Old Mar 10, 2013, 11:14 PM
BiggyBoy is offline
Find More Posts by BiggyBoy
EDF's Really Blow !!!
United States, KS, Wichita
Joined Mar 2011
HobbyKing EPO, 70mm F-86 EDF Jet, PNF, Electric Retract - Problems & Mods Tread.
I wanted to start this Thread - because all the other threads on the Foamy EPO, 70mm F-86 EDF Jet - Seem to refer mostly to the older Venom model with Air Retracts, which has a Different motor, servo's, ESC, Ect. So It's really not the same Jet in that respect - it dosen't have the same problems and issues as the HobbyKing Model. I do understand that many of the Mods for this jet are the same, so sharing between the two threads is more then welcome.
BiggyBoy is offline Find More Posts by BiggyBoy
Old Mar 10, 2013, 11:21 PM
BiggyBoy is offline
Joined Mar 2011
Description:
Old Mar 10, 2013, 11:47 PM
BiggyBoy is offline
Joined Mar 2011
Has anyone installed a Changesun 10 blade EDF and still used the stock Motor?
If so; what amps did it pull, can you keep using the stock ESC. Will the motor last long with the added stress of the 10 blade?
Old Mar 14, 2013, 08:14 AM
BiggyBoy is offline
Joined Mar 2011
Closing this thread - There is already a thread on this subject at this link: http://www.rcgroups.com/forums/showthread.php?t=1506367
New Product Hobbyking F-86 EPO 70mm EDF with retracts, flaps and airbrakes Tartago Electric Ducted Fan Jet Talk 45 Feb 15, 2014 04:52 PM
Discussion F-86 The Huff EDF Jet 70mm Electric zeroback Foamy EDFs 11 Jan 26, 2013 06:56 PM
Discussion HobbyKing Mig-15 EDF Jet 70mm Electric Retracts, Flaps, Airbrake e_lm_70 Foamy EDFs 9 Jun 02, 2011 12:23 AM
Discussion Starmax Mig-15 EDF 70mm Electric Retracts, Flaps, Airbrake, EPO @Hobbyking jbc Foamy EDFs 2 Jun 02, 2011 12:21 AM
