnderPilot is offline Find More Posts by DownUnderPilot
Old Jul 18, 2012, 05:23 PM
Dbox is offline
Dbox's Avatar
Joined Jun 2005
I would not have problems to put this wing in to production.
....But it is initially not my "baby"
Yuri.
Old Jul 18, 2012, 07:05 PM
Hemet California
Joined Jul 2009
Yuri, I took almost a year off to build my wife a car that I promised her ten years ago. Now I can build all I want and not feel guilty. Now its mubu full speed ahead!
Scott, Thanks. I could lengthen the drag spar to the main spar. I think I want everything to stay pointed in the right direction. I have gotten a suggested lay up schedule from the designer and it includes fibre oreintation. The good part is if it blows up I can make another.
DE
Old Jul 18, 2012, 09:36 PM
Dbox is offline
Dbox's Avatar
Joined Jun 2005
3 stage two tones WOW !!!!
Your wife has to have matching manicure from now on
You hired Dave
Yuri.
Old Nov 29, 2012, 05:47 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Dave,
Your work is some of the finest I've seen, question on the ability for the prop to fold when mounted tractor rather than pusher. Will it work or interfere and get jambed on the LE?
ApexAero is offline Find More Posts by ApexAero
Old Nov 29, 2012, 02:16 PM
Hemet California
Joined Jul 2009
Thanks Apex,
I tried a simple small wire that helped the prop out a little and then the sweep of the wing let it smoothly slide open.
This project has been tabeled for a while as PaulS who was part of the design team for the wing and sawtooth prop and I are working on a new F5D model, It is very different than anything out as of yet, fingers crossed.
DE
Old Dec 02, 2012, 07:37 PM
Schoolya is offline
Find More Posts by Schoolya
Schoolya's Avatar
United States, FL, Mayo
Joined Jul 2012
Is that all the info we get. I am working on a foam cored mubu now. Should i stop?
Schoolya is offline Find More Posts by Schoolya
Old Dec 03, 2012, 10:43 AM
Troy is offline
Troy's Avatar
Joined Feb 1999
I would keep building. I have my Mubu test airframe about 3/4 done but have been working on some other things for Dave and the project. I also had another project to finish ahead of the Mubu. I actually scratch built a Mubu way-back-when using foam cores and balsa skins and it flew well with modest power. I had a radio failure in flight which destroyed the model.
http://static.rcgroups.net/forums/at...Bumm%20027.jpg
http://static.rcgroups.net/forums/at...Bumm%20030.jpg
Old Jan 01, 2013, 02:56 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Nice piece of work in this plane.
Any progress reports?
I think it is a good inspiration for a sloper.
Jim.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Discussion My home make Nednaca-E01 Project pcomud UAV - Unmanned Aerial Vehicles 8 Oct 20, 2012 01:51 AM
Discussion CBM F16 Thinking about Making a Mold unclecrash Electric Ducted Fan Jet Talk 11 Jul 08, 2012 12:07 AM
Discussion Help in making a rhino mold thebaconbits CAD/CAM 7 Feb 27, 2012 01:14 PM
Thought you might like to see my second composite project I'm Rick James Composites Fabrication 16 May 31, 2005 12:38 PM
