Old Jul 12, 2014, 05:09 AM
RBS
Auckland. New Zealand
Joined May 2007
Question
Katana 46 v2 cog
Hi all. According to the manual a cog 5.25 inches (133mm) back from the leading edge is a good place to start. I'm about to set it up at this with an empty tank. Should I believe the manual. Any advice would be appreciated.
RBS is offline Find More Posts by RBS
Old Jul 25, 2014, 06:05 AM
Australia, ACT, Canberra
Joined Dec 2011
Hello. I have an older Accel hobbies ( I think that's the brand) 46 Katana (48" wing) and I've got it balanced at approx. 5" back from the LE and it's a bit nose heavy. I'm just getting used to it and intend on moving it back a bit once I get used to it.
I'm assuming you are talking about the TM Pro Katana.
NOI53Y is online now Find More Posts by NOI53Y
Old Aug 20, 2014, 05:01 AM
RBS
Joined May 2007
Thanks for the reply regarding the Katana cog. It is a TM Pro. I Haven't flown mine yet. How are you getting on with yours. Still in one piece?
Old Aug 20, 2014, 07:25 AM
Joined Dec 2011
Hey mate,
You need to get yours up in the air. Mine is seriously fun to fly. Mine is a bit over powered with a YS 63 fz 4 stroke on it. Full throttle take off and she's off the ground in around 2 meters haha. Flying is done at about 1/2 throttle and it'll go out of site vertical on full
As for the balance I moved it back a small amount. Not much but now it is pretty much neutral. You can go inverted and not touch the sticks.
It's a fun thing mine and I'm pretty sure the TM pro is identical to mine except yours will have a 2 piece wing whereas mine is glued in.
For Sale OMP Katana V2 46 profile r/c airplane. Mint in box. Outlawtjet Aircraft - Fuel - Airplanes (FS/W) 0 Nov 17, 2013 06:42 PM
Sold Katana 46 V2 Profile w/gear - $100 Dukester Aircraft - Fuel - Airplanes (FS/W) 0 Feb 24, 2008 08:47 PM
Discussion TMPRO Katana V2 46 E-converstion furyflyer2 3D Flying 6 Dec 09, 2007 09:42 AM
For Sale Ohio Model Products Katana V2 .46 (RTF)$225.00 gjhinshaw Aircraft - Fuel - Airplanes (FS/W) 0 May 14, 2007 08:31 AM
For Sale Ohio Model Products Katana PRO V2 .46 Chickenfoot Aircraft - Fuel - Airplanes (FS/W) 1 Jun 17, 2006 09:54 AM
