Old Yesterday, 10:21 AM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Disclaimer: OT
EUROFIGHTER, Low Level Speed Flight! - HD 50fps (18 min 20 sec)
SU-4ever is offline Find More Posts by SU-4ever
Old Yesterday, 03:44 PM
SU-4ever is offline
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Question:
Do I need to upgrade my ESCs if I am getting HV LiPos?
Say, for instance, I want to use Revolectrix Blend 435 on the SU-35S with YEP 80 ESCs.
Will that be okay, or will the ESCs mishandle the extra tension?
Old Yesterday, 06:16 PM
PAPE is offline
Find More Posts by PAPE
Joined Jun 2012
Originally Posted by SU-4ever View Post
Question:
You will be fine with the yep or any other ESC, the higher voltage lipos are only a little bit higher. The real advantage is that under power the nominal voltage is higher, so yes it will pull a little more amps but nothing to go changing your esc's. the difference is like going from a 30c pack to a 60c pack, under power voltage is held higher thats all.
on a side note, love your videos, but man that music is really bad, I always have to watch your videos on mute...
PAPE is offline Find More Posts by PAPE
Old Yesterday, 07:36 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Nose leg lateral support
After investigating the nose leg I decided there is no way to give it better lateral support....
Because the steering arm is quite thick, and the bay doors are quite thick, there is just no room left to add anything substantial to support the leg laterally.
It could probably be done with a 2mm/2.5mm alloy plate, just below the steering arm, if the bay doors were made thinner. But then it would need to be done so that the brace does not hit that either (when the leg stores). So all in all it is not really viable to do anything of good use.
Just Longitudinal support via the brace will have to do.....
PeterVRC is offline Find More Posts by PeterVRC
Old Yesterday, 09:21 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Question:
some of the Freewing 6S ESCs have given some problems saying they won't work with fully charged 435s. When they are charged at lower voltages 4.2 etc that has worked for them.
Yep is supposed to be a little more overspecd so you should be fine with them. I would go HV ESC if you can though.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Today, 12:06 AM
SukhoiDan is online now
Find More Posts by SukhoiDan
'Slick'
SukhoiDan's Avatar
Australia, QLD, Carbrook
Joined Mar 2016
Hey Tube guess what i just pulled the trigger on the tundra im stoked!!! Cant wait it was on backorder but they apparently have fresh stock every 30 days, rc groups plane of the year here i come... thanks for the advice bud
SukhoiDan is online now Find More Posts by SukhoiDan
Old Today, 12:07 AM
'Slick'
SukhoiDan's Avatar
Joined Mar 2016
guess i better start on the tundra thread
Old Today, 12:54 AM
PeterVRC is offline
Joined Nov 2006
Plane of the Year???
Old Today, 03:49 AM
'Slick'
SukhoiDan's Avatar
Joined Mar 2016
Terry Awards 2016 - RCGroups com (3 min 49 sec)
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
