Old Mar 11, 2016, 02:09 PM
FOGeologist is offline
Find More Posts by FOGeologist
Flying again - 4th time
FOGeologist's Avatar
United States, CO, Frederick
Joined Jan 2016
Guidance needed - control horn broken on PZ P51 UMX
I've flown my P-51 UMX bird now about 17 times - in the last 3 flights, I've crashed it a couple-five times or so. I have a replacement nose cone on the way, and a wing...
But the rudder control horn is broken and I don't know what to do. Any hints or suggestions?
FOGeologist is offline Find More Posts by FOGeologist
Old Mar 11, 2016, 03:51 PM
cmdl is offline
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
Horn is broken by itself or separated from the rudder?
Former: You can epoxy it back together.
Latter: You may want to ask here what glue is best. I'm guessing epoxy or CA should be fine but ask them.
It also helps if you post pics.
cmdl is offline Find More Posts by cmdl
Old Mar 11, 2016, 09:05 PM
Joined Jan 2016
I'll post pics soonest - good call.
The horn disappeared after I wound down the battery so far that it couldn't handle the sudden, 15 knot gusts that came out of nowhere right at that second (I know, I know) and I crashed the bird into my neighbor's truck. Weird, huh? No damage to the tail - just a broken horn.
Old Mar 11, 2016, 09:19 PM
cmdl is offline
cmdl's Avatar
Joined Jan 2012
Fyi, don't fly the cell too low. Make sure the voltage is >= 3.7volts unloaded at the end of each flight.
Old Mar 12, 2016, 06:59 AM
OldRCNut is offline
Find More Posts by OldRCNut
Still Flying
OldRCNut's Avatar
United States, WI, Fond du Lac
Joined Mar 2013
Control Horn
Make yourself a new horn. Cut it out of a milk container or similar plastic that is stiff but slightly flexable so you can get it together. Look around for packaging or a container like a freezer container you can cut up. Glue it in place with Go2glue or gorilla glue. Do not use CA as it will not stick to the plastic very well.
OldRCNut is offline Find More Posts by OldRCNut
Old Mar 12, 2016, 11:03 AM
Joined Jan 2016
Originally Posted by OldRCNut View Post
Make yourself a new horn. Cut it out of a milk container or similar plastic that is stiff but slightly flexable so you can get it together. Look around for packagingq or a container like a freezer container you can cut up. Glue it in place with Go2glue or gorilla glue. Do not use CA as it will not stick to the plastic very well.
OK - That seems like a great idea. Thanks!
Discussion umx pitts broken control horn scole Electric Plane Talk 5 Aug 25, 2015 11:09 AM
Discussion Pz Sport Cub S2 Control Horns Shadowecho Electric Plane Talk 1 Jun 10, 2015 03:36 AM
Sold PZ UMX Spit, P51, E-Flite Carbon Cub SS BattleDude Aircraft - Electric - Airplanes (FS/W) 2 May 01, 2013 08:18 PM
Wanted couple of PZ UMX P51/Corsair 8.5mm motors with gearbox karfrik Aircraft - General - Miscellaneous (FS/W) 0 Jan 08, 2013 08:12 PM
Wanted wanted broken micro PZ P51 elkhunt1 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Aug 23, 2010 09:42 PM
