Old Jul 29, 2014, 04:07 AM
Germany, HE, Frankfurt
Joined Nov 2013
Hobbyking Specter 1800mm or Deamon Electric Sailplane Composite 2000mm
Hi!
I'm thinking about buying a new glider. which should I take?
http://hobbyking.com/hobbyking/store...dproduct=53913
or
http://hobbyking.com/hobbyking/store...dproduct=52797
I've got some experience in building models and i want a easy to transport glider, but no foam.
Best regards
Christian
christian0007 is online now Find More Posts by christian0007
Old Jul 29, 2014, 09:14 AM
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Looks like the same glider, just 200 mm difference. that means that there is only a 100 mm difference in the length of each wing, about 4". So you have to decide if that matters for your storage or transport.
I would normally go for the larger span for better visibility in thermals.
aeajr is online now Find More Posts by aeajr
Old Jul 29, 2014, 10:15 AM
Joined Apr 2012
Hi, Christian.
I have a Specter but it's from an earlier production run than currently offered. I really enjoy it and there were only a few minor issues to fix. The provided pushrods needed to be replaced and I needed to rework the servo mount and actually grind the corners off my ruddervator servos to fit in the fuselage. It's also a bit heavier than HK claims and I suspect that they weighed theirs without a battery.
From what I have read about the new batch it sounds like they share the same minor problems. It also appears that they changed the location of the aileron servos so one needs a little creativity to achieve a good fit and, more disturbing, several people have received twisted fuselages. It's not insurmountable but one needs to be aware of Chinese QC issues.
In return one ends up with a very capable general purpose glider. It has a wide speed range, responds to light lift, and I feel comfortable flying mine in high winds. It's also tough as nails and has survived two props breaking at full throttle and a bounce off a tree followed by a 20 foot dead drop straight on the nose.
I have not seen a Daemon in person and there seems to be less information available but I would guess that it has the same issues. As aeajr said the only real difference seems to be a few inches in span.
Cheers!
peterlngh is offline Find More Posts by peterlngh
Old Jul 29, 2014, 10:22 AM
Joined Nov 2013
Thank you for this assessment. The only difference really seems to be the span. what the quality is concerned, I'm not sure if there is nothing better for that price. to read more from the fact that the hull is not quite in order. there is still more to experience?
Build Log Hobbyking Dragonfly 1800mm balsa composite electric sailplane Matty12 Electric Sailplanes 151 Sep 14, 2014 01:19 PM
For Sale Deamon Electric Sailplane Composite 2000mm (ARF)<<<LPU>>>> ED3 Aircraft - Electric - Airplanes (FS/W) 7 Jan 23, 2014 09:40 PM
Discussion HK Sukhoi Su-26 Aerobatic Composite 20cc -1800mm ltb Fuel Plane Talk 11 Dec 02, 2013 03:02 AM
Sold Sharon 3.7 Sailplane for trade for Electric Heli or cash roboto65 Aircraft - Sailplanes (FS/W) 2 Sep 30, 2013 05:56 PM
Sharon 3.7 Sailplane for trade for Electric Heli or cash. roboto65 Non R/C Items (FS/W) 0 Sep 28, 2013 08:53 PM
