Old Mar 22, 2013, 06:32 AM
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
RA microfilm as trim
Has anyone got a method of using RA microfilm over itself for trim? I'm used to Ultracoat over itself, trim monokote, etc. But RA is so thin it doesn't seem feasible to overlay a precut piece onto another sheet?
Any suggestions? I've done some masking and painting with Gordon's frisket masks but that's not a great solution either.
Pete
Petefoss is offline Find More Posts by Petefoss
Old Mar 23, 2013, 10:33 AM
Carbondale PA
Joined Aug 2005
Pete,
I have done it many times with great results. I just use a glue stick to apply the trim. Then smooth out it with your fingers.
Joe.
Joe Malinchak is offline Find More Posts by Joe Malinchak
Old Mar 24, 2013, 10:53 AM
Petefoss's Avatar
Joined Aug 1999
How do you keep it flat Joe to cut it? Static electricity, a spritz of water on the cutting board?
Old Mar 24, 2013, 09:34 PM
Carbondale PA
Joined Aug 2005
Pete,
I place the film on my cutting board and cover it with wax paper. Then I use a fresh #11 blade to cut out my trim.
Old Mar 25, 2013, 06:13 PM
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
I've applied the second layer of trim with 3M77 and it seems to work pretty well. The insignias on my Cartoon Nieuport 17 were done this way.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Mar 27, 2013, 10:34 AM
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
This reply is somewhat off topic, but a good hint to tuck away.
I substitute Depron for balsa when making wing ribs on some planes to effect lightness. No problem if its going to be covered with tissue, but for planes covered with RA, it's a big problem.
Therefore, I reduce the outline of the Depron ribs by 1/16 all around, then cap the ribs with strips of 1/16 balsa. Now, when covering with RA, a quick pass with the iron adheres the film without melting the foam.
356Jim is offline Find More Posts by 356Jim
Old Mar 27, 2013, 03:37 PM
Boston, Mass
Joined May 2001
Jim,
Nice technique. Do you think it would work with 1/32 balsa strips for a bit less weight? Do you punch holes in the Depron ribs to lighten them?
Gordon
Old Mar 28, 2013, 11:59 PM
Joined May 2001
Originally Posted by Gordon Johnson View Post
Jim,
Gordon
Gordon, it depends on the chord thickness whether I poke holes in the Depron. Usually, the weight saved isn't worth the loss of strength.
As far as using 1/32 cap strips, I haven't tried it, but glue a strip onto a scrap of Depron and run your sealing iron quickly over it. When I applied the 1/16 strips, I found that a little less than 400 degrees F would still adequately bond the RA to the wood. (The English use of the term "timber" just popped into my mind!!). But realistically, unless you're going for really low wing loading (and you're the king, here), I'm not sure the weight saving adds up to a whole lot.
As always, YMMV !!
P.S., my current project is to make a 16" wingspan mostly-scale rendition of the Chance Vought V-173 "Flying Pancake", using mostly Depron, along with judicious use of Balsa for spars and rib cap strips and a leetle-bit of carbon. I will use this method of RA over Depron to the max. Just for nostalgic sense - and strength - I plan to laminate the whole outline from several strips of soaked balsa.
I have blown up a very scale-like Peanut scale plan. I'm thinking of using two 4000 Kv AP03's turning scale-modified GWS 5x3 three bladed counter-rotating props, driven by a DelTang Rx with twin-steering. Geting the CG at about 18-20% is going to be a challenge here, as I always hate to use bigger than necessary LiPo cells just to balance!!
Old Mar 29, 2013, 07:56 AM
Petefoss's Avatar
Joined Aug 1999
Very cool Jim. Can you post your plans as you work out the details?
Old Mar 29, 2013, 10:18 PM
Joined May 2001
I certainly will right after Easter, I plan to get back to my drawing board and sketch some equipment placement and control setups to get the CG close right off the bat.
Discussion DLE 55 side ex. vs ra 19pointbuck Engines 4 Feb 01, 2013 06:17 AM
Question UltraCote as trim? Fly Wheel Painting and Finishing Tips 2 Mar 10, 2011 10:23 PM
Found Looking for a Sealing Iron & Trim Iron (as combo) flustercluck Aircraft - General - Miscellaneous (FS/W) 2 Jan 21, 2011 06:23 PM
Discussion Microfilm Feeddacat Indoor and Micro Models 16 Feb 02, 2007 09:24 PM
