Old Apr 27, 2016, 08:23 AM
ncflyer79 is offline
Find More Posts by ncflyer79
ncflyer79's Avatar
United States, NC, Marion
Joined Jun 2011
New Product
Phoenix Models Stuka GP/EP ARF
Saw this on Tower Hobbies website today and thought it looked decent. I already have the stuff from my crashed Seagull P47 to go inside of it.
http://www.towerhobbies.com/products/pmm/pmma0380.html
Wingspan: 75.2 in (1910 mm), Wing Area: 936 in² (60.4 dm²), Wing Loading: 26.5 oz/ft² (81 g/dm²), Weight: 10.8-11.9 lb (4.9-5.4 kg), Length: 60 in (1522 mm), Requirements: 6+ channel radio with 9 standard servos, 2-stroke 1.20 or 4-stroke 1.40 glow engine or 20 cc gasoline engine or RimFire™ 1.20 outrunner brushless motor, 120-160A ESC, 5-6S 5500-6000mAh LiPo battery and charger, 4.8-6.0V 1200-2000mAh NiMH battery and Propeller
ncflyer79 is offline Find More Posts by ncflyer79
Old Apr 27, 2016, 11:16 AM
SJ is offline
SJ
Find More Posts by SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
Looks exactly like the black horse stuka
SJ is offline Find More Posts by SJ
Old Apr 27, 2016, 01:13 PM
Thrawn150 is offline
Find More Posts by Thrawn150
Thrawn150's Avatar
USA, IL, Oak Lawn
Joined Apr 2007
did Black horse have the EP setup?
Thrawn150 is offline Find More Posts by Thrawn150
Old Apr 27, 2016, 06:13 PM
otherhalf2 is offline
Find More Posts by otherhalf2
New Zealand, Marlborough, Blenheim
Joined Jun 2012
This model is covered here
http://www.rcgroups.com/forums/showthread.php?t=2636531
otherhalf2 is offline Find More Posts by otherhalf2
Old May 10, 2016, 07:47 AM
panzercreation is offline
Find More Posts by panzercreation
TSHobbies
panzercreation's Avatar
Georgia
Joined Jun 2010
yes, in glow...see no harm for a thread here for electric too
panzercreation is offline Find More Posts by panzercreation
Old Jun 01, 2016, 09:08 PM
JurassicJet is offline
Find More Posts by JurassicJet
JurassicJet's Avatar
United States, WI, Chetek
Joined Jul 2011
I purchased one of these about a week ago. Not bad for the money. All wood construction.
One of the things that struck me as odd is the fact that the covering is essentially a printed sticker. The panel lines, inspection panels and some major rivet areas are on the covering. One thing I did find out, much to my horror, is that either CA or the kicker for CA removes the color from the covering. Luckily, I discovered this on the bottom of the wing, so hopefully a little airbrushing will make it virtually unnoticeable.
Plan on making mine electric (like all of my planes) with hopefully 6 cell power. Plenty of room in the cabin for batteries.
JurassicJet is offline Find More Posts by JurassicJet
Old Jun 01, 2016, 09:16 PM
ncflyer79's Avatar
Joined Jun 2011
Nice!! I have Tacon power 60 (50-65-400kv) that I'd like to try on this bird if it's enough. I have all the servos, ESC, receiver, etc... Just kinda waiting on a report of the all up weight
Old Jun 01, 2016, 10:00 PM
Joined Jul 2011
Have you used the Tacon motors before? Wondering how they hold up. I was thinking about putting a Hyperion ZS4025-14 380Kv in it but not sure if it will be big enough. I have that setup in a slightly smaller Corsair and it works fine, but this bird will be a little heavier. Will have to do some testing tomorrow with props and my E-meter.
I would like to give Suppo a try, but need to find a good vendor (not the one in Colorado). I have been using Motrofly motors which are absolutely awesome, but the pricing has gotten up there so far that I am having a hard time justifying them.
Old Jun 02, 2016, 06:35 AM
ncflyer79's Avatar
Joined Jun 2011
Yeah Iv used Tacon motors before and they work great! The more im reading on this plane the more im starting to think that a Eflite power 60 470kv would be the perfect fit.
Old Jun 02, 2016, 07:02 AM
Terminater is online now
Find More Posts by Terminater
Terminater's Avatar
Australia, SA, Adelaide
Joined Apr 2014
I use a Turnigy G110 295kv on 8s with either a 17x10 2 blade apc or 16x10x3 blade master airscrew and it flies great :
Terminater is online now Find More Posts by Terminater
Old Jun 04, 2016, 01:07 PM
lokigrac is online now
Find More Posts by lokigrac
lokigrac's Avatar
United States, CO, Thornton
Joined Apr 2007
Terminator. What ESC are you using?
lokigrac is online now Find More Posts by lokigrac
Old Jun 04, 2016, 05:54 PM
Terminater's Avatar
Joined Apr 2014
Using Turnigy Sentilon V4 100A 5-12s HV Bulletproof Speed Controller w/RPM Sensor
with a HITEC SUPER SERVO S-BEC, REGULATES 3-14S LIPO TO 5.2 / 6 / 6.8 / 7.4/ 8.4 V
http://www.worldhobbies.com/product/...ref_cat_id=BMB
http://www.hobbyking.com/hobbyking/s...PM_Sensor.html
Old Jun 06, 2016, 03:49 PM
lokigrac's Avatar
Joined Apr 2007
Terminator. I am asking this as a relative newby and because I want to understand the reasoning and the process. Why did you select a 295kv motor as opposed to the 450kv that is recommended in the instruction manual ?
Old Jun 06, 2016, 05:50 PM
Joined Jul 2011
I will attempt to answer for him Lokigrac. If you go down in Kv, you usually can go up in voltage (cell count) to get the added RPM out of it. Lower RPM allows you to turn a larger propeller, which is more efficient.
So a 450Kv motor on 6 cell will give you about 9990 rpm (22.2 volts X 450). Terminator's setup yields 8732 RPM. BUT, the lower Kv can turn a larger prop and be less taxed than trying to turn a (also relatively large) prop at 9990 RPM.
Hope that makes some sense.
Also, I generally use 2 cell LiFe packs for the radio to eliminate the lipo and voltage regulator. Just use the LiFe pack. Easy peasy, but Terminator's setup works just fine too.
Old Jun 07, 2016, 01:22 AM
lokigrac's Avatar
Joined Apr 2007
Thanks, JurrasicJet. So the 295kv at 8s allows him to use the 17x10 2 blade or the 16x10 3 blade prop whereas using the 450kv motor would require the recommended 16x10 2 blade prop at 5-6s (or a 15x10 3 blade). And it also saves him quite a bit of money
Review Phoenix Models Ryan STA GP/EP ARF 70.8" Review Michael Heer Scale ARF/RTF 11 Jun 28, 2016 09:36 PM
Discussion Phoenix Model Edge 540 .91 GP/EP ARF 65" jobinseattle Sport Planes 30 Jun 04, 2016 05:35 PM
Review Phoenix Model and Tower Hobbies 1/5 MXS Aircraft GP/EP ARF Michael Heer Sport Planes 5 May 25, 2016 10:56 AM
Review Tower Hobbies Exclusive: Phoenix Model Sbach Aerobatic GP/EP ARF 55.3" Review kingsflyer Scale ARF/RTF 8 Jan 19, 2016 02:47 PM
Discussion Phoenix Model Edge 540 .91 GP/EP ARF 65" jobinseattle Giant Electric Planes 0 Oct 22, 2015 05:43 PM
