Old Jun 03, 2014, 08:59 AM
Joined Mar 2014
Question
AERONAUT Classic motor!
HEY all,
Im building a Aeronaut Classic but I don't know which motor I will use, any suggestions?
I want it to be from Hobbyking and brushless and last but not least I want it to be powerful enough.
hope someone can help!
cheers.
BASTHEBEAR is offline Find More Posts by BASTHEBEAR
Old Jun 03, 2014, 12:35 PM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Bas,
'Powerful enough' is relative, if you want the boat to run at scale speed like this:
Aeronaut Classic-Ein Abend am See (2 min 32 sec)
This is sufficient:
Roxxy BL 3529-20
Roxxy BL Control 930
Graupner 2318.37,5k prop
2S Lipo
HK will have an equivalent motor and ESC, just compare the roxxy data.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Jun 03, 2014, 12:40 PM
Joined Mar 2014
Hey,
Thank you, but what if I want it to have just a little more?
Not that I will go full speed but I want it to have that power.
Bas
Old Jun 03, 2014, 04:55 PM
Sneek, Netherlands.
Joined May 2004
Hi Bas,
That's a matter of calculus; 7,4V x 1500Kv = 11100 rpm unloaded, which is about 9000 rpm under load.
If you want to go faster, either take a bigger prop (if the motor can turn it), keep the prop and go for a 1600Kv, or 1800Kv motor with slightly more Watt, or both.
http://www.hobbyking.com/hobbyking/s...00Kv_875w.html
(This motor is way overkill and will turn a 40 - 42 twoblade, high pitch prop that will overturn the boat when full throttle is applied from a standstill.)
Another option is to go to 3S and select a lower Kv motor with sufficient power to tuern a bigger prop more efficiently (higher Voltage equals lower Ampdraw).
http://www.hobbyking.com/hobbyking/s...50Kv_600W.html
Still overkill, but easier on the Ampdraw.
To get an idea what overkill will do to a 110 cm boat, check out 800Kv on 4S on a 58 mm prop:
Short sprint Zwette 28 4 2014 (1 min 44 sec)
Not something a Classic hull was designed for!
Regards, Jan.
Wanted Graupner Super Dimona or Aeronaut Fournier Rf-4 motor gliders s2000 Aircraft - Sailplanes (FS/W) 2 Mar 07, 2014 04:27 AM
Help! Will a 10x7 Aeronaut folding prop exceed the limits of a Hyperion GS2218-10 Motor hog2soar Power Systems 2 Sep 27, 2013 04:10 AM
Sold Aeronaut CAM Carbon classic 10x7 RichR12 Aircraft - Electric - Power Systems (FS/W) 2 Feb 01, 2012 07:56 PM
For Sale Aeronaut Classic 10.5 x 6 folding prop blades RSTEARMAN Aircraft - Sailplanes (FS/W) 0 Jul 22, 2010 06:33 PM
Discussion Mounting AeroNaut Classic blades AndreyT Electric Sailplanes 5 Mar 17, 2006 10:30 PM
