Old Aug 07, 2010, 01:02 PM
hondarider98 is offline
Find More Posts by hondarider98
hondarider98's Avatar
Canada
Joined Jul 2010
Traxxas 1/16 E-Revo
Hello everyone i was wondering if this is proper for the mini e-revo.
Can the toe links be adjusted? The tires are really pointed towards the body. When i drive it it looks broken. Drive it forward it goes straight, go in reverse and it will back up at a angle because one of the rear tires are toed in more than the other. Are the traxxas aluminum toe links adjustable?
hondarider98 is offline Find More Posts by hondarider98
Old Aug 07, 2010, 08:18 PM
jettrooper02 is offline
Find More Posts by jettrooper02
jettrooper02's Avatar
USA, WA, Bonney Lake
Joined Aug 2008
well, as odd as it sounds they are supposed to be angled in a lot, and i don't think they are adjustable.
jettrooper02 is offline Find More Posts by jettrooper02
Old Aug 08, 2010, 07:04 AM
Redfisher is offline
Find More Posts by Redfisher
Nice day for RC'ing
Redfisher's Avatar
Palmerston On. Canada
Joined Jul 2010
My 1/16 vxl slash was like that to, helps it track straight.
Redfisher is offline Find More Posts by Redfisher
Old Aug 08, 2010, 01:05 PM
Duster_360 is offline
Find More Posts by Duster_360
Texas
Joined Aug 2006
Toe is not directly adjustable or separately adjustable. Toe is affected by the camber adjustment to some extent. Camber is the angle the wheel makes with teh vertical. These are set to have neg 1degree camber which means looking at the tire from the bacl, it should lean in toward the chassis 1degree. If you have a manual, its covered on pg22. If you don't have one, here's link to it -
http://www.traxxas.com/PDF-Library/7007_7107_manual.pdf
Yours looks normal to me. I haven't seen anyone offereing adj toe links for the mervo.
Duster_360 is offline Find More Posts by Duster_360
Old Aug 08, 2010, 01:16 PM
Texas
Joined Aug 2006
Here's a few pics of mine -
and
Old Aug 10, 2010, 02:58 PM
Canada
Joined Jul 2010
If you adjust the camber it really helps out with going straight. The rear wheels really needed it.
Old Aug 10, 2010, 08:20 PM
Texas
Joined Aug 2006
I need to adjust mine - you can see they are not even from one side to the other. Looks like the right rear has too much toe.
Old Aug 11, 2010, 03:05 PM
EvgenUA is offline
Find More Posts by EvgenUA
Ukraine
Joined Mar 2010
actually i don't really understand what's the problem?
take the key and turn pivot balls until you get what you want
i have a gpm turnbuckles and pushrods. steel and aluminum ones (steel is more durable). everything is adjustable.
but i don't need to adjust them - i can make the wheels stand straight only by screwing pivot balls into a-arms (that's why stock ones are non-adjustable)
EvgenUA is offline Find More Posts by EvgenUA
Old Aug 14, 2010, 02:57 AM
2sicMiniT is offline
Find More Posts by 2sicMiniT
Under Warranty!
2sicMiniT's Avatar
Washington State
Joined Feb 2006
Steal TB's are more durable but with the power that the e-revo puts out you will still bend them. Once that happens there is no turning back.
As far as your toe problem. (tough actin tinactin) J/K. I hate the way that it looks. Not going to argue whether or not the car needs it or not. But, I have mine straightened out a whole lot more than stock. Using the GPM TB's myself as well. If you want to get rid of it all together go to your local hardware store and just get some long stainless steel screws and cut them down and make your own. That is my next step when they bend too much.
2sicMiniT is offline Find More Posts by 2sicMiniT
Old Aug 14, 2010, 05:47 PM
Under Warranty!
2sicMiniT's Avatar
Washington State
Joined Feb 2006
BTW,You will have to have to use the ends from the GPM TB's in order to use the method I mentioned. I did this with my mini-t and they turned out to last longer than my titanium turnbuckles.
For Sale Sportwerks Recoil Pro, 1/16 E-Revo VXL Modified, LST2 Brushless lafuerza Cars - Trucks and Parts (FS/W) 2 Aug 30, 2010 01:01 PM
Discussion 1/16 E-Revo Lipo Battery Packs hondarider98 Car Talk 7 Aug 11, 2010 03:24 PM
Discussion 1/16 E-Revo Lipo Battery Packs hondarider98 Batteries and Chargers 2 Aug 02, 2010 04:30 PM
Sold Traxxas 1/16 E-Revo VXL Brushless F/S/T >> Jato 1/10 & E-Revo look here! phantomette Cars - Trucks and Parts (FS/W) 13 Jan 11, 2010 12:43 AM
Sold SUPER CLEAN Traxxas Nitro 2.5 Revo...$299 SHIPPED2U! (will trade 4 E-Revo VXL 1/16) bighank13 Cars - Trucks and Parts (FS/W) 0 Dec 26, 2009 05:04 PM
