Old Jan 03, 2015, 11:04 AM
United States, TX, League City
Joined Jun 2008
Build Log
Boeing 747-8 build
This will be a hybrid build so it has a mixture of materials in it. Approximately 1:36 scale which breaks down to approximately 7ft long by 6.25ft wing span
The plan so far are:
EPP foam fuse formers
Depron foam skins for fuse
Balsa sheeted over depron
Finishing epoxy coated sanded and then painted
The wings will be EPP ribs
2 ply spars with CF reinforcements
Depron foam skin over wings
Balsa layered over the top
Spoilers, Krueger, simple fowler flap plus split fowler flaps
(EPP formers "should" provide me some flex for added cool factor)
Electronics:
2-4 XRP 14 blade fans with 2300kv motors
Unknown count of servos
2 sets of turnigy oleo airline retracts
Sound module maybe
Gear doors
60a esc 2-4
Navi lights
That's all I have so far, I'm winging it to see how everything goes together, wings will probably be plug in wings or the normal split wings.
It should weigh next to nothing so it'll make for a very nice floater
hi2nr is online now Find More Posts by hi2nr
Old Jan 03, 2015, 11:18 AM
Concordefan2's Avatar
Joined Jun 2013
Another Queen in making!, sweeet.....
Like your scale very much.
Concordefan2 is offline Find More Posts by Concordefan2
Old Jan 03, 2015, 11:25 AM
3 holes are better than twoo!
727Dream's Avatar
United Kingdom, England, Potters Bar
Joined Dec 2008
yeap.....another beauty on the way......
727Dream is offline Find More Posts by 727Dream
Old Jan 03, 2015, 12:14 PM
747-400
alaska
Joined Mar 2007
Oooooooo!!!!! I like!!!
w747 is offline Find More Posts by w747
Old Jan 03, 2015, 12:45 PM
I make stuff
cwrr5's Avatar
United States, AZ, Marana
Joined Dec 2011
Very nice! I've found that's a scale that's a good comprimise between "big" in the air and small enough to easily store/transport.
cwrr5 is offline Find More Posts by cwrr5
Old Jan 03, 2015, 01:21 PM
Winter Is Coming
Doushiyou12's Avatar
Joined Feb 2010
So many new builds in the making. YES!
Subbed for another I like the specs. Great start. Keep us posted.
Doushiyou12 is online now Find More Posts by Doushiyou12
Old Jan 03, 2015, 01:31 PM
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
hi2nr , . . . .where You been hiding yourself Sir? WOW!!! Simply amazing Project so Far, I eat-Sleep-& ShT 747!
The More RC airliner Builders The better I say! Subbed-Up!
demondriver is online now Find More Posts by demondriver
Old Jan 03, 2015, 01:45 PM
Joined Jun 2008
I've been trying to 3d it only to come back to the scale stuff so here I am!
I do have a question for you though, on your landing gear bases, are you supporting them with a ply sheet over foam or just blocks of ply attached to foam?
I figure I'm going to try the ply sandwiched in between to disperse the load of impact since I fly off of grass
Old Jan 03, 2015, 04:41 PM
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Another Great Plane In The making
Keenan smith is offline Find More Posts by Keenan smith
Old Jan 03, 2015, 07:04 PM
I make stuff
cwrr5's Avatar
Joined Dec 2011
Originally Posted by demondriver View Post
<snip> , I eat-Sleep-& ShT 747!
OUCH!
Old Jan 04, 2015, 12:49 AM
Joined Jun 2008
Here's the forward fuselage almost done. Haven't glued it yet since I still need to make the gear box
Old Jan 04, 2015, 01:13 AM
Up-Out-&-Gone
Joined Mar 2007
I would swear you and W747 where the same builder Hi2NR lol
Which means you Both are excellent builders!
Old Jan 04, 2015, 06:22 PM
Joined Jun 2008
Progress from today so far!
Old Jan 04, 2015, 06:26 PM
Joined Dec 2010
are you sure your not W747??
Great Work Man Shes looking HOTT!
Old Jan 04, 2015, 06:35 PM
Joined Jun 2008
Nope we just use the same card models :P
This is based off of the 747-400 modified and stretched to a 747-8. So I ended up adding about 6" in fuselage length. When I scaled it up the nacelle will have to be scrapped and scratched since I need to make them slightly bigger to accommodate 70mm fans which might have a ground clearance issue on grass runways if I build it scale
The weight so far is next to none so it kinda makes me want to keep it a depron model so it'll float in scale and slow. Then a part of me wants to make it a balsa sheeted model so I can add in full details.
Build Log Lufthansa 747-8 MrADT RC Airliners (Commercial, Cargo, Troop Carrier) 75 Oct 22, 2013 10:41 PM
Discussion 747-8 EDF Depron foam Ysharma Electric Plane Talk 6 Jul 13, 2013 11:20 AM
Discussion 747-8 atlas air cargo w747 RC Airliners (Commercial, Cargo, Troop Carrier) 31 Jul 02, 2013 10:28 PM
Discussion 3D model of Boeing's new 747-8 "Intercontinental" Mike James CAD/CAM 7 Sep 01, 2012 07:17 PM
