Old Dec 24, 2014, 09:42 AM
John
Willow Grove, PA
Joined Nov 2007
COG is way off
Upon finishing my first foamy (Value Hobby 32" Edge 540) and installing the 3S battery I have found the COG is much farther forward than the instruction manual has stated. I have the battery back as far as it will go in the battery compartment. I could enlarge the battery compartment but it most likely will have to be cut all the way back to the aileron servo. I know this plane can use a 2S or 3S so how do you balance the extra weight when using a 3S? I could just purchase a 2S but most of the reviews said it flies better on a 3S. Thanks.
Sandman70 is online now Find More Posts by Sandman70
Old Dec 24, 2014, 10:18 AM
RonJ's Avatar
Sparta,WI,USA
Joined Nov 2000
Boy, that's a tough one. You could go to a smaller mah 3S battery which will give you shorter flights. Many times the recommended CG is conservative. To me, that is the starting point. My final battery location is determined by flying inverted and finding the "hands off" point.
RonJ
RonJ is offline Find More Posts by RonJ
Old Dec 24, 2014, 03:14 PM
ProBro Spaz
spastic's Avatar
Buffalo, NY
Joined Aug 2004
yeah i'm like Ron i would tape the pack on for the first few flights to see where the CG really should be, it probably will balance for KE better with the pack on top of the fuse anyway, when i design my EPP planes i don't do a pre-cut slot because people tend to use different gear anyway
you didn't say what battery, motor, servos you used...? and where is the CG as is?
if you do enlarge the pre-cut slot you can add the cutoff back to the front of the slot
spastic is online now Find More Posts by spastic
Old Dec 24, 2014, 04:08 PM
John
Willow Grove, PA
Joined Nov 2007
The motor is a 2206.
9g aileron servo
5g rudder and elevator servos
Battery is 3s 800mah
I ordered the battery that was in the suggested parts for 3s setup off of Value Hobby's website, oddly enough when I check the site now it lists a 500mah 3s battery. After making the initial post I remembered my brother in law gave me all his rc plane stuff a few years ago which included a 2s 800mah battery, will this battery work with the 2206 motor?
Old Dec 25, 2014, 06:05 AM
oceanway99's Avatar
United States, FL, Jacksonville
Joined Feb 2012
those are heavy packs for this size plane. set it on top of the spar aand see how it flies inverted
oceanway99 is offline Find More Posts by oceanway99
Latest blog entry: Mancave
Old Dec 25, 2014, 07:26 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Yep, do like Oceanway says. Trim it out for level flight, then flip it inverted. With the CG in the proper place, the plane should neither climb or dive, whether upright or inverted for a 3D plane. There are other methods but this one is pretty precise.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Dec 25, 2014, 09:13 AM
John
Willow Grove, PA
Joined Nov 2007
Okay, I will give that a try when the weather cooperates. Thanks for the help.
Merry Christmas everyone!
Old Jan 13, 2015, 12:52 AM
Christian F
CaliPilot's Avatar
United States, CA, Redwood City
Joined Mar 2011
yeah, just velcro it to the top of the fuse
CaliPilot is online now Find More Posts by CaliPilot
Discussion Proctor Antic/ Stand Off Scale...way way off dr.E WWI Aircraft 20 Mar 31, 2014 04:35 PM
Alert MegasMicros.com Black Friday. $14 off motors. $10 off ESCs and way more. Mega Stumbler Hot Online Deals 0 Nov 29, 2013 09:32 AM
Discussion Best way to find COG? SJW2511 Multirotor Talk 5 Apr 19, 2013 01:21 PM
Question Best way to balance for COG dlovett Multirotor Talk 4 Mar 18, 2013 09:34 AM
way, way off topic Aussie thread woodsy Electric Flight Events 6 Mar 03, 2004 04:20 AM
